Automatic Upshift Problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 09-14-2011, 11:04 PM
fiveten fiveten is offline
Mein Auto: 328
So I have a 2001 Z4 sdrive 35i with the 7 speed DCT transmission. if I am doing about 50 and floor the gas pedal down all of the way while in manual mode, my car will drop down to second gear. If i keep the pedal floored and use the paddle shifters at 6100 rpms it will go to third. If I still keep the pedal floored and use the paddle shifters at 6100 rpms it will momentarily go to fourth gear and then automatically go the fifth. Anyone else having this problem.
Old 09-26-2011, 10:53 PM
sammie sammie is offline
Mein Auto: chev
I found 31 Service Bulletins
Report Date : September 27, 2011 at 12:49 AM
Search Type : VEHICLE
Year : 2009
Make : BMW
Model : Z4
Results : 31 | All records displayed
Make : BMW Model : Z4 Year : 2009
Manufacturer : BMW OF NORTH AMERICA, LLC
Service Bulletin Number : SIB-33-01-02 Date of Bulletin : JUL 01, 2011
NHTSA Item Number : 10040853
Component : SUSPENSION:REAR:AXLE:NON-POWERED AXLE ASSEMBLY
Summary :
BMW: A GRINDING NOISE IS COMING FROM THE DIFFERENTIAL DURING SLOW CORNERING. WHEN TURNING A SLIP/STICK EFFECT IS CREATED ON THE LINING AND STEEL DISCS INCORPORATED IN THE DIFFERENTIAL CLUTCH CAUSES A GRINDING NOISE. *RM
Check to Request Research. Submit below.
Service Bulletin Number : SIB-11-02-08 Date of Bulletin : JUN 01, 2011
NHTSA Item Number : 10032779
Component : ENGINE AND ENGINE COOLING:ENGINEIESEL
Summary :
BMW VEHICLE: THE SERVICE ENGINE SOON (MIL) LAMP IS ILLUMINATED AND A POWER REDUCTION IS CLEARLY PERCEPTIBLE. THIS SITUATION MAY OCCUR AFTER DRIVING FOR SOME TIME WITH THE ENGINE ALREADY AT FULL OPERATING TEMPERATURE. IF THE IGNITION IS CYCLED, THE ENGINE THEN USUALLY PERFORMS NORMALLY. *PE UPDATED 2/7/11. *PE UPDATED ON 06/09/2011. *KB UPDATED 8/10/11. *PE
Summary :
Service Bulletin Number : SIB-28-01-10 Date of Bulletin : JUN 01, 2011
NHTSA Item Number : 10037069
Component : POWER TRAIN:AUTOMATIC TRANSMISSION
Summary :
BMW: THERE IS A SOFTWARE PROBLEM WITH THE DUAL CLUTCH TRANSMISSION MODULE. DATA CAN'T BE READ FROM THE MODULE'S MEMORY. *RM UPDATED 8/10/11. *PE
Component : POWER TRAIN:MANUAL TRANSMISSION
Summary :
Service Bulletin Number : SIB-23-01-08 Date of Bulletin : APR 01, 2011
NHTSA Item Number : 10040045
Summary :
BMW: A NEW TECHNICAL SUPPORT PROCESS HAS BEEN CREATED REGARDING TRANSMISSION CONCERNS. *RM
Service Bulletin Number : SIB-12-01-11 Date of Bulletin : MAR 01, 2011
NHTSA Item Number : 10039765
Component : FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
Summary :
BMW: THE SERVICE ENGINE SOON LIGHT IS ON WHILE DRIVING. THIS IS A PROGRAMMING ISSUE. *RM
