*NEW* delete pls - Page 3 - Bimmerfest - BMW Forums
Old 06-15-2015, 01:24 PM
GHOST PROTOCOL's Avatar
GHOST PROTOCOL GHOST PROTOCOL is offline
Mein Auto: 2014 750ix M Sport
Got it. Okay. Close the new thread.
MCChuck's Avatar
MCChuck MCChuck is offline
Mein Auto: 2009 750Li
Everyone's reaction to the delete pls thread lock;
Originally Posted by MCChuck View Post
Meh
Harry.
Are you now the sheriff?
Old 06-15-2015, 01:25 PM
Attachment 514605
I don't think that is what anyone of the guys thought when they saw this pic.
Old 06-15-2015, 01:26 PM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
Originally Posted by cracked1 View Post
"Ellipses
An ellipsis is a set of three periods ( . . . ) indicating an omission. Each period should have a single space on either side, except when adjacent to a quotation mark, in which case there should be no space.
Informal writing
In informal writing, an ellipsis can be used to represent a trailing off of thought.
If only she had . . . Oh, it doesn't matter now.
An ellipsis can also indicate hesitation, though in this case the punctuation is more accurately described as suspension points.
I wasn't really . . . well, what I mean . . . see, the thing is . . . I didn't mean it.
Like the exclamation point, the ellipsis is at risk of overuse.
In quoted material
Ellipses are most useful when working with quoted material. There are various methods of deploying ellipses; the one described here is acceptable for most professional and scholarly work.
The following examples are based on a paragraph from Henry David Thoreau's Walden:
I learned this, at least, by my experiment: that if one advances confidently in the direction of his dreams, and endeavors to live the life which he has imagined, he will meet with a success unexpected in common hours. He will put some things behind, will pass an invisible boundary; new, universal, and more liberal laws will begin to establish themselves around and within him; or the old laws be expanded, and interpreted in his favor in a more liberal sense, and he will live with the license of a higher order of beings. In proportion as he simplifies his life, the laws of the universe will appear less complex, and solitude will not be solitude, nor poverty poverty, nor weakness weakness. If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
Ellipses at the beginning of a quotation
It is rarely necessary to use ellipsis points at the beginning of a quotation, even if the quotation begins mid-sentence. It is also usually acceptable to change the capitalization of the first word of the quotation to match the surrounding material. (When a change in capitalization must be acknowledged, you should use brackets, as explained here.)
"If one advances confidently in the direction of his dreams," writes Thoreau, "he will meet with a success unexpected in common hours." Moreover, Thoreau claims that "in proportion as he simplifies his life, the laws of the universe will appear less complex."
Quotations placed in the middle of a sentence
When a quotation is included within a larger sentence, do not use ellipsis points at the beginning or end of the quoted material, even if the beginning or end of the original sentence has been omitted.
Correct: When Thoreau argues that by simplifying one's life, "the laws of the universe will appear less complex," he introduces an idea explored at length in his subsequent writings.
Incorrect: When Thoreau argues that by simplifying one's life, ". . . the laws of the universe will appear less complex, . . ." he introduces an idea explored at length in his subsequent writings.
Quotations placed at the end of a sentence
When a quotation is placed at the end of a sentence, but the quoted material is only part of a larger sentence, authorities differ on the use of ellipsis points. The Chicago Manual of Style allows the use of a sentence-terminating period; the MLA Handbook for Writers of Research Papers requires ellipsis points.
Chicago style
Thoreau argues that by simplifying one's life, "the laws of the universe will appear less complex."
Could anyone other than Thoreau have written, "If you have built castles in the air, your work need not be lost"?
MLA style
MLA style places the sentence-terminating period immediately after the last word of the quotation, even though a period does not occur there in the original material. The three ellipsis points are then placed after this sentence-terminating period.
Thoreau argues that by simplifying one's life, "the laws of the universe will appear less complex. . . ."
Could anyone other than Thoreau have written, "If you have built castles in the air, your work need not be lost . . ."?
When using MLA-style parenthetical references, the sentence-terminating period is placed outside the parenthetical reference.
Thoreau argues that by simplifying one's life, "the laws of the universe will appear less complex . . ." (152).
Ellipses for omitted material within a single quoted sentence
Use ellipsis points to show omission within the quotation. Omit any punctuation on either side of the ellipsis, unless the punctuation is necessary to make the shortened quotation grammatically correct.
