Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 16 - Bimmerfest - BMW Forums
Old 05-06-2019, 03:01 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by snow1 View Post
I used to use Launcher Pro, but can not upgrade it and getting Tokenmaster to reply to anything is worse than pulling teeth. He originally sent me the files to get up and running, but now it looks like a online login, and he is not replying. How do I contact Tony about Rearm?
Post question in Rearm Script thread on F30post or send him a PM.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 05-06-2019, 07:06 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
I have run the Rearm script after setting the date back and before installing Launcher Premium and running it. Launcher works fine runs E-Sys connects to the car via Vin, lets me read FA, SVT, and read code and edit, save the code and code it back, No Errors. However, it is not actually wring to the car, because when I do it again, it is back to original setting. I have tried several times. I am sure there is some cockpit pilot problem, but I do not know what. The only strange thing is that E-Sys never asks for the pin I assigned in Launcher, at any point.
If E-sys asks for PIN, you did something wrong.
Are you sure you are using "Code FDL?"
Old 05-06-2019, 07:23 PM
snow1 snow1 is offline
Mein Auto:
Yes, I used Code FDL, but it just doesnít take. No errors.
Old 05-06-2019, 11:01 PM
Almaretto's Avatar
Super Moderator
Maybe you are coding outside acceptable range.
Old 05-07-2019, 12:03 PM
Mein Auto:
Please explain? I have changed this same option a few years ago when I had Launcher Pro.
If out of range, how do I put it in range?
Old 05-07-2019, 08:20 PM
Almaretto's Avatar
Super Moderator
If you changed before, then unlikely out of range.
You can check storage info for details; basically, E-sys will not allow you to set values outside set parameters.
Old 05-12-2019, 09:55 AM
aoch88 aoch88 is offline
Mein Auto: BMW F10 LCI
Tokenmaster is giving out Launcher PRO 2.8.2
Anyone tried and if it works? I couldn't seem to get it running on mine.
Old 05-12-2019, 10:26 AM
Mein Auto:
Working perfect for me.
Old 05-12-2019, 10:39 AM
I added the token and keyed in password, activation code but when I click Launch, it just disappears without E-sys popping up.
I've used E-sys with launcher many times before, never had this problem in the past.
Old 05-12-2019, 10:41 AM
I added the token and keyed in password, activation code but when I click Launch, it just disappears without E-sys popg up.
If you have Win 10 Build 1809, you must upgrade it.
Old 05-12-2019, 11:24 AM
Mein Auto:
I had the same problem, then I ran it by right mouse clicking on it and choosing ďrun as administratorĒ.
Old 05-22-2019, 06:08 AM
a.vl.romanov a.vl.romanov is offline
Mein Auto:
Good day! Tell me please. When opening an FDL coding attempt in all blocks, an "true ()" error occurs
According to the logo files, the maximum java memory is 4 GB. Last date, although I have tried others. E-sys tried both 3.27 and 3.33. I tried on different cars.
Maybe someone knows what the problem is?
Old 05-22-2019, 11:46 AM
I see only normal display of active condition, which is used by the coding Boolean Logic. Where is the actual error / problem you mention?
Old 05-23-2019, 01:11 AM
Mein Auto:
The problem is that the folder does not open!
Old 05-23-2019, 01:12 AM
Mein Auto:
Old 05-23-2019, 06:33 AM
It is not supposed to open. Codings are under Funktionen not Aktivbedingung.
Old 05-29-2019, 02:11 AM
Mein Auto:
For sure! excuse me:***1087;***1072;***1083;***1077;***1094; ***1074;***1074;***1077;***1088;***1093;:: ***1059;***1095;:
Old 06-17-2019, 10:30 PM
joako joako is offline
Mein Auto: Car
I have working ISTA/D Rheingold 3.56.14 (directly) and E-SYS 3.28.1 (Vmware) with Launcher Premium 2.6.2.124. Both changed with an appropriate Psdzdata for my car's i-step.
Any reason to change to the newest versions? I never figure out anything about the easy coding guidance and the entire launcher thing seems like some confusing drama.
Old 06-17-2019, 10:31 PM
Mein Auto: Car
Old 06-18-2019, 10:36 PM
Almaretto's Avatar
Super Moderator
ISTA+: Depends on to what cars you are connecting. If newer models, update is recommended/needed. If not, no.
E-sys 3.28 is junk. I use 3.27.1 (mostly) and 3.33.4_x64.
Should at least use Launcher Pro 2.8. If connecting to G-series, you want Pro 3.4.
Old 06-29-2019, 04:40 AM
S5csimon10425 S5csimon10425 is offline
Mein Auto:
Iím running ISTA+ from Rheingold USA. Looks like they shut down. Anyone know if itís worth it for me to upgrade? Itís for a 2011 135i. Also, anyone have links for ISTA-P?
Thanks!
Old 07-27-2019, 08:33 AM
Cisquo Cisquo is offline
Mein Auto: X4 M40i
Hello,
Anyone knows the PsdzData I must use for the new G20 serie ?
Old 07-27-2019, 08:36 AM
Mein Auto: X4 M40i
I answer myself : it's S18A
Old 07-31-2019, 02:40 AM
Almaretto's Avatar
Super Moderator
Originally Posted by Cisquo View Post
Hello,
PSDzData is not divided by targets.
Old 08-02-2019, 08:11 PM
mochoukri mochoukri is offline
Mein Auto: X5 F15
Esys Launcher error message
Hi Guys,
when i start the esys launcher pro i get the following error:
E-SYS LAUNCHER ERROR
LOADING E-SYS LAUNCHER PSDZ API MODULE FAILED!
ERROR : C:/PROGRAMDATA/TOKENMASTER/E-SYS LAUNCHER PRO/BIN/PSDZAPI.DLL : CAN'T FIND DEPENDENT LIBRARIES
Anyone knows what this means?
Thanks in advance
