99 540 M62tu timing chain tensioner oil leak - Bimmerfest - BMW Forums
Old 10-12-2018, 03:12 PM
Panel beater Panel beater is offline
Mein Auto:
Hello all I finished a total timing chain guide job as well as vanos reseal and clean and reseal all parts involved with the job. I did run into a problem with timing and codes .i resolved that issue with the help of you guys. I have an oil leak that is coming from the timing chain tensioner for sure. When I installed the new tensioner I noticed there was no o ring on the cap that screws into the block. I already threw out my old parts to check the old cap. My question is should it have some sort of seal or o ring on the cap????? All you feedback is appreciated.
Old 10-12-2018, 03:45 PM
atobe atobe is offline
Mein Auto: 00 528, 01 540
There's a crush washer #20
http://www.realoem.com/bmw/enUS/show...diagId=11_2264
Old 10-12-2018, 11:20 PM
777-300ER 777-300ER is offline
Just call me 777.
Mein Auto: 2015 GTI (yes, traitor)
Should be a brass washer in the box.
Sold 12/23/17
She will be missed.
Old 10-12-2018, 11:44 PM
Chedley Chedley is online now
Mein Auto: 2001 E39 540i
When you did the timing chain guides job, and removed the old tensioner, did you find and remove the washer ?!
If not, that old washer may have been stuck to the engine block. Remove the tensioner, AND the old washer -scratch it out-. Then reinstall the new tensioner (with the longer spring) and a new washer.
<=E39=>
Old 10-13-2018, 08:05 AM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
The timing chain guide tensioner does not come with a new O ring. I found out the hard way. The old one sometimes sticks to the block. Sound like you lost the old one. Itís aluminum not brass.
Order one online or stop by a dealer. They have them in stock. Alternatively, when I was stuck without one, I found a package of copper O rings at autozone and one matched perfectly. I still replaced it though with the correct aluminum BMW part.
2003 540i|Jet Black|Gray Interior|M-Sport|WS NAV|Shades|PDC
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|745li|2007 750li|2006 750li|2001 530i|2012 535xi|
Old 10-15-2018, 03:03 AM
Mein Auto:
Yes I did find the washer ,it was with the kit I bought but it was labeled " differential seal" so I thought it was somthing in the kit that wasn't for my application .i thought it was for an X5 application or somthing.
I installed it no more leak, test drive was good no check engine lights!!!!! Project was a success!!!!!!
Old 10-15-2018, 05:29 AM
Joe-BMW's Avatar
Nice! Hopefully if you had a rattle on cold start it's gone.
Old 10-15-2018, 10:21 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
... and O-rings are made of rubber, and shaped like a toroid.
Old 10-15-2018, 10:48 AM
Joe-BMW's Avatar
Nope, they are aluminum for sure - I have like 12 of them:
https://www.ecstuning.com/b-genuine-...h/07119963418/
(it's not often I am right here
