Incorrect exhaust fluid - No start in 200 miles. - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 04-30-2019, 10:32 PM
ard ard is offline
Resident Curmudgeon
Live and die by paperwork. Had you jotted down on the work order what your understanding was, then that could be used to support a contested charge. AGree with trying to use the CC.
Good luck. ****ty dealer, BMWNA being totally unhelpful. Shocker
Edit to add:
Talk to a tuner that has been working on coding DDEs. Dealers and BMW may not be able (willing) to do what a tuner can do. I **strongly** suggest this. Not sure they CAN, but worth a shot.
GL
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 05-01-2019, 01:12 PM
Quest3300 Quest3300 is offline
Mein Auto:
Edit to add:
GL
Thanks for the advice. I'm going to search for a tuner now.
Old 05-02-2019, 11:34 AM
n00bkiller944 n00bkiller944 is offline
Mein Auto:
How much is BMW charging to replace the DDE?
Old 05-02-2019, 11:36 AM
Mein Auto:
$2,700 before taxes and fees.
Old 05-04-2019, 08:12 AM
listerone listerone is offline
Oil Burners Rule!
Mein Auto: 2018 540d
Hi,Quest...just stumbled upon this thread and although I haven't read all the posts I think I have an idea of what's going on. I could very well be wrong here but the thing that just occurred to me is a Federal law that provides for a long (7 years,100,000 miles comes to my mind) factory warranty on emissions related repairs. I live in a "California emissions" state which,IIRC,provides for such a mandatory extended warranty.I'm not entirely sure that it applies in all 50 states.
Has this,by chance,been considered? It just *might* be worth a try.
Current: 2018 540d / Sapphire Black Metallic
Formerly: 2014 328d / Mineral Grey Metallic
Formerly: 2011 MB E350 Bluetec / Palladium Silver
Formerly: 2009 335d / Monaco Blue
Fuelly
Old 05-04-2019, 08:31 AM
Mein Auto:
Unfortunately I have 5 years and 128k+ miles. Thanks for the advice.
Old 05-07-2019, 07:35 PM
ard ard is offline
Resident Curmudgeon
Good point, the ECU is listed under the federal warranty to 8/80k.
Not a help to the OP, but to clarify...
(CA has a 7/70k that includes MANY more parts than the 3 in the federal warranty.)
Old 05-08-2019, 07:56 AM
Mein Auto:
Keep us updated on what you end up doing!
Old 05-08-2019, 08:17 AM
Mein Auto:
At the moment I'm searching for someone that can reset the DDE. I'm having no luck.
Old 05-14-2019, 06:15 PM
Renovator Renovator is offline
Mein Auto: E70 35d
If you're still jambed up, PM me.
I have an outfit I plan to use If my last/next attempt to remove the 'Incorrect Fluid' message fails.
(Since I have not already paid for their service, I'd rather not post in the open, until then.)
______
Yes, I'm sure he's had trouble finding help. I've had dealer service writers deny that they flash the ecu.
I've had indies squirm at the thought with the countdown. The tuners I talk with, are in the delete bidness, and didn't provide a service for just the ecu and cas.
______
I'll throw this out:
There are folks selling both front sensors as a fixit pair. In theory, no problemo. The narrative is... the probe and controls are the same.
The front cable is 500 mm longer. Over twice the rear's length.
The control pack attaches to the tunnel wall ABOVE the aluminum alloy heat shield.
The cable passes under/between the two heat shields on it's way to the attachment point. Right next to the drive shaft.
One would need to be diligent. Real diligent, to be sure that extra 20 inches was properly stowed. It's real tough to see beyond the heat shields as they're about to be secured.
The heat shields overlap, and the cable makes an S bend to head rearward.
_____
My forward heat shield was molested. The car had been dealer serviced by the previous owner.
That shield was mangled and pressed against the exhaust pipe. Missing fasteners.
Old 05-21-2019, 02:06 PM
Mein Auto:
Any update?
HTML code is Off
Similar Threads
Evolution Racewerks B46 Downpipe Now Available! ***NEW PRODUCT*** [email protected] F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 3 11-04-2018 07:28 PM
DPF "needs replaced"... for $5,900... at 65k miles disillusioned X5 E70 (2007 - 2013) 16 08-04-2018 03:34 PM
335D diesel exhaust fluid incorrect - need new DDE? mav91 E90/E91/E92/E93 (2006 - 2013) 9 08-01-2018 02:57 PM
Service info needed for 60k mile interval Maximus 3 Series & 4 Series 5 04-04-2004 05:53 PM