Component : ELECTRICAL SYSTEM: SOFTWARE
Summary :
Service Bulletin Number : SI B12 55 06 Date of Bulletin : JAN 01, 2011
NHTSA Item Number : 10037700
Summary :
BMW: THERE MAY BE EXCESSIVE CRANKING BEFORE THE VEHICLE STARTS. THE SERVICE ENGINE SOON LIGHT MAY ALSO BE ON WITH A LACK OF ENGINE POWER. *RM
Service Bulletin Number : SIB-11-03-08 Date of Bulletin : DEC 01, 2010
NHTSA Item Number : 10038217
Component : ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:CRANKCASE (PCV)
Summary :
BMW: CRANKCASE PRESSURE DIAGNOSIS AND INFORMATION FOR ALL VEHICLES. *RM
Service Bulletin Number : SIB-51-42-10 Date of Bulletin : NOV 01, 2010
NHTSA Item Number : 10037464
Component : STRUCTURE:FRAME AND MEMBERS
Summary :
BMW: WATER IS LEAKING INTO THE LUGGAGE COMPARTMENT DUE TO A DAMAGED SEAL ON REAR VENTS. *RM
Component : STRUCTURE:BODY
Summary :
Component : STRUCTURE:BODY:TRUNK LID
Summary :
Service Bulletin Number : SIB-16-09-10 Date of Bulletin : SEP 01, 2010
NHTSA Item Number : 10037125
Component : FUEL SYSTEM, OTHERELIVERY:FUEL PUMP
Summary :
BMW: WHILE DRIVING THERE IS A WHISTLING OR HOWL NOISE COMING FROM THE PASSENGER SIDE. *RM
Summary :
Service Bulletin Number : SIB-63-02-01 Date of Bulletin : AUG 01, 2010
NHTSA Item Number : 10037025
Component : EXTERIOR LIGHTING
Summary :
BMW: PROCEDURE FOR DETERMINING AND REPLACING INCANDESCENT AND HALOGEN LIGHT BULBS UNDER WARRANTY. *RM
Service Bulletin Number : SI B12-55-06 Date of Bulletin : JUL 01, 2010
NHTSA Item Number : 10025701
Summary :
N54-DIAGNOSIS FOR DME FC 29DC/2FBF FOR MODELS E90, E92 PRODUCED FROM 06/06 AND E93, E60, E61 PRODUCED FROM 03/07. *PE UPDATED 7/8/09. *PE MODELS E82, E88 PRODUCED FROM START 2000 AND E71 PRODUCED FROM START 2000. UPDATED 7/21/10. *PE MODELS X6, E89, Z4 FROM START OF PRODUCTION. UPDATED 11/1/10. *PE MODELS F01 AND F02 FROM START OF PRODUCTION. UPDATED 1/3/11. *PE
Service Bulletin Number : SIB-11-08-03 Date of Bulletin : JUL 01, 2010
NHTSA Item Number : 10037010
Summary :
BMW: SIX DIFFERENT MODELS EQUIPPED WITH THE M54 ENGINE COULD HAVE VALVE COVERS BREAK IN COLD WEATHER AND RUIN THE ENGINE. THIS IS DUE TO MOISTURE ACCUMULATION. *RM
Summary :
Service Bulletin Number : SIB-32-04-07 Date of Bulletin : JUN 01, 2010
NHTSA Item Number : 10036979
Component : STEERING:ELECTRIC POWER ASSIST SYSTEM
Summary :
BMW: A NEW TECHNICAL PROCESS HAS BEEN CREATED FOR BMW TO IDENTIFY CAUSES OF STEERING COMPLAINTS WITH A WIDE RANGE OF MODELS. *RM
Service Bulletin Number : SIB-28-02-08 Date of Bulletin : JUN 01, 2010
NHTSA Item Number : 10036980
Summary :
