Is my OFHG leaking ? - Bimmerfest - BMW Forums
Old 03-30-2019, 09:03 PM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
See attached images. OFHG ? I know it's a common leak on the E9x.
ID:	845991   Click image for larger version
Not even sure if -40 degrees is cold anymore ?
Old 03-30-2019, 11:55 PM
stonex1's Avatar
stonex1 stonex1 is online now
Mein Auto: 13' X1 35i
I'm no mechanic, but that looks pretty clean.
I think if it was leaking, you would see worse.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 03-31-2019, 04:03 AM
Doug Huffman's Avatar
Nuclear engineer
+1.
Wipe the film off and monitor.
If someone else does your oil changes ...
Old 03-31-2019, 03:21 PM
Engine needs a wash anyways, after the filthy winter driving. Will give it a good cleaning and then monitor
Old 03-31-2019, 07:22 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
if anything id say the cap is leaking not the filter housing itself. but as a bmw tech i wouldnt sell anything to a customer at this point in time.
Similar Threads
N73 motor leaking coolant from BACK of motor mws 7 Series - E65 / E66 (2002 - 2008) 5 05-02-2019 07:47 PM
Oil leaking Ericyin 7 Series - E65 / E66 (2002 - 2008) 3 03-11-2019 02:34 PM
2006 335i ATF leaking excessively mclarry01 E90/E91/E92/E93 (2006 - 2013) 1 11-27-2018 01:00 PM
New water + engine heater inlet coolant pipe leaking chimacc E39 (1997 - 2003) 2 10-17-2018 12:08 PM
