Aftermarket Radio / Receiver - Bimmerfest - BMW Forums
Old 06-03-2019, 02:08 PM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
So I am looking again at the audio in the Z4 and I want to make a change and put in something else
I was always under the impression that you can not just change out the head unit. IF you did you would have to change out the Amp and the speakers.
Now I am talking to Crutchfield and they are saying I can change out the head unit but I would just need to splice in after the factory amp.
I wanted to find out other peoples experience.
Old 06-10-2019, 10:23 AM
bump
Old 06-12-2019, 08:46 AM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
There are lots of threads/posts on this subject.
A little time spent googling this will give you the details......
Hint: Run the last 7 digits through a vin decoder to see what radio system you have. There are 3...
Old 06-12-2019, 09:21 AM
I have the Hifi+ system i did look that up with my VIN
Old 06-12-2019, 09:50 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
The Crutchfield advice is good. My understanding is that the oem speaker impedance and amp are matched, making aftermarket upgrades a bit limited. If you end up keeping the factory head unit, I highly recommend the Grom unit which will let you stream music and retain steering wheel controls.
[SIGPIC]
Old 06-13-2019, 11:06 AM
I used the audiovox / soundcity Dice unit
This is a great solution that adds BT, Handsfree, AUX, Usb Satellite to your factory unit/. It works great.
I got a quote from best buy. Its about 1.2k to do the work. reasonable. the head unit is about $500. I am wanting a Pioneer Single din NEX unit. They also have spec-ed an alpine KTP-445U. its a 180w small amp. So it looks like the Nex will plug into the back of it and then it will be in the bypass of the factory amp.
I think i am gonna pull the trigger and do it. still just pulling it all over
Old 06-24-2019, 10:51 AM
Stinger22 Stinger22 is offline
Mein Auto:
2006, 3.0si E85. I had the Top End Hi-Fi ten speaker and my amp required a digital signal from the OEM HU to turn on the amp, not just the normal pre-amp power hitting the amp. Had to replace the OEM amp and they had to run all new wires. 4 signals came from the new head unit, Alpine, and six from the new amp also Alpine. Kept the OEM speakers they are not bad speakers at all.
Old 06-27-2019, 03:50 AM
How were you able to keep the OEM speakers, since they are not the same OHMs as 3rd party /aftermarket speakers?
Old 06-27-2019, 01:53 PM
Mein Auto:
I didn't run the wires myself the shop did but I don't think they had to bridge anything.
