Would a bad crank position sensor give O2 sensor control limit error - Bimmerfest - BMW Forums
Old 01-21-2020, 04:03 PM
bluelectron bluelectron is offline
Mein Auto: E39 523i
I have been having a recurring crank position sensor problem on my 1997 523i (Euro spec 2.5L engine). I replaced the sensor about a month ago and the car was starting and running fine until yesterday. Last evening I felt the power was down again and checked the codes using a Peake Research R5 scanner. I go the following error code
53 Crankshaft sensor
CA O2 sensor control limit, Cyl 1-3
CB O2 sensor control limit, Cyl 4-6
I took the car to an Indy mechanic today and they confirmed the same codes. However, I asked to do a smoke test before changing the crank sensor.
My question is would a bad Crankshaft sensor cause O2 control limit errors. They seemed to believe it would. Before replacing the crank sensor the car would not start. It starts fine now.
I read that the quality of the crank sensor makes a huge difference. I am finding it difficult to get genuine BMW crank sensor for a Euro spec car in Canada.
Old 01-21-2020, 05:16 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The codes are not related.
Sounds like a massive vacuum leak (unless the fuel trims are negative).
If the crank sensor was bad, the car would not start, as you observed before replacing the sensor.
Old 01-21-2020, 05:30 PM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
ah yeah it could...
when the engine is out of time.. the firing it off the mixture is wrong and the result is the o2's catching that downstream
When ever doing a diag process tree you must trouble shoot the a primary codes before you do the seconday codes
more then likely what you have is a timing event, being captured as the crank code, and the result effect is out of mixture
you will need a better scan tool to confirm..
also live data... But what your asking is possible
Specializing In Breaking Things Professionally
15486372<-----
Old 01-21-2020, 06:35 PM
blackslcchild blackslcchild is offline
Mein Auto: E39
So you replaced the crank sensor but itís not a good brand or bmw oem?
Old 01-22-2020, 04:13 PM
Mein Auto: E39 523i
The mechanic performed a smoke test and confirmed there were no vacuum leaks.
They claim to have fixed the problem with a crank position senor that costs $200+ .
As I mentioned the car is Euro spec and the sensor is not the same as the ones on North American cars. ECS tuning had a sensor for this car and I replaced it with that. $15 sensor + $40 shipping to Canada .
Old 01-23-2020, 10:19 AM
Originally Posted by Burning2nd View Post
ah yeah it could...
I was under the impression that, if the crank sensor was bad, the engine would not start.
Old 01-23-2020, 10:24 AM
Mein Auto: E39 523i
I was under the same impression because the car did not start with the previous bad sensor. But it was starting now but would not idle well and was really down on power.
If there is not signal from the sensor the ECU does not pump fuel during cranking. However, if there is signal but the signal quality is poor the car starts but timing is off.
The car seems to be running fine now with a $200 sensor. I am hoping it stays this way.
Old 01-23-2020, 11:11 AM
Certainly possible. If the sensor were of poor quality, the output signal could be intermittent.
Old 01-23-2020, 11:28 AM
Burning2nd's Avatar
Under the lift arms
not always
15486372<-----
Old 01-23-2020, 05:38 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
^^^ what he said...sensor being bad isnt always a black or white issue, theres a lot of gray area in between.
99 528i 5sp sport
be alert...the world needs more lerts
Old 01-23-2020, 10:01 PM
djbecker djbecker is offline
Mein Auto: e30,e34,Z3,e39
If you are getting an erratic signal, the error would be logged.
But it's very unlikely to cause the air/fuel ratio to exceed the controllable limit. That is very likely an air leak. It might possibly be low fuel pressure, but that would be much further down on the list.
Is this a regular M52 single VANOS iron block engine? What was the part number for the crank position sensor? Is it a three pin or four pin sensor? Does your car have an adapter cable to use the updated M52tu sensor?
12141744492
12141709616
Old 01-24-2020, 04:17 AM
Burning2nd's Avatar
Under the lift arms
except he already had a OEm sensor installed and the problem was fixed.......
really... if you guys want to get technical...
you can always just view the waveform thru a oscilloscope.. and thee whole conversation about if it can be possible is null
Im telling you very indirectly with out shouting at you.. that its possible
further more.. there is no golden promise that you get code that reflects thee actual problem
when you are running lean... doesnt mean you get a lean code
when your mis fireing... the big difference is with or with out cut off
If the op would have never mentioned anything about the crank sensor in the Original post... the diag tree would have been different
case and point.. I fought a lean code bank 1 and 2 for 5 years, if i would have listened to your recommendation i would have wasted money on 02 sensors : it was a maf sensor... and had nothing to do with the 02 sensors
BUT the code said O2 sensors out of range..... here we are 10 years later with the same o2's running perfectly
15486372<-----
Old 01-24-2020, 11:55 AM
Yes, "sensor control limit" or other out-of-range descriptions means that the ECU can't control the air-fuel ratio as it expects.
The ECU won't post that error unless it's pretty sure that the oxygen sensor is working. You are "shooting the messenger" if you replace the oxygen sensors based on those errors.
I don't think that there is an "European" crank sensor. Rather there was an update for the U.S. (and perhaps Canada) that replaced the original sensor with the newer design from the M52tu because the engines were failing emissions checks when the sensor went flaky. In the U.S. emissions-related equipment gets an extended warranty. BMW would normally exclude parts such as crank sensor from warranty coverage, but a pattern of failing emissions is a big deal.
Old 01-24-2020, 12:49 PM
Burning2nd's Avatar
Under the lift arms
lol except he already fixed the problem by replacing the crank position sensor
15486372<-----
Old 01-24-2020, 01:33 PM
bmw blue's Avatar
bmw blue bmw blue is offline
Mein Auto: 2000 BMW 528i Steptronic
Original poster should list the 1997 BMW European Crank Sensor part #, I would have.
BTW, I had a 1994 SHO Taurus, I had to replace the crank sensor twice in the 8 years I owned it. Car would cough, stall, shut down for a few minutes to an hour then start up and drive fine for a day/week/whatever until it decided to do it again, never a code. What a pain in the arse that thing was to replace.
Old 01-24-2020, 01:35 PM
Burning2nd's Avatar
Under the lift arms
i remember that motor well..... what a blast to drive
15486372<-----
Old 01-24-2020, 01:43 PM
bmw blue's Avatar
Yes it was, that engine would just pull and pull. Always wished it was a rear wheel drive, that would have been really cool.
