2006 BMW DSC Module - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 05-10-2018, 12:20 PM
kdont kdont is offline
Mein Auto:
2006 BMW DSC Module
Hi everyone,
Looking for some help/insight here. I recently purchased a used 2006 bmw 325Ci and a month or so later while I was driving, the check control light came on as well as the yellow brake light. I took it in and the service center is telling me that I need a DSC module replacement.
I'm wondering if I'm being taken for a ride here- everything I've found says that a DSC module problem is usually accompanied by the DSC light, or even ABS or DTC lights. I'm thinking that it's a little fishy that this is the recommendation but i only have the BRAKE light on.
Any thoughts? I don't want to take the whole DSC module out and send it for repair if I actually just need my brake fluid topped off or brake pads replaced.
Old 05-10-2018, 01:04 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Read our E46 Wiki (link on every page), pay attention to the section titled: Trifecta Lights".
The road goes ever onward....
(R.I.P. Jever)
Old 05-10-2018, 01:28 PM
Mein Auto:
The Wiki page that I'm getting to is blank- want to share a link?
Old 05-10-2018, 07:19 PM
BMW-North's Avatar
BMW-North BMW-North is offline
Kostspieliger Spaß Quandt
Mein Auto: e46;e92;f30;e83, AMv8v
You will need to get a diagnostic tool that will scan the ABS/DSC - something like INPA, ISTA or BMW scanner 1.4 - the latter you can find on eBay or amazon for under $20 and should be in every e46/e39 owners tool kit.
There are specific codes that indicate the exact fault.Fault could be anything from a wheel speed sensor, steering angle sensor, pressure sensor or even low brake fluid. There are a few of the codes that indicate a complete failed module - which is when the module board is kaput (typically a broken solder joint.)
Repair of your current module is feasible and common - typical cost runs about $150. There are a few companies that offer this service - it's a good option for those that don't want to code a donor module to their car. Seeing your old board is repaired no coding required.
I cut the following from a post I had in another forum a few years back:
Without the code you can be chasing shadows for weeks. Here's just two of the ABS unit's error code list. First thing is find out what unit you have (Possibly #3 or Teves) then get the code and refer to the exact problem. The one that I hinted to my my prior post is 5DF2 Internal Error, Valve/ECU Hardware Error, ROM/RAM Check. If it's this then you need to remove and send the ABS unit for repair else swap it with a donor. If your swapping it (if that's what the error is) then read my thread here on doing it:
Swapping, Coding ABS Donor Module & Steering Angle Calibration
BMW ABS fault codes.
ABS 3
5D90 Left Front Wheel Speed Sensor : Accident Recognition
5D91 Left Front Wheel Speed Sensor : Extrapolation
5D92 Left Front Wheel Speed Sensor : Periodical Control
5D93 Left Front Wheel Speed Sensor : Accident Recognition
5D94 Left Front Wheel Speed Sensor : Long Term Control
5DA0 Right Front Wheel Speed Sensor : Accident Recognition
5DA1 Right Front Wheel Speed Sensor : Extrapolation
5DA2 Right Front Wheel Speed Sensor : Periodical Control
5DA3 Right Front Wheel Speed Sensor : Accident Recognition
5DA4 Right Front Wheel Speed Sensor : Long Term Control
5DB0 Left Rear Wheel Speed Sensor : Accident Recognition
5DB1 Left Rear Wheel Speed Sensor : Extrapolation
5DB2 Left Rear Wheel Speed Sensor : Periodical Control
5DB3 Left Rear Wheel Speed Sensor : Accident Recognition
5DB4 Left Rear Wheel Speed Sensor : Long Term Control
5DC0 Right Rear Wheel Speed Sensor : Accident Recognition
5DC1 Right Rear Wheel Speed Sensor : Extrapolation
5DC2 Right Rear Wheel Speed Sensor : Periodical Control
5DC3 Right Rear Wheel Speed Sensor : Accident Recognition
5DC4 Right Rear Wheel Speed Sensor : Long Term Control
5DF0 Pump Motor
5DF4 Power Supply too Low
5DF5 Control Unit Internal Error
5DF7 Power Supply too High
5E00 Tyre Test Active
5E01 Tyre Test Timeout
5E02 Tyre Test Gyration Sensor Justification Error
5E03 Tyre Test Gyration Sensor Error
5E04 Tyre Test Lateral Acceleration Sensor Error
5E05 Tyre test Lateral Acceleration Sensor Error and Gyration Sensor
5E06 Tyre Test Gyration Sensor Fault
5E07 Tyre Test Lateral Acceleration Sensor Error and Gyration Sensor Fault
5E08 Tyre Test Steering Angle Sensor Error
5E11 Internal Error CAN-Controller
5E14 CAN Timeout DME/DDE
5E15 CAN Timeout EGS
5E16 CAN Timeout Instrument Cluster
5E18 CAN DME/DDE Message
5E19 CAN DME/DDE Torque Reduction Not Possible
5E1A CAN DME/DDE Signal Error
5E1E CAN Timeout LWS
5E1F Steering Angle Sensor - not Initialised
5E20 Pressure Sensor 1
5E21 Pressure Sensor 2
5E24 Pressure Sensor 1/2 not Plausible
5E26 Sensor Power Supply
5E2F Temperature Sensor
5E30 Lateral Acceleration Sensor
5E32 Lateral Acceleration Signal not Plausible
5E38 Wheel Speed Sensor
5E3C Wheel Speed not Plausible
5E40 Lateral Acceleration Signal not Plausible, Offset
5E43 Lateral Acceleration Internal Error
5E4E DSC Sensor Offset Check
5E4F Long Time Regulation DSC
5E59 Coding Error
5E5B Switch Pressed Longer than 10s or Faulty
5E5D Brake Fluid Level Switch
5E5E Brake Light Switch
BMW ABS Teves MK20
11 Front left wheel-speed signal
12 Front left wheel-speed signal
14 Front left wheel-speed signal
15 Front left wheel-speed signal or front left outlet valve
21 Front right wheel-speed signal
22 Front right wheel-speed signal
24 Front right wheel-speed signal
25 Front right wheel-speed signal or front right outlet valve
31 Rear left wheel-speed signal
32 Rear left wheel-speed signal
34 Rear left wheel-speed signal
35 Rear left wheel-speed signal or rear axle outlet valve
41 Rear right wheel-speed signal
42 Rear right wheel-speed signal
44 Rear right wheel-speed signal
45 Rear right wheel speed signal or rear axle outlet valve
61 Front left inlet valve
52 Front right inlet valve
53 Rear left inlet valve
S4 Rear right inlet valve
55 Front left outlet valve
56 Front right outlet valve
57 Rear left outlet valve
58 Rear right outlet valve
61 ASC special valve
71 Pump Motor
73 ABS control unit
76 Electromagnetic or mechanical influence of wheel speed signal
78 Battery voltage
81 ABS/ASC main relay
82 Solenoid valves power supply
83 Solenoid valves power input
85 Solenoid valve coil
91 CAN: chip in ABS/ASC control unit
92 CAN: bus faulty
93 CAN: engine intervention
94 CAN: engine speed
95 CAN: connection failed with DME/DDE
96 CAN: connection failed with EGS
97 Incorrect coding
98 ASC button
Edit: If you are going to try to fix this yourself a BMW specific scanner would be useful (necessary) PA Soft or INPA can read the exact errors. INPA can actually assist with replacement (both are under £15 )
2006, bmw, brake, check control, dsc
