Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 5 - Bimmerfest - BMW Forums
Old 01-05-2018, 03:12 PM
timmeketim timmeketim is offline
Mein Auto: F45 225xe
Hi,
I have another question about coding. My previous car (E91) has been "chip tuned" Most tuners act as if they tweak and tune all settings for your specific car. But I suspect them to just upload a different map to the motormanagement unit. But the results where fine: drove a lot better, more power and even less consumption.
But what is the main difference between "tuning" and "coding"? Both happen using OBDII interface. So can we also code engine parameters? (not that I want to change stuff there, except uploading an improved map if available)
I'm just wondering...
Old 01-05-2018, 05:01 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by timmeketim View Post
Hi,
Coding is adjusting parameters/settings within given software.
Tuning is changing firmware.
Old 01-13-2018, 03:20 AM
esferato esferato is offline
Mein Auto: BMW 530d GT xdrive
Hi guys,
what i'm doing wrong? all folders "."
Old 01-13-2018, 07:56 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by esferato View Post
Hi guys,
http://prntscr.com/hzu4j5
You have Trimmed PSdZData, which means either you do not use E-Sys Launcher PRO to open E-Sys, or E-Sys has Incorrect Target Connections, or this CAFD is not mapped in Launcher's CAFD Mapping Database.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-23-2018, 05:40 AM
Hello, which value need to change in E-sys to change inside trunk button to open trunk? Not it's open just that small hatch on my 2010 gran turismo. On key fob trunk button also open just small trunk and only diamond button opens big trunk any advise?
If possible...what I want is --> Key Fob trunk button open/close Big Trunk, Diamond Button (holding) opens small hatch. Inside button open/close big trunk.
Old 01-27-2018, 01:44 PM
Beowulf65's Avatar
Beowulf65 Beowulf65 is offline
Mein Auto: 435i xDrive Gran Coupé
E-sys Launcher Premium v2.8.0.143 Car Series Choice
I have just installed v2.8.0.143 and want to be sure that I choose the correct car series. I have an F36 (2016 435xi GC): do I still use F020 as in the previous launcher? Or is it now F036?
Old 01-27-2018, 01:49 PM
That is not correct.
E-Sys Launcher PREMIUM = F036 (AS IT HAS ALWAYS BEEN)
E-Sys Connection Target = F020
Old 01-27-2018, 01:55 PM
Beowulf65's Avatar
Thank you Shawn! I hadn't used it for awhile and appreciate the refresh.
Old 01-29-2018, 10:46 PM
Fodder540 Fodder540 is offline
Mein Auto: BMW 550i
A really odd one - Only one side affected
Ok guys, this one is damn peculiar. I'm coding the angel eyes to be fully bright with headlights on. 2015 F33. I tried the cheat sheet and additional hints from the forum but no luck.
I then found the info for changing both "Standlicht Modus 1" and "Standlicht Modus 2" in the two TMS entries:
00, 03, 00, 00, 64, 03, 00, 00, 64, 03, 00, 00, 2E, 04, 00, 00
Changing 2E to 64.
Here's the thing - only the passenger side gets brighter. I undid and redid the changes and still only the one side affected, both rings. Definitely did Modus 1 and 2, in both TMS. Also cycled the ignition stopping and restarting the car. Thoughts or ideas?
Old 01-31-2018, 02:40 AM
Hello,
is there are any coding to get lowercase letters to rename music folders? Only uppercase letters in my F07
Old 01-31-2018, 12:40 PM
iammarrk iammarrk is offline
Mein Auto: X
I'm a little confused about cheat sheets. Maybe someone can clarify.
Are they specific to specific chassis? If so, are there any for the G01?
Old 01-31-2018, 01:12 PM
There is no Gxx Cheat Sheet. Use builtin E-Sys Launcher Cheat codes, which are ECU specific.
Old 02-03-2018, 01:53 PM
pej7445 pej7445 is offline
Mein Auto: 2019 X3 m40i
I can edit FDL on all modules except for FRM. When I try to 'edit FDL' I get an error and cannot proceed.
Any suggestions?
Old 02-03-2018, 02:22 PM
Any suggestions?
"An error" is meaningless.
Maybe details of the Error might help someone out here help you?
Old 02-03-2018, 06:29 PM
Almaretto's Avatar
Super Moderator
Any suggestions?
Make sure you are using correct connection target and use E-sys 3.27.1.
Old 02-03-2018, 09:06 PM
Mein Auto: BMW 550i
Changing 2E to 64.
Guys - any ideas on this? Or do I just experiment with some of those other byte entries?
Old 02-03-2018, 09:10 PM
Almaretto's Avatar
Super Moderator
That is what you want.
Old 02-05-2018, 01:50 AM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
can somebody write xslt file for merging all FDL cheat codes? I have started learn XSLT but it will take me another 2 weeks
Old 02-05-2018, 10:34 AM
Almaretto's Avatar
Super Moderator
Why do you need to merge? They can already display at same time.
Old 02-06-2018, 04:00 AM
Curamrda's Avatar
Mein Auto: Fxx
to avoid the duplicity
Old 02-06-2018, 08:20 AM
Almaretto's Avatar
Super Moderator
There is some redundancy. That would be an impressive script to be able to automate merge.
Old 02-26-2018, 07:56 PM
Wyre08 Wyre08 is offline
Mein Auto: 2013 BMW 550i
So I'm having some issues. I installed new seats so I'm trying to VO code them. I'm following the "E-Sys - VO Coding Guide" and I can get to the Page 9 (the part where under SALAPA you can add 3 digit codes) and I'm afraid to put codes in. I've been reading the post below which has the 3 digit codes and I'm pretty sure I need to add one of these (711 4MA 459 456 <-My guess on the one I need) but I'm not sure which one. If I add the wrong one what will happen? And if I add the correct one is that all I need to do to reset the seats?
https://www.bimmerfest.com/forums/sho...d.php?t=966607
The seats I put in are the 18 way adjustable ones.
https://www.ebay.com/itm/272815116412?ul_noapp=true
Old 02-27-2018, 08:12 PM
Yobyot's Avatar
Yobyot Yobyot is offline
Mein Auto: Two G01a
Bummer...just bought a G01. I prefer "old school" coding, circa 2012. You have a cable, a VM running on a Mac, and a marked-up PDF with the changes you wanna make.
I get that some people might find integrated cheat sheets in eSys easier. I don't. Now, I have to download the XML, install it and manually find the codes from the description tags. Two-parters are gonna be especially cumbersome.
Just my $.02.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced 2018-08-15; Delivered 2018-08-22
Old 03-10-2018, 10:25 AM
Dannyb2711 Dannyb2711 is offline
Mein Auto: BMW f30
Hi sorry if I sound stupid . I've done very little coding and none on Bmw . I've a f30 2014 and want to code bluetooth streaming . Can I use my old ncs expert or INPA ?. Or even the lead I allready have for them sorry again if I'm far of the track. I went to the local Bmw dealer and they told me it was not possible this is why I'm seeking you kind gets help
Old 03-10-2018, 10:48 AM
For F30, you need an ENET Cable not K+DCAN Cable, and E-Sys & PSdZData, not NCS Expert and SP-Daten. PM sent.
