N63 engine recall - Page 82 - Bimmerfest - BMW Forums
Old 04-12-2019, 12:14 PM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Originally Posted by bmwm42 View Post
yes there is a core charge
Yep motor is around $3000 and so is the core charge $3000
'14 X6 i50 - Deep Sea Blue Matallic
'07 650i Coupe - Black Sapphire Metallic
'11 328i Sedan - Alpine White
Old 04-12-2019, 08:17 PM
Pookie7 Pookie7 is offline
Mein Auto: 08 328i
So my car barely passed the consumption test, after reviewing some sort of checklist they got approval to replace the valve seals. I guess that's good news, the bad news is they said theres minor oil leaks from oil pan and real main seal?
Do they drop the engine to the valve stems?? What other gaskets gets removed to get to the valve stem seals?
I assume if they remove something that has a gasket on to do a repair they will put a fresh gasket or seal when putting it back
Old 04-13-2019, 03:52 AM
veery veery is offline
Mein Auto: 2011 328xi; 2007 X3
With the proper tool, they will pull the valve covers and change out the seals from the top.
Old 04-17-2019, 03:31 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Hey guys. Is there a link where a BMW VIN can be entered to check on eligibility for the N63 CCP? I have a buddy interested in a 2012 F01 But he wants to see if the work has been performed or eligible if not.
Old 04-18-2019, 03:47 PM
Mein Auto: 08 328i
You can call a dealership and provide the last 8 digits of your Vin and they should be able to tell you.
I just picked mine up from the dealer they replaced the valve stem seals and oil separators at no cost as per the settlement.
The SA called me and said the technician took the car out for a drive to make sure all is good and he heard some noise, he then diagnosed the noise and found that the rear left spring is cracked and that would be around $1050 to replace and they recommend I replace both sides. I was just excited to get the car and I never heard any weird noise before, I thought they're just trying to milk me. I picked the car up and drove home and I heard all kinds of noises I never heard before since I got the car, I mean when I go over bump it sounds like theres a guy in the trunk playing a ****ing mandolin. So weird I absolutely never heard such noises before I dropped the car off.
All I can think of is maybe it was cracked and being on a lift with some pressure relieved off the spring made it move or something and now it makes weird noises.
Old 04-25-2019, 04:34 AM
Profesor Profesor is offline
Mein Auto:
I could not have asked for better service
All,
About 7 months ago, I purchased a 2013 550I from Florida (I live in North Carolina). The purchase was from a BMW dealership where a friend of mine works, and the car was taken in on trade. The odometer was sitting at roughly 86,000 miles. When the car arrives, I drive it off the truck and take it for a test drive. Literally, within 1/4 mile, the car stalls and I pull to the side of the road. I try to start it, and it is clear that the engine is seized (I was a mechanic before I became a Professor). Oil is leaking on the road in a fairly large quantity.
I call BMW customer care and they send out a tow truck to haul it to a dealership. A few days later, I get a call from my service advisor that the engine threw a rod through the side of the block. He had good news for me though... BMW will not only replace the engine and all associated parts which received oil circulated through the engine (turbos, oil cooler, etc.), but they would provide me a rental car.
I go to the dealership to pick up the rental (a 2019 X3) and they tell me a new engine should arrive in about 3 months. 7 months later (day before yesterday) and $12,764 in rental car charges (paid for by BMW), I pick up my 550I and it appears to be absolutely perfect. The engine purrs like a kitten and everything is working as I would expect.
From my perspective, nicely done BMW.
Joe
Old 04-26-2019, 07:37 AM
Originally Posted by Profesor View Post
All,
Joe
A good story! Thanks for sharing the up-side!
Old 04-26-2019, 08:28 AM
TXSTYLE's Avatar
Joe. That is the BEST story I've heard EVER regarding this issue! That dealership is certainly a "model of customer support". Because as I've been told by BMW NA, they are NOT responsible for any rental or loan cars. It is up to the dealer.
Old 04-26-2019, 10:25 AM
Eagle11's Avatar
Eagle11 Eagle11 is offline
Mein Auto: 2017 330i
enough said
2017 330i, 475, KCL3, ZDA, ZPP, 2A5, 494, 4GA, 609, 6CP BMS JB tune and Many Coded goodies
2016 328xi GT, A86, LCOM, ZDA, ZDH, ZLP, ZPP, ZTP, 494, 5AC, 5DF, 5DL, BMS Stage 1, Many coded goodies. ED 8-28-2015 Gone
Old 04-28-2019, 10:20 AM
Jfierro Jfierro is offline
Mein Auto: 550i GT & Z3
oil consumption after valve stem seals replacement
Good morning,
I had my valve stem seals replacement done December 2018. Since then my 550iGT with 59K miles has been running strong. However, yesterday, I checked the oil and it is low again, perhaps 1/2 a quarter needed. I have put roughly 5k miles since the valve stem seals replacement service with no issues whatsoever. Anyone else experiencing this? Is this considered new "normal" for oil consumption?
Thanks,
Jfierro
Old 04-28-2019, 09:34 PM
ard ard is offline
Resident Curmudgeon
Originally Posted by Jfierro View Post
Good morning,
Thanks,
Jfierro
1 quart per 10,000 miles is fine ("1/2 quarter needed...5k miles since")
This is, apparently, YOUR new normal.
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 04-29-2019, 08:57 AM
Thanks.
Old 05-13-2019, 01:17 PM
heymattw heymattw is offline
Mein Auto:
Hi, just found this forum and thought I would share my experience.
On January 12th of this year I purchased a 2011 X5 50i with 74k miles on it from a local (non BMW) dealership with an after market warranty from the dealership. It was also "dealer certified" to their standards.