"I learned this . . . : that if one advances confidently in the direction of his dreams, . . . he will meet with a success unexpected in common hours."
In the example above, the colon in the original is needed to introduce the thing that Thoreau learned. The comma after "dreams" is necessary to separate a dependent clause from an independent clause.
Ellipses for omitted material spanning two or more sentences
When a quotation is presented as a single sentence made up of material from two or more original sentences, ellipses should be used for all omitted segments.
Thoreau believes that "if one advances confidently in the direction of his dreams, and endeavors to live the life which he has imagined, . . . he will live with the license of a higher order of beings."
When quoted material is presented as multiple sentences, four dots should be used for omissions between two or more original sentences; three dots should be used for omissions within a single original sentence.
In the example below, MLA style requires an ellipsis at the end of the quotation, indicating that a portion of the original sentence has been omitted. Chicago style would omit the final ellipsis and terminate the sentence with a single period.
Thoreau notes: "I learned . . . that if one advances confidently in the direction of his dreams, . . . he will meet with . . . success. . . . He will put some things behind, will pass an invisible boundary. . . . In proportion as he simplifies his life, the laws of the universe will appear less complex. . . ."
That was too much for me to digest right after lunch . . .
https://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:27 PM
Come on Fred.
Put your back into it.
Who Posted? Total Posts: 54
User Name Posts
GHOST PROTOCOL 26
MCChuck 9
bighorns 8
Popoemt 3
cracked1 3
Yinzer 2
Jay Arras 2
tim330i 1
Old 06-15-2015, 01:28 PM
bighorns's Avatar
Evil cider brewer
Originally Posted by GHOST PROTOCOL View Post
Come on Fred.
User Name Posts
GHOST PROTOCOL 26
MCChuck 9
bighorns 8
Popoemt 3
cracked1 3
Yinzer 2
Jay Arras 2
tim330i 1
You all know that I'm a late night poster. I'm 'working' today!
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:34 PM
Yinzer's Avatar
Yinzer Yinzer is offline
6 RINGS
Mein Auto: CTS-V,540,Subaru Forester
Its crazy the old thread is locked
BMW CCA MEMBER 486229
Old 06-15-2015, 01:35 PM
Yinzer's Avatar
6 RINGS
It was the cool hangout spot
Old 06-15-2015, 01:37 PM
The old thread probably would have crashed if it was allowed to get much larger.
Now it's here.
Old 06-15-2015, 01:44 PM
Yinzer's Avatar
6 RINGS
At least were all starting from 0
Old 06-15-2015, 01:45 PM
It is a little like the race for the cup.
The points all get adjusted for the final 10 races.
Old 06-15-2015, 01:47 PM
bighorns's Avatar
Evil cider brewer
Double rainbow from Friday:
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:49 PM
bighorns's Avatar
Evil cider brewer
It got up to 100 degrees yesterday.
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:50 PM
bighorns's Avatar
Evil cider brewer
Duke will just push the cover out of his way when he gets too hot:
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:51 PM
Yinzer's Avatar
6 RINGS
I wonder if any new people will jump in
Old 06-15-2015, 01:56 PM
bighorns's Avatar
Evil cider brewer
A couple of us actually recruited Justin. Perhaps we should go out and find some new blood!
*NEW* delete pls 1K
3K
11K
Old 06-15-2015, 01:59 PM
MCChuck's Avatar
It's a reaction shot open to many interpretations. Many interpret it such as we did on first sight.
Take another 'shot' at further interpretation.
Old 06-15-2015, 02:00 PM
MCChuck's Avatar
Good thing it was a face only pic.
Old 06-15-2015, 02:17 PM
Crocadilen's Avatar
Crocadilen Crocadilen is offline
Mein Auto: 2000 BMW 740i
So so we need new shirts now lol
Old 06-15-2015, 02:21 PM
MCChuck's Avatar
New shirts!
Craig will have them all made by 8/15.
It has to be done
Old 06-15-2015, 02:22 PM
Attachment 514611
The interpretations can not be posted on this thread.
I was thinking the same thing.
*pipe dreams*, -*nga*-, animal behavioral research, deletepls, dog biting, j loy knows an ugly dog owner, jeff loves puppies, njspca, pvc dog coaching, tmi
