F30 Stripped Oil Drain Plug - Bimmerfest - BMW Forums
Old 03-30-2019, 10:00 PM
JWYer JWYer is offline
Mein Auto:
Last week, I changed my F30 328i xDrive's engine oil. When I put the oil drain plug in, I over tightened and stripped it. (I believe the oil pan is stripped, because steel bot on aluminum pan.) A little oil was constantly dripping from it for a week. I was going to tap the oil pan one size bigger today. I spent some time trying to pull and turn the drain plug out with a vice grip, but the plug just spin freely in place. I couldn't pull on it hard since I was laying down in a tight space. I consider drilling the bolt out, but drilling in the tight space under the car sucks, and metal chips will get into the pan. I try to avoid removing the pan if I can. Here are a few questions:
1. What do you think is the easiest way to remove the free spinning drain plug?
1. How easy/complicated is it to remove the oil pan?
2. When does the low engine oil warning come up? (The car has been dripping oil slowly for a week and still showing max oil every time I measured it.)
I appreciate any comment.
Old 03-30-2019, 11:57 PM
dkreidel's Avatar
dkreidel dkreidel is offline
Aviator
Mein Auto: cars with studded tires
Here's what I'd do:
Get a helper to put pressure under the plug 180* apart with 2 sharp screwdrivers or knives while you turn the drain bolt CCW
Let the oil drain, and the install a helicoil or tapsert in the pan ... same thread as OE! Are you certain the pan is aluminum or magnesium and not plastic like Ryton?
Get a new drain plug and reinstall with a torque wrench
'18 440xi Vert Individual Dinan Stage 2 ED #17 Oct '17
...and a bunch of old English motorcycles
Old 03-31-2019, 02:48 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Once the drain plug is leak tight then consider evacuating the oil from the topside with a vacuum pump. VW's have notoriously fragile oil pans and after the first time I never again loosened the plug, always sucked the oil out the dipstick tube.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 03-31-2019, 06:41 AM
Michael Schott Michael Schott is online now
Super Moderator
Mein Auto: 2017 VW GTI Sport MT
Where do you get your information that VWs have fragile oil pans? Thats a very broad statement.
Old 03-31-2019, 06:56 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
How do you suction from the top without a dipstick tube?
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 03-31-2019, 07:14 AM
Mein Auto:
Originally Posted by dkreidel View Post
Here's what I'd do:
I looked up parts online, 2016 328i xdrive has aluminum pan.
They are lots of covers under the car. The cutout on the cover for drain plug is small, which makes it hard to pry. I wish the car can be lift up higher so I don't have to crawl under it. Getting the plug out is a nightmare. Once the plug is removed, I can tap it.
Old 03-31-2019, 07:18 AM
Mein Auto:
The only place I am thinking is the oil cap. However that doesn't provide a straight path to the bottom of the oil pan, I doubt that would work.
Similar Threads
New! F80/F82/F83 M3/M4 Baffled Oil Catch Can And Drain System! ECSTuning Site Sponsors & Bimmerfest Group Buys 0 10-30-2018 10:47 AM
Qusetion about switching to synthetic oil... PeteG E36/7 Z3 (1996-2002) 13 10-20-2004 08:29 PM
S54 oil pan drain plug Ron Stygar E36/7 Z3 (1996-2002) 3 08-02-2004 12:55 PM
Oil Filter Removal Question JPinTO General BMW Questions 34 08-13-2002 04:41 PM
