Noisy front X1 diff - Bimmerfest - BMW Forums
Old 02-21-2018, 10:11 PM
X1 owner X1 owner is offline
Mein Auto: BMW X1
Noisy front X1 diff
We have a BMW X1 2011 model, the front diff is very noisy!!
BMW Brisbane have confirmed its caput. $5600 to replace is their offering
Spoke to a diff specialist, he said that post 206 BMW moved to an inferior design, where they used roller bearings instead of tapered bearings. The roller bearings design is a flaw and is causing noisy diffs.
Needless to say that I am very unhappy.
Is anyone else having front diff issues?
Old 02-21-2018, 11:16 PM
0w40X1 0w40X1 is offline
Mein Auto: 2014 X1 s28i Msport
For that kind of money one could get a machinist to over haul with a better bearing.
In other words, fix the design defect.
Old 02-23-2018, 08:27 AM
4llr 4llr is offline
Mein Auto: BMW X1 2012
How many miles? Mine is at 100k kms, and I just changed diffs and transfer case oil. All good so far!
Old 02-24-2018, 04:24 AM
kevman2 kevman2 is offline
kevman2
Mein Auto: 2013 X1, 2007 Audi A4 vrt
Whats the symptoms of this? I have a slight rattle and get clicking sound on lower speed turns.
Old 04-11-2018, 09:20 PM
sweetpete59 sweetpete59 is offline
Mein Auto: 2013 BMW X1
have same issue on my 2013 x1 28i xdrive...inferior bearings in front differential....mechanic I know who works on Ferrari's, sez the "kit" is not available yet for BMW....BMW will install front differential with upgraded bearings for 5500.00 (so BMW knows about the problem)......
.....best is to buy the differential from BMW for 3100.00 & get your mechanic to install...if you install used, will have same problem.......
Old 04-14-2018, 01:58 PM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
what is the condition of the fluid? fluid level?
Old 05-08-2018, 06:33 AM
marcX1 marcX1 is offline
Send a message via ICQ to marcX1
Mein Auto: 2012 X1
That's where I would draw the line, considering a used 2011 would be around 9000$ to buy i would not spend 5600$ at a stealership to repair. If it was my car i would pick up a used diff at the wreckers, install it and roll the dice! or trade it back in to BMW and be like "what noise"?
Good luck,
Old 05-01-2019, 08:53 PM
latest on front differential problems is that there's an upgraded bearing available, seems can be installed by my shop all-in for 2000.00 cad
Old 05-02-2019, 10:53 AM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
FWIW, bad design or not, change the fluid on a regular schedule. My 2014 has NOT ever had the fluid changed. People don't think about these items when they think maintenance (some people don't even think much about engine oil, TBH......).
Not even sure if -40 degrees is cold anymore ?
front diff, loud, noisy bearings, x1 diff