On January 13th I dropped the vehicle back off to the dealership because of a lot of smoke. They claimed it was a bad turbo and fixed it in 26 days.
Three days after it was fixed I still noticed an oil burning smell so I swung by the dealer, they told me it was just oil burning off the manifold from the turbo replacement. I didn't agree, but whatever.
Three days after that the motor blew. This was late February. I have since been making payments, paying insurance, and paying for an additional warranty.
Dealership I purchased it from ordered the motor from a local BMW dealership. I have not seen the car since then. The dealership has given me a 2014 3 series loaner, but I'm getting pretty anxious for my car.
Everyone points their fingers at BMW USA, but they cannot give me any answers. This has been a very disappointing experience. I feel like I should have done some more research before buying.
Old 05-14-2019, 07:41 AM
Eagle11's Avatar
Ding Ding Ding....... Don't get mad at BMWNA, sounds like this is a learning lesson to investigate before purchasing.
Old 05-14-2019, 09:16 AM
Steveseidl322 Steveseidl322 is offline
Mein Auto: 2014 Space Grey 550i
Purchased a 2014 550i February 2019 w/36000 miles. I liked this car's performance, comfort, size, and amenities. Built in June of 2014 this car has the N63TU engine, and I assumed that the many changes made to this engine had alleviated the "oil burn" problem suffered by the original N63 design.
This car has burned 4 quarts of oil in 5,000 miles... it runs strong, has no outward signs of oil consumption such as smoking, or fouled plugs. There are no visible signs of leaks, nor any hesitation during acceleration or de acceleration.
As far as due diligence "ding,ding,ding" in researching a purchase... a used $77,000.00 automobile (when new) with 36000 miles should be reasonably relied upon to provide adequate and reasonable service.
These automobiles, if these problems were widely reported on in the main stream media would be relegated to " junk" status, and their value would be in the toilet as well. BMW should perform a " recall"... not a Customer Care Program as they did for the original N63, and take ownership for the fiasco they've created and once and for all correct it....
Old 05-14-2019, 10:26 AM
celluloidheros1 celluloidheros1 is offline
Humble Mechanic
Mein Auto: 2013 X5 5.0
My Car had 97K when the deal did the valve stem seals. Now it has 107 and the car burned about 1 quart. It still smokes a bit but it is vastly improved. BMW snapped the tabs on the engine cool,king fan cowl. so when you get your car back look it over carefully. BMW didn't charge me too much.
Old 05-14-2019, 11:52 AM
Mein Auto:
No, took my point all wrong. The point is I will never own a BMW again because of the way they handled this as a company.
Old 05-14-2019, 12:18 PM
TXSTYLE's Avatar
That was the impression I got from your post, And I respect that.
Old 05-14-2019, 05:04 PM
ard ard is offline
Resident Curmudgeon
lol
The poster bought a USED car, 74k miles... a car model with a MASSIVE history of V8 issues...from "not a BMW dealer'
and he thinks he should have done more research into BMW as a company. And you respect that???
Name ONE car mfg that has never produced a car with issues, systemic issues. Further, on what planet is the mfg 'on the hook' for a car purchased 24k out of warranty? I guess he will no longer buy any car from anyone.
Old 05-15-2019, 02:08 PM
Eagle11's Avatar
Originally Posted by ard View Post
lol
Thank you!!!
Old 05-20-2019, 10:50 AM
Mulchman's Avatar
Mein Auto: '07 650i
DONE!!!!
Car died 3/3/19. Order was placed 3/14 from Bimmerzone. I was first in line at Faulkner BMW for an N63TU. Motor arrived 4/26. Installed by 5/3, then I left for vacation with several errors present. Came home last Sunday and got rid of my last error today.
Note - The cam followers are not installed in the new short block! You need to take the old one and install them in the new motor. This knowledge would have saved me a week of hassle and stress. The guy at the dealership parts counter this morning told me that they have had mechanics do the same thing, so I guess I don't feel too bad about it. Just happy to have my X6 back!
Thanks to all who contributed to this thread! Let me know if I can help, I did about 70% of this job myself.
Mulchman's Avatar
Mein Auto: '07 650i
DONE!!!!
Old 05-21-2019, 08:29 AM
Mein Auto:
lol
Sorry to not explain it all. I am not complaining about the warranty or the engine from BMW. I am complaining that the non BMW dealership has been trying to get their hands on an engine (and pay for it) with nothing but run around answers from BMW.
My case has nothing to do with a warranty or the fact that the part failed, I took that risk. The fact that they are not able to give me answers is what bothers me.
Old 05-22-2019, 05:20 AM
tim716 tim716 is offline
Mein Auto: 2011 550i
I documented my oil loss for 2 years which occurred every 600-800 miles. Finally the dealer repaired, but did not replace the engine. This was fine with me as the oil loss is gone completely and no white smoke from a warmed up engine.
Old 06-03-2019, 10:13 PM
Goran Goran is offline
Mein Auto:
Bmw 525
Hello everybody. Iam new here and iam new in the BMW world as well.
Unfortunatly i had a very bad start. I just bought a BMW 525 F10 from 2010 from Bulgaria (i wonder why i was so stupid to buy a car from there but....) anyways, i drove the car 400 km and before i get home the engine blocked. Car wouldnt start at all. What we found out at local service is that they have put something, very thick thing, in the engine and as I heard, they do it so the engine works very smooth for awhile, so they can cheat people like me to buy it
Every service i asked so far is telling me i need to replace that engine cause its not worthed to try to clean it or fix it etc ...
Although i find it very dificult to find another engine for the 525 model.
Any advices, previous experiences with this engines etc ... Please.
