Where can I find oils that meet LL-01 today? - Bimmerfest - BMW Forums
Old 08-11-2019, 11:57 AM
xivzgrev xivzgrev is offline
Mein Auto: bmw x3
Hi all,
I'm struggling to find the current acceptable options for changing my oil in my 2008 X3.
Last year I changed my oil with Mobil 1 based on owner's manual, but was told by my mechanic that next oil change I should definitely use an oil that's (still) LL-01. Apparently it was at one time, but no longer?
I had also posted to this forum, and was told that Castrol 0W-40 was the typical economic choice for LL-01 rated oils. But when I look at it today, it doesn't seem to be LL-01 rated anymore: https://www.walmart.com/ip/Castrol-E...-5-QT/35931146
I also heard that Pennzoil is now the recommended choice by BMW. I went to their website, selected my make & model, and was recommended to get Pennzoil Platinum Euro SAE 5W-30 Full Synthetic Motor Oil. But when I look that up at Wal-Mart, it's LL-04 rated, not LL-01. LL-04 I heard would f* your engine with US car / fuel: https://www.1addicts.com/forums/showthread.php?t=541486
I tried Googling around but it seems BMW doesn't post a list of approved oils anymore, probably because they want you to just go to dealership.
So at this point I'm a bit stuck. I remember mechanic suggesting Liquid Moly, I found this "kit" for $60, but seems a bit expensive...may be my only option than going to dealer though? https://www.fcpeuro.com/products/bmw...427566327kt-lm
Old 08-11-2019, 12:51 PM
Autoputzer Autoputzer is online now
Today, as in Sunday? Probably nowhere that's open. BMW branded oil that meets BMW LL-01 can be had for about $9/liter on-line. The Pennzoil that meets BMW LL-01 is Platinum Euro (not Euro L, which meets BMW LL-04, and is only suitable for diesels in the U.S.). But, Euro is also known as unicorn oil.
Mobil has recently come out with Mobil Super Synthetic Euro. The 5W-40 meets BMW LL-01. LinkyÖ.
https://mobiloil.com/en/motor-oils/m...synthetic-euro
Old 08-11-2019, 09:56 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
BMW part number is 83212365946 for LL-01 Twinpower Turbo, 5w-30 at just under $9/L. Still available at ecstuning, turnermotorsport and autohausas; generally free shipping if your order is big enough. Forget Amazon, they want $14.75/L currently.
If you can't fix it, you don't own it.
Old 08-11-2019, 01:51 PM
dukedkt442 dukedkt442 is online now
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
The Castrol edge 0w-40 euro is a3/b4 rated and LL-01 approved. Their 5w-40 is also LL-01 approved (I have some on my shelf). Buy it at Walmart or anywhere youíd buy oil. I donít see what the problem is.
Or buy liquimoly, pentosin, etc online. $60 isnít much for full synthetic oil change.
Old 08-11-2019, 07:48 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is online now
BeeemerBro
Mein Auto: X3 M54 150k
Deja vu?
https://r.tapatalk.com/shareLink?url...5&share_type=t
Sent from my SM-G531H using Tapatalk
[FONT="Arial Black"]
Old 08-13-2019, 05:15 AM
abscate abscate is online now
Mein Auto: 2006 BMW X3... VOLVO... V
Ignore the oil hype and use a quality full synthetic and change in 5000-7500 mile intervals.
Mechanics aren't oil experts
Old 08-13-2019, 05:25 AM
BeeemerBro
Actually this is accurate and sound advice...if I did it, I would stick to 5000 intervals... (that's with the cheaper oils tho) and of course one is using the recommended oil weight from the manufacture.
Old 08-13-2019, 02:57 PM
ac_2007 ac_2007 is offline
Mein Auto: 2006 BMW X3 6MT
Lol, exactly.
Unless you're running 20k intervals it won't make one crap worth of difference.
Old 08-13-2019, 08:14 PM
Originally Posted by ac_2007 View Post
Lol, exactly.
Other than the oils that don't chemically react well with engine internals (like sleeves, which BMW has a history of issues with).
With Castrol being as cheap and readily available as it is. I really don't understand the need to fix something that isn't broken.
Old 08-13-2019, 08:42 PM
Attacking Mid's Avatar
Attacking Mid Attacking Mid is offline
Mein Auto: 04 X5 3.0i, 08 X3 3.0si
That's where I sit. If the only approved oils available were $12/qt or similar, I'd probably take my chances on something less expensive. Jet.com has had Castrol for $20.xx / 5qt jug recently, so getting an approved oil at that price is a no-brainer to me.
AM.
Old 08-13-2019, 09:24 PM
I've been running Castrol synthetic from Costco for over 10 years, in all of my vehicles. (E46 M3 excluded)
You're preaching to the choir.
