What did you do to your E83 X3 today? - Page 5 - Bimmerfest - BMW Forums
Old 08-20-2018, 01:52 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
Replaced compressor, condenser and belts...cleaned off radiator for the 05 I'll bleed in antifreeze later on.
Sent from my SM-J727T using Bimmerfest mobile app
[FONT="Arial Black"]
Old 08-20-2018, 08:25 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
We expect you back to work at 0755 - those five minutes to login are on YOUR time, not the company.
Old 08-20-2018, 08:41 AM
mitch500 mitch500 is offline
Mein Auto: 1997 e36 m3 s54
Well I would hate to work for you.
Old 08-20-2018, 09:26 AM
You wouldn't actually.
100% match on the 401k up to the Federal limit, not some fraction of your salary
Paid first class travel over 4 hours.
Your manager reviews your travel and expenses, and Finance writes a check. We advance your travel costs each month, and reconcile end of month.
Sales gets paid on booking a clean order. Thats when you have done all the hard work of getting commitment, and thats when I want you to get the reward.
Three tiers of performance review, and if your manager can't move you into the top tier of performance in three quarters, s/he loses their bonus.
The best part of pinhead corporate America is how easy it is to take their best people.
Old 08-24-2018, 03:09 AM
BeeemerBro
Transmission oil cooler popped off...lost coolent...now I have to replace the coolent and seals this morning...the fix should be easy. Can you believe that only the wire latch holds that cooler on.?..but I think there is suction too right? to keep the fitting tight?
Old 08-24-2018, 06:06 PM
tsuintx tsuintx is offline
Mein Auto: 06 325i and 99 R1100RT
Today it was time for the rear pads/rotors/sensor. About 120 bucks for everything from RockAuto. Can't beat that. Passenger side had just started to go metal on metal, so I guess it was about time.
Also cleared the lean codes (P0171/174 or 2882/2883) once again. Poked around a little bit in the engine bay but still can't find any noticeable vacuum leaks, so the search continues.
06 325i
99 BMW R1100RT
Official mechanic of my daughter's 06 X3 (Chronicled here.)
Plus a bunch of others...
Old 08-24-2018, 07:25 PM
I'm having lean codes as well, they only pop up on long highway drives. I've replaced all ccv system, gaskets from intake manifold up and have smoke tested and confirmed no vacuum leaks.
Have you smoke tested for vac leaks? I'm pretty sure at 200,000kms on mine it's fair to say I'll be doing complete o2 refresh soon.
Old 08-25-2018, 11:13 AM
Nah... Havenít smoke tested. Been pushing it out, but probably need to do it ome of these days. The codes are intermittent and after reset they can be gone for weeks at a time and sometiems they come back within just a few days.
Just need my daughter to drop it off for a few days at some point when it finally cools down around here. Hate working on crap when itís 100-something degrees outside like yesterday when I did the brakes.
06 325i
99 BMW R1100RT
Old 08-25-2018, 02:54 PM
swampX3 swampX3 is offline
Mein Auto: bmw++many
lots of lame/false codes are down to software
>software inadequacies in this one/programming with the maxi also covered
BMW individual module programming using Autel MaxiSys MS908P.
Thx for the vŪdeo luis, it may be a stupid question but here it goes what sort of situation would have to programme a car module...***65279;
1
LM Auto Repairs
44 minutes ago
Hi
I give you an example...
My 7 series, had for a long time a fault with one of the airbag modules... would come up with something like internal failure...
Clear the the codes, would last for days, sometimes weeks and even months....
Has been doing it for 2 years... I was too lazy to reprogram it...
But finally done it around Christmas last year... no issues ever since...
This is just an example... the manufacturer sometimes releases updates to rectify or improve deliverability etc...
Thank you for watching!***65279;
Old 08-26-2018, 05:35 PM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Installed a new GUIBO, CSB and did an Oil Change. While down there I also opened up my actuator to inspect my wheel and it was superb compared to the ones I've seen online. Since I had another one on hand I replaced it anyways. The CSB and GUIBO took days due to the rusted bolts on the exhaust below..
Last weekend was Eccentric Sensor and Valve cover gasket. I am totally exhausted.
