X3 E83 (2004 - 2010)
Where can I find oils that meet LL-01 today?
Hi all,
I'm struggling to find the current acceptable options for changing my oil in my 2008 X3. Last year I changed my oil with Mobil 1 based on owner's manual, but was told by my mechanic that next oil change I should definitely use an oil that's (still) LL-01. Apparently it was at one time, but no longer? I had also posted to this forum, and was told that Castrol 0W-40 was the typical economic choice for LL-01 rated oils. But when I look at it today, it doesn't seem to be LL-01 rated anymore: https://www.walmart.com/ip/Castrol-E...-5-QT/35931146 I also heard that Pennzoil is now the recommended choice by BMW. I went to their website, selected my make & model, and was recommended to get Pennzoil Platinum Euro SAE 5W-30 Full Synthetic Motor Oil. But when I look that up at Wal-Mart, it's LL-04 rated, not LL-01. LL-04 I heard would f* your engine with US car / fuel: https://www.1addicts.com/forums/showthread.php?t=541486 I tried Googling around but it seems BMW doesn't post a list of approved oils anymore, probably because they want you to just go to dealership. So at this point I'm a bit stuck. I remember mechanic suggesting Liquid Moly, I found this "kit" for $60, but seems a bit expensive...may be my only option than going to dealer though? https://www.fcpeuro.com/products/bmw...427566327kt-lm Last edited by xivzgrev; 08-11-2019 at 12:08 PM. |
Sponsored Links | ||
Advertisement | ||
Today, as in Sunday? Probably nowhere that's open. BMW branded oil that meets BMW LL-01 can be had for about $9/liter on-line. The Pennzoil that meets BMW LL-01 is Platinum Euro (not Euro L, which meets BMW LL-04, and is only suitable for diesels in the U.S.). But, Euro is also known as unicorn oil.
Mobil has recently come out with Mobil Super Synthetic Euro. The 5W-40 meets BMW LL-01. Linky…. https://mobiloil.com/en/motor-oils/m...synthetic-euro |
The Castrol edge 0w-40 euro is a3/b4 rated and LL-01 approved. Their 5w-40 is also LL-01 approved (I have some on my shelf). Buy it at Walmart or anywhere you’d buy oil. I don’t see what the problem is.
Or buy liquimoly, pentosin, etc online. $60 isn’t much for full synthetic oil change. Sent from my iPhone using Bimmerfest
Advertisement | ||
Deja vu
![]() https://r.tapatalk.com/shareLink?url...5&share_type=t Sent from my SM-G531H using Tapatalk
BMW part number is 83212365946 for LL-01 Twinpower Turbo, 5w-30 at just under $9/L. Still available at ecstuning, turnermotorsport and autohausas; generally free shipping if your order is big enough. Forget Amazon, they want $14.75/L currently.
If you can't fix it, you don't own it. |
Ignore the oil hype and use a quality full synthetic and change in 5000-7500 mile intervals.
Mechanics aren't oil experts |
![]() Sent from my SM-G531H using Tapatalk
Unless you're running 20k intervals it won't make one crap worth of difference. |
With Castrol being as cheap and readily available as it is. I really don't understand the need to fix something that isn't broken.
AM. |
You're preaching to the choir. ![]() |
This Q has been asked hundreds of times in different forums.
I do not pay attention to LL01 etc. b/c of sludge issue with long oil change interval. I just get the least expensive synthetic (such as Napa synthetic or Supertech at Walmart) and a Mahle filter. I drive 50-50 city-hwy mix and I replace my oil every 5K miles. Zero issues so far. |
The engine failure doesn't occur until 150K miles.
J/K - I saw your mileage listed as 140K ![]() I doubt your method will have any negative effects. I just stick to my assertion that for as cheap and readily available as is LL-01 approved Castrol Edge 0W-40, I see no reason to use something else that ISN'T approved. As mentioned previously, I've bought my last few jugs for $20.xx at Jet.com. Even Super Tech isn't much cheaper than that. AM. |
I still run Mobil 0w-40 at 10k mile intervals on my 05. Currently at 200k.
Is there a reason we can't still use Mobil1 0w-40 even though it is no longer LL-01 approved? It's still the same blend no? |
AM. |
I will still run the 0w40 mobile...but when I find (walmart, Amazon, eBay, letgo)
'LL 01...i swipe it up ![]() Sent from my SM-J727T using Tapatalk
Wal-Mart $20 for a jug of the Castrol 0w-40! May have to pick up a couple of jugs and put on the shelf...but I'm pretty stocked up as it is
Car company generates a " spec for oil" then goes and sells it To oil companies for the privilege of being the " recmmemded vendor"
Quite the scam. Use oil analysis to determine the right OCI for you, Don't forget to buy a new oil cap each time the high Bidder becomes the new " recommended oil vendor" |
Another LL01 is Walmart Penzoil Platinum Euro 5w30 5 quarts for everyday low price $22.68 + tax for free in-store pickup.
Penzoil $10 rebate for 5quarts(two coupons max) used to include Walmart, so net price used to be $15/5 quarts LL01! Walmart is no longer on the list though. |
To me LL01(esp. cheap and readily available) is a no brainer, the non-LL01 proponents are just spinning to occupy internet bandwidth. ![]() Last edited by namelessman; 10-01-2019 at 01:36 PM. |
I assume LL-04 will soon replace LL-01 as sulfur levels are mandated to be reduced in US gasoline supplies. Jan 1, 2020 is another significant deadline for US refiners to meet the requirements. The oil formulations meeting LL-04 apparently don't play well with the high sulfur levels we've traditionally had in our US gasoline supplies. Europe has had low sulfur gas for some time, which is why the same engines in Europe list LL-04 while here in the US, BMW has stuck with LL-01 rated oils. It would be nice to see BMW put out something official explaining this, however.
AM. |
I just bought a Castrol edge 0w-40 a3/b4, the LL01 statement is not on the back of the jar any more...
2010 X3 28i Black, Engine N52B30 AT (Millage Sep2019-112K km) #2 2015 Dodge Caravan, AT (Millage Sep2019-30K km) |
#25
Here's some decent info on BMW oil specs: https://www.bimmerworld.com/BMW-Engine-Oil/
AM. |
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
