Warped rotors? - Bimmerfest - BMW Forums
Old 05-15-2019, 05:39 AM
535kjp 535kjp is offline
Mein Auto: 2011 535i XDrive
Warped rotors?
Hey all,
I have a 2018 330i with 6.5k miles on it. Began to realize that you hear the brakes rumbling between 65-80mph. It hasn't gotten to the extent that it shakes the entire car yet, so if the music is loud enough, it's not particularly noticeable.
Are warped rotors covered under warranty this early? I know BMW removed brakes/rotors from maintenance, but this doesn't seem like regular wear and tear to me. I generally don't do too much spirited driving, and don't slam on my brakes so I'm a bit confused
Old 05-15-2019, 07:17 AM
Doug Huffman's Avatar
Nuclear engineer
It is unlikely that YOU can warp a 25 mm rotor. More likely you have deposited pad material stuck and making high spots.
Old 05-15-2019, 07:56 AM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
What Doug said. You need to do a few "panic stops" to remove any pad deposits that have accumulated.
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 05-15-2019, 09:17 AM
pshovest pshovest is online now
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
Very unusual for factory pads to leave deposits, they are incredibly abrasive and scrub the rotors well. If you can feel the shake, you've got a braking performance issue. Car should be under factory warranty. Complain to dealer when several aggressive stops from 70 - 0 MPH don't fix it.
Old 05-15-2019, 09:25 AM
Nuclear engineer
Aggressive stops from 70 MPH to 5 MPH. Do not leave the pads resting on a stinking hot disc.
Old 05-15-2019, 10:34 AM
BMW CCA 69606
Absolutely correct.
Old 05-16-2019, 09:21 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
The rotors may also have developed a glaze which gives a shuddering sensation. Doug's remedy should work.
Old 05-17-2019, 04:40 PM
I tried the 70-5 a few times. Still feels a little uneven but its pretty bearable now
Old 05-17-2019, 05:27 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: 944 Turbo M235 Z4 335Mcar
I've had this a few years back, I took the rotors and cut them. Problem solved.
Similar Threads
Brake rotors warped / Pad ? PaulPt E90/E91/E92/E93 (2006 - 2013) 10 05-27-2016 10:16 AM
3rd Set Of Warped Rotors..Help Diamond_Ed E63 / E64 6 Series (2004 - 2010) 15 03-25-2013 12:02 AM
Warped Rotors shendrick X3 E83 (2004 - 2010) 7 12-21-2011 09:13 AM
All four rotors warped after a few thousand miles JejuneLegume E82 / E87 / E88 / F20 1 Series (2008 - 2014) 2 09-10-2011 02:25 PM
Control Arm Bushing vs Warped Rotors casino hairpin E34 (1989 - 1995) 4 05-23-2008 02:57 PM