Old 08-14-2019, 08:50 PM
cn90 cn90 is offline
This Q has been asked hundreds of times in different forums.
I do not pay attention to LL01 etc. b/c of sludge issue with long oil change interval.
I just get the least expensive synthetic (such as Napa synthetic or Supertech at Walmart) and a Mahle filter.
I drive 50-50 city-hwy mix and I replace my oil every 5K miles.
Zero issues so far.
Old 08-15-2019, 12:03 PM
BeeemerBro
I will still run the 0w40 mobile...but when I find (walmart, Amazon, eBay, letgo)
'LL 01...i swipe it up
Sent from my SM-J727T using Tapatalk
Old 08-29-2019, 08:57 PM
BeeemerBro
Wal-Mart $20 for a jug of the Castrol 0w-40! May have to pick up a couple of jugs and put on the shelf...but I'm pretty stocked up as it is
Old 08-30-2019, 04:45 AM
Car company generates a " spec for oil" then goes and sells it To oil companies for the privilege of being the " recmmemded vendor"
Quite the scam. Use oil analysis to determine the right OCI for you,
Don't forget to buy a new oil cap each time the high Bidder becomes the new " recommended oil vendor"
Old 10-01-2019, 01:01 PM
namelessman namelessman is offline
Mein Auto: bimmer
Another LL01 is Walmart Penzoil Platinum Euro 5w30 5 quarts for everyday low price $22.68 + tax for free in-store pickup.
Penzoil $10 rebate for 5quarts(two coupons max) used to include Walmart, so net price used to be $15/5 quarts LL01! Walmart is no longer on the list though.
Old 10-02-2019, 06:08 AM
I assume LL-04 will soon replace LL-01 as sulfur levels are mandated to be reduced in US gasoline supplies. Jan 1, 2020 is another significant deadline for US refiners to meet the requirements. The oil formulations meeting LL-04 apparently don't play well with the high sulfur levels we've traditionally had in our US gasoline supplies. Europe has had low sulfur gas for some time, which is why the same engines in Europe list LL-04 while here in the US, BMW has stuck with LL-01 rated oils. It would be nice to see BMW put out something official explaining this, however.
AM.
Old 10-02-2019, 06:36 AM
AM.
And with the US backing off of emissions and fuel economy regulations, who knows if the low sulfur dictate will actually occur; time will tell. I'd love to use Pennzoil Platinum (like in the rest of the fleet), but the A1 oils don't play well with BMW cylinder sleeves IIRC.
Old 10-02-2019, 07:26 AM
kind16 kind16 is offline
Mein Auto: X3
I just bought a Castrol edge 0w-40 a3/b4, the LL01 statement is not on the back of the jar any more...
2010 X3 28i Black, Engine N52B30 AT
(Millage Sep2019-112K km)
2015 Dodge Caravan, AT
(Millage Sep2019-30K km)
Old 10-02-2019, 08:11 AM
Here's some decent info on BMW oil specs: https://www.bimmerworld.com/BMW-Engine-Oil/
AM.
Old 10-02-2019, 08:33 AM
AM.
Very interesting read; a 5th purpose of oil needs to be added, and that is for hydraulic operation of the VVT system, which requires appropriate anti-foaming agents to keep the VANOS operating properly. Liquid doesn't compress, but gas of course does.
Old 10-02-2019, 09:09 AM
I would also take exception with the statement, "In 2016 BMW announced new 0W30 to replace 5W30. 0W30 carries the same LL-01 approval with a FE label, making it backwards compatible but also making newer models more fuel efficient." Emphasis mine.
I've seen contradicting statements on this, but I doubt that BMW engineers would agree that "FE" oils are backward compatible.
If we can trust that sulfur levels are now (or soon) low enough to use diesel oils, something like Shell Rotella T6 would sound more appealing to me. I've read many reports of people using it anyway over recent years. For now I have several 5 qt jugs of Castrol Edge 0W-40 LL-01 to keep me going for another year or more.
AM.
Old 10-02-2019, 10:46 AM
AM.
If we can trust sulfur is a big IF, IMO. Don't forget the ZDDP (imperative for flat tappet cams) is also damaging to exhaust catalysts. I do really want to use Shell Rotella Gas truck oil, which is currently the highest-rated non-racing oil, rated higher than (in decreasing order) Quaker state ultimate durability and Pennzoil Platinum, but don't think it is A3 rated. I did use Rotella 15w-40 in my MK3 Jetta, but was just too thick for the climate; switched to 5w-40 and the old ABA loved it.
Old 10-02-2019, 09:33 AM
Markst Markst is offline
Mein Auto: BMW 5
While that page has some good info on oils. it isn't particularly accurate.
Old 10-03-2019, 12:52 AM
BeeemerBro
The last oil shoot out eruption!
https://www.bimmerfest.com/forums/sh...php?p=12913333
