What did you do to your E83 X3 today? - Page 3 - Bimmerfest - BMW Forums
Old 06-17-2018, 06:21 AM
Not1Clue's Avatar
Not1Clue Not1Clue is offline
Bluebirds fan in USA
Mein Auto: '05 X3 & '03 530i
Originally Posted by abscate View Post
See thread triad of death started by me...touch user name and then ď find all threads started by abscateĒ
After coffee Iíll stick link in my post
Found it Good to know in case I have that issue.
Originally Posted by tsuintx View Post
Cheaper, for sure, but letís see how long it lasts.
I know. I've heard this "fix" usually lasts 6-12 months. I applied a clear coat so I'll see if that makes it last longer.
Old 06-17-2018, 11:59 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Few questions;
Can the GUIBO and CSB be checked without removing all the components, exhaust etc. I want to look at the two items to see their condition. Lately I've found my driveline seems to have a lot of slack in it..
The small transfer case plastic gear is it worthwhile to replace that preventatively?
Old 06-17-2018, 12:38 PM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i, 2005 X3
You can unfasten the heat shields and bend them enough to check things out. The plastic gear isn't terribly hard to replace, but having it fail isn't particularly disabling, so I would just wait to it fail. It is probably worth having one on hand.
Old 06-17-2018, 05:16 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
6 to 12 mos is about right I did mine about a week ago...turned out really nice...i keep looking at them...cant believe how well they turned out (used the same product) before that 12 mos I used the 3M stuff...it turned out ok. bottom line the more solar exposure the quicker that yellow tent returns.
Sent from my SM-J727T using Bimmerfest mobile app
[FONT="Arial Black"]
Old 06-17-2018, 05:27 PM
BeeemerBro
I was just in there 4 weeks ago *rear drive shaft replacement. I took every thing out exhaust heatsheild rear drive shaft...and that too was my question should I replace the gear...after posing the question to the forum...i decided to leave it alone and change it when it fails and I got one (gear) in the trunk when it does.
Old 06-17-2018, 06:23 PM
H F H F is offline
Mein Auto: 2005 545i
Can you share the source with us where you purchased the gear ? I think its a good idea to have one on hand , for a quick repair when it strips out ..
Old 06-17-2018, 06:30 PM
BeeemerBro
Good ol ebay
Old 06-17-2018, 06:36 PM
H F H F is offline
Good ol ebay
Attachment 802088
Oh nice ... Thank you Sir!
Old 06-17-2018, 06:41 PM
BeeemerBro
ok...NP...but you gotta drop the Sir...
you can do a search...there are others that were cheaper in cost.
Old 06-18-2018, 12:04 AM
H F H F is offline
Ive heard that there is a carbon fiber reinforced nylon gear . I just haven't looked into it . But now my daughter in law has a x3 and ill be keeping up the maintenance . So I need to be ready for that if the time comes .
Old 06-18-2018, 06:18 AM
tsuintx tsuintx is offline
Mein Auto: 99 R1100RT
Clear will probably help somewhat. I used a 3-step $20+ 3M kit on my daughterís 05 MB about six months ago and the result was awesome and they still look like brand new. Will be interesting to see how long that will last. Luckily she has parking under the building at her new apartment, so the Texas sun shouldn not be able to kill them too fast.
99 BMW R1100RT
Official mechanic of my daughter's 06 X3 (Chronicled here.)
Plus a bunch of others...
Old 06-18-2018, 10:18 AM
dirtx dirtx is offline
Mein Auto: e83 x3,e30 325E, 1100RS
New front driveshaft
Just installed new front driveshaft. and new bolts. This is the first of the drivetrain reoairs I'll be doing. next week I'll change out f/r diff fluid, transfer case fluild. Maybee put servo gear in, not shure yet. Then rear driveshaft someday rebuild transfer case. Its got about 4 degrees of play in it.
My pocket book will have to take a rest before I do that job!
Old 06-18-2018, 06:11 PM
Gents, if I plan on replacing my eccentric shaft sensor I'll be doing the valve cover.
Anything else that should be replaced while there? I've already addressed the spark plugs.
My cart contains the following;
BMW Valvetronic Shaft Sensor Gasket
BMW Valvetronic Eccentric Shaft Sensor - VDO
BMW Eccentric Shaft Actuator Seal - Rein
BMW Valve Cover Gasket Set - Genuine BMW
Anything I may be missing?
Old 06-18-2018, 06:44 PM
dukedkt442 dukedkt442 is offline
Mein Auto: X3, 442, S15, F150
Valvetronic/mechatronic (whatever it's called) motor seal (between coils 3 and 4).
Over 100k, I'd replace all coils rather than wait for a failure, but that's me.
Old 06-18-2018, 06:49 PM
Isnít that this here?
Old 06-19-2018, 05:58 PM
BeeemerBro
Installed new Sylvania headlight bulbs in the 05 makes a big difference then those chinese brand I used.
Old 06-19-2018, 06:27 PM
I dunno, is it? Descriptions are suspect... I'm talking about the seal for the motor. If you have it,
Old 06-20-2018, 12:59 PM
Yes thatís the one.
Old 06-22-2018, 01:45 AM
darknmy darknmy is offline
Mein Auto: 04' X3 3.0i
I thought I'd share it here:
I checked my tire pressure today.
front 2.4bar
rear 2.2bar
I confirmed my theory - now both tires are at even height and the xdrive feels smoother.
Old 06-22-2018, 07:08 AM
front 2.4bar
rear 2.2bar
Whats your theory?
Old 06-22-2018, 04:09 PM
Today I ordered spark plug for my X3. No, I am not Russian, I ordered one, because I forgot to change qty to 6.
Its a good thing something else will break soon and I can make another order of 4.
And wait until the order after that to order the remaining one?
Old 06-22-2018, 05:18 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Number 4 spark plug symbol of death. Never touch that plug
Old 06-22-2018, 06:15 PM
Esidelito Esidelito is offline
Mein Auto: 06 BMW X3 3.0I E83 Sport
Damage sensors & condenser :/
Shall we begin today on my way to work I hit a huge pothole
passing a construction ZONE it is GRIDLOCK hour so you have to be fast,
to swerve Downtown Brooklyn NYC this is very weird because I expected
for s strut or shock, even a bent rim but (NO) took it to my Mechanic
now my goddam A/C Condenser is leaking needs to be replaced
not to mention my upstream and downstream 02 oxygen sensors
are also faulty as well the story of my life... good day to you all.
Old 06-22-2018, 06:17 PM
LMFAO I know the feeling and struggle mane, you fix one item days or weeks later here comes another...
Old 06-23-2018, 04:06 AM
BeeemerBro
But you can catch up, and when you do...man how sweet it is!