Old 08-26-2018, 06:05 PM
BeeemerBro
Took 04 on a trip to Atl to drop the wife off at the train station...drove back and revived 05 armrest it was tired and had blemishes brung it back to life. see pics...looks like I need some.sort of permission to attach pics...now I'm tired
Old 08-29-2018, 12:25 AM
BeeemerBro
Before/AfterClick image for larger version
ID:	815689Click image for larger version
Old 08-29-2018, 01:04 PM
how to attach pics/pdfs etc etc
follow the pics below
>click on the paper clip
>only load one thing at a time from the panel in the second picture below ....this panel will pop up when you click on the paper clip.....you will see "choose file" radio button you can use to load stuff
>follow the guidelines for max file size
>navigate to where your pics/etc are on your computer......putting them easily accessible on the desktop is good
>click on the upload radio button and wait a few seconds for them to spring into you bimmerfest post.....you will see the panel etc pop a bit
>then rinse and repeat for the next picture/screen shot etc etc etc
>if you mess up and want to add/delete anything simply edit your post and take the extra click of "GO ADVANCED".....like in pic number 3 below.....this will enable the full edit of the subject line and attachments
>good work on the arm rest
Name:	Screen Shot 2018-08-29 at 1.55.00 PM.png
ID:	815785   Click image for larger version
Name:	Screen Shot 2018-08-29 at 1.55.21 PM.png
ID:	815787   Click image for larger version
Name:	Screen Shot 2018-08-29 at 3.56.47 PM.png
Old 08-29-2018, 02:53 PM
CoolShirtDude CoolShirtDude is offline
Mein Auto: 2011 BMW X3 2.8i F25 N52
Before/AfterAttachment 815689Attachment 815691
This looks really good, what did you use?
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 08-30-2018, 04:42 AM
Genuine Germano child tears in a bottle
Part number bmw-666
Old 08-30-2018, 04:44 PM
Cheap BMW Door Pull Handle Restoration!
good tips on getting generic bmw door parts apart too
Name:	Screen Shot 2018-08-30 at 5.42.34 PM.jpg
Old 09-01-2018, 09:13 AM
BeeemerBro
Thanks I almost always post using the phone
Old 09-03-2018, 06:40 PM
HDTF614 HDTF614 is offline
Mein Auto: Camaro SS
Had a productive week! Replaced driveshaft support bearing and realigned driveshaft, replaced the CCV hoses and collector, replaced front speakers, replaced hatch emblem, touched up lots of rock chips, cleaned out sunroof drains. Car is getting a little better everyday!
Old 09-11-2018, 10:38 PM
Josan Josan is offline
Mein Auto:
Bought my X3 this past weekend and started to look for things to do.
yesterday, I found these wheels on Craigslist, price seemed good to me and put them on. They are Style 594s from 2010 X6, 19" wheels tires 255/50/19. I really like the way it looks compared to the 17" stock wheels. Unfortunately the tires rub a little on the wheel well plastic when I turn hard on the steering wheel. I have 2 options 1- cut some of that plastic off, and save me some money(tires are 95% new) or 2-suck it up and but smaller tires probably 245/45/19 all around.
Also took it to dealer to get some recalls done for the pcv valve replacement and also for seat mat, which will have to wait until part arrive.
ID:	818029   Click image for larger version
Old 09-16-2018, 04:47 PM
BeeemerBro
For both 04 and 05 installed new belts also for 04 changed out interior light bulbs to bright white bulbs leds?
Old 09-16-2018, 05:21 PM
My daughter got married today and I got her X for the next week while they're honeymooning in Aruba. Don't think there's too much I need to do, but guess I'll have to wait and see what I can find... Looks loke even the SES light hasn't reappeared since the last time I cleared it a few weeks ago.
06 325i
99 BMW R1100RT
Old 09-19-2018, 02:29 AM
BeeemerBro
Rear diff fluid changed on 05 used redline added in valvoline...75w90 chatter gone...getting back to its smooth self.
05 X3 181k
04 X3 162k
Old 09-27-2018, 06:42 PM
Mein Auto:
New Pioneer subwoofers under seat
After changing door speakers (alpine SPS-410s) today I went ahead and also changed the under seat subwoofers.
I went with 8" Pioneer TS-SW2002D2. which sound great and much cheaper than the BavSound and earthquake subs.
Old 09-28-2018, 03:34 AM
Dropped 4 liters of ATF out and refreshed. Got Valvoline Max life for under $5 aliter onAmazon , in the gallonjugs.
Elapsed time 45 minutes!
Technique...gray transmission funnel tied to roof rail, hose snaked into fill port.
T45 for drain. 17 mm hex for fill
Last drain and fill in summer 2016, fluid red brown.
Old 09-28-2018, 04:10 AM
BeeemerBro
Let me see if I envision this you say above.
a funnel and hose is attached to the roof rail (passenger side?). you've snaked the hose to the tranny fill plug?
The car was on jacks?
You started with a cold car no doubt?
at this point chances are you were looking to get the most fluid drained out which was 5 litres?
At this point you were able to put in the same amount of fluid you removed?
Was there any starting and stopping the engine?
And finally, you know when your finished when you've returned the same amount of fluid that you've removed?
Is that all? any other tips tricks...and you were successful no doubt? Any major spillage? you used a clear hose?