BMW: A NEW TECHNICAL PROCESS IS BEING USED ON MANY MODELS TO DETERMINE THE ROOT CAUSE OF DOUBLE-CLUTCH TRANSMISSION PROBLEMS. *RM
Service Bulletin Number : SI B12 12 10 Date of Bulletin : JUN 01, 2010
NHTSA Item Number : 10037702
Summary :
BMW: WHEN AT LOWER SPEEDS OR STOPPING THE ENGINE IDLE DIPS TOO LOW BECAUSE OF A SOFTWARE PROBLEM. *RM
Component : STEERING:HYDRAULIC POWER ASSIST SYSTEM
Summary :
Service Bulletin Number : SIB-61-18-09 Date of Bulletin : APR 01, 2010
NHTSA Item Number : 10034467
Summary :
BMW VEHICLES: VARIOUS SIMULTANEOUS ELECTRICAL PROBLEMS. THERE IS A SOFTWARE ERROR IN THE JBBFE-3R CONTROL MODULE. VERY INTERMITTENTLY, THE JBBFE-3R WAKES UP IN BOOTLOADER ODE INSTEAD OF APPLICATION MODE. PERFORM DIAGNOSTICS WITH ISTA AND WORK THROUGH ANY RELATED TEST MODULES. *PE
Summary :
Service Bulletin Number : SIB-16-02-09 Date of Bulletin : DEC 01, 2009
NHTSA Item Number : 10033130
Component : FUEL SYSTEM, GASOLINEELIVERY:FUEL PUMP
Summary :
BMW VEHICLES: FUEL LEVEL SENSOR REPAIRS. WHERE IT IS NECESSARY TO REPLACE THE RIGHT OR THE LEFT SIDE FUEL LEVEL SENSOR DUE TO A FAILURE, THE ENTIRE PUMP AND HOUSING OR DELIVERY UNIT (SUCTION JET ASSEMBLY) DO NOT NEED TO BE REPLACED AS WELL. IN SOME CASES, EPC DOES NOT SHOW THAT THE REPAIR KIT IS AVAILABLE SEPARATELY IN THE ILLUSTRATION, BUT IT IS AVAILABLE IN THE PARTS DESCRIPTION. ALL MODELS. NO MODEL YEARS LISTED. *PE
Service Bulletin Number : SI-B-34-11-08 Date of Bulletin : AUG 01, 2009
NHTSA Item Number : 10030844
Component : SERVICE BRAKES, AIR
Summary :
BMW VEHICLES: TEILECLEARING FOR DYNAMIC STABILITY CONTROL (DSC). A PART REPLACEMENT AUTHORIZATION MUST BE OBTAINED BY SUBMITTING A TC CASE IN PUMA BEFORE ANY OF THE FOLLOWING DSC COMPONENTS ARE REPLACED UNDER WARRANTY FOR THE VEHICLES LISTED IN THE MODEL SECTION OF THIS BULLETIN: DSC CONTROL MODULE, DSC HYDRO UNIT, AND YAW RATE SENSOR. NO MODEL YEARS LISTED. *PE
Service Bulletin Number : SI-B72-02-09 Date of Bulletin : AUG 01, 2009
NHTSA Item Number : 10030843
Component : SEAT BELTS:FRONT
Summary :
BMW: BELT TENSIONER HARNESSES. A REPAIR HARNESS FOR THE FRONT SEAT SAFETY BELT TENSIONERS AT THE BELT RETRACTORS MAY HAVE BEEN IMPROPERLY INSTALLED. *PE
Component : SEAT BELTS:FRONT:RETRACTOR
Summary :
Component : SERVICE BRAKES, HYDRAULIC
Summary :
Service Bulletin Number : SIB-36-05-07 Date of Bulletin : DEC 01, 2007
NHTSA Item Number : 10032988
Component : TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
Summary :
BMW: TIRE WARNING LIGHT ILLUMINATED DUE TO LOW AMBIENT TEMPERATURE. MODEL E90, E91(3 SERIES);E92, E92 (3 SERIES); E60 (5 SERIES); E60 (M5); E63, E64 (6 SERIES); E63, E64 (M6); E65, E66 (7 SERIES); E70 (X5); E83 (X3); AND E85, E86 (Z4). *PE
HTML code is Off
