Control Arm Bushing vs Warped Rotors - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 05-22-2008, 12:20 PM
casino hairpin casino hairpin is offline
Mein Auto:
Trying to diagnose a worsening shimmy problem under braking. Pads look fine, but I believe my rotors are the problem. Also thinking the control arm bushings could be the source, but I'm not experiencing any front end shimmy under moderate speeds 60-80, only under braking. Any thoughts?
Old 05-22-2008, 12:29 PM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Thought number 1
Control arm bushings are begining to go bad. That was the first thing I noticed before I began to get a vibration between 50 to 60 MPH.
Thought number 2
refer to thought number 1 (LOL)...
http://www.bmwe34.net/e34main/mainte.../upper_arm.htm
Old 05-23-2008, 02:21 AM
Sboerem Sboerem is offline
+1
You can start to feel it first when your braking, before the 50-60 shimy. If you feel the vibration more when you brake downhill (ie more weight on the front of the car) that's an almost sure sign for thrust arms. Get underneath your car and check to see if you can see any cracks in the rubber bushing, if so it's time to change them, best of luck.
Old 05-23-2008, 07:51 AM
Mein Auto:
Thanks guys, very helpful.
Old 05-23-2008, 02:57 PM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
As long as you continue braking, does the shiimmy or shake continue until you stop? It may be the rotors. I am experiecing a shimmy as I described. I think it is brake rotors. iIturned the rotors about 20,000 miles ago to stop the shimmy. It is back again only when braking at any speed.
May just replace the rotors. My upper thrust arms were replaced with lemforder arms and I believe 750i bushings about 2 years ago.
1995 525i auto, 1/95 build, EAT chip, abt 239K miles, , HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 211K
