eas | Streamline SE Panel Filter for N54 135/335/535i IN STOCK! - Bimmerfest - BMW Forums
Looking to get some great BMW parts for your car? Get the latest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 08-22-2008, 05:38 PM
david @ eas david @ eas is offline
European Auto Source
Mein Auto: M3
eas is proud to offer the Streamline SE Panel Filter for N54 135/335/535i, E46 M3, Dinan and K&N Replacement cone filters, and Most BMW filters for several different applications.
Helene Performance specializes in high quality, high performance and high protection original equipment direct replacement air filter panels for select vehicles. Every Helene Performance Streamline SE panel filter is designed to the specific requirements of the engine it will be protecting so you are not getting just another mediocre one-size-fits-all design. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today's high tolerance engines.
The Streamline SE panel filter is the ultimate tweak for someone that wants to maintain and improve upon the highly engineered stock intake systems.
http://www.europeanautosource.com/pr...oducts_id=1904
This is an engineered filter. Not just another universal washable filter! You are proud of your high performance vehicle so now get a panel filter of the same caliber.
Maintaining proper CFM flow and particle capture efficiency is a delicate balancing act. Filters that flow well usually do not protect as well and vice versa. Helene Performance has mastered the formula to achieve this elusive perfect balance and so your engine assets will perform better without sacrificing protection. This filter is serious equipment for serious cars.
Features of the Streamline SE panel filter:
- Direct replacement for original equipment filter panel. No modifications required
- Tight leak proof seal with the air box
- Easy and fast installation suitable for novice requiring only a screwdriver at most
- Deepest multi-layered pleats increase air flow and maintain critical protection levels
- Maintains OEM filter's 99% debris collection efficiency per ISO 5011 standards
- Maintains BMW engineered pressurized air box and stock appearance
- Sturdy sidewall construction ensures filter will last the life of the vehicle
Models Supported:
2008+ 135i
2006+ 335i
2008+ 535i
Streamline SE Panel Filter for most BMWs
This Streamline Panel Filter for most BMW's covers a wide range of cars. Offering the same reliability and performance as the filter for the N54 Motor comes the Streamline Panel Filter for most BMWs. Every Helene Performance Streamline SE panel filter is designed to the specific requirements of the engine it will be protecting so you are not getting just another mediocre one-size-fits-all design. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today's high tolerance engines.
http://www.europeanautosource.com/pr...oducts_id=1223
Models Supported:
1992-1998 BMW 318i/iC/is
1995-1999 BMW 318ti
2000 BMW 323Ci/CiC
1999-2000 BMW 323i/iC
1998-1999 BMW 323is
2000 BMW 323iT
2001-2004 BMW 325Ci/CiC
1992-1995, 2001-2004 BMW 325i
1992-1995 BMW 325ic/is
2001-2004 BMW 325iT/xi/xiT
1996-2000 BMW 328i
1996-1999 BMW 328ic/is
2001-2004 BMW 330Ci
2001-2004 BMW 330Ci Convertible
2001-2003 BMW 330i
2001-2004 BMW 330xi
1992-1995, 2001-2003 BMW 525i/iT
1997-2000 BMW 528i/iT
1994-1995, 2001-2003 BMW 530i/iT
1995-2001 BMW 740i/iL, 750iL
1999-2000 BMW M Coupe
1998-2000 BMW M Roadster
1998-1999, 2001-2006 BMW M3 Convertible
1995-1999, 2001-2006 BMW M3 Coupe
1997-1998 BMW M3 Sedan
2001-2004 BMW X5 3.0i
2000 BMW Z3 Coupe 2.8
2001-2002 BMW Z3 Coupe 3.0
2001-2002 BMW Z3 Roadster 2.5L & 3.0L
1997-2000 BMW Z3 Roadster 2.8L
2006-2007 BMW Z4 Coupe (excludes 2.0L and M models)
2002-2007 BMW Z4 Roadster (excludes 2.0L and M models)
Streamline SE Panel Filter - e46 M3
Offering the same reliability and performance as the previous filters, comes the performance enhancing Streamline filter for the E46 M3. Maintaining proper CFM flow and particle capture efficiency is a delicate balancing act. Filters that flow well usually do not protect as well and vice versa. Helene Performance has mastered the formula to achieve this elusive perfect balance and so your engine assets will perform better without sacrificing protection. This filter is serious equipment for serious cars.
Streamline SE Panel Filter - e46 M3:
http://www.europeanautosource.com/pr...oducts_id=1222
Models Supported:
2000-2006 BMW M3
Streamline SE Cone Filter - Dinan Replacement
The Helene Performance replacement cone filter retains the same high quality, high performance and superior protection concept as our original equipment direct replacement panel filters. This is an engineered filter. Not just another universal washable filter! The Helene Performance replacement cone filter for the Dinan brand cold air intake brings the Streamline SE level of "performance and protection" to this already highly capable and well designed kit. This filter is shaped with a subtle taper that will facilitate installation within the tight confines of the intake enclosure.
Features of the Streamline SE cone filter:
- Specific for replacement on Dinan e46 M3 Cold Air Intake kit (filter P/N D401-0440)
- Tight leak proof seal with the intake pipe
- Easy and fast installation requiring only a screwdriver at most
- Multi-layered pleats increase air flow
- Deeper pleats maintain critical protection levels
- Velocity stack integrally molded into flange
- Sturdy urethane construction ensures filter will last the life of the vehicle
Cross Reference:
Replacement cone filter for Dinan part no: D401-0440
http://www.europeanautosource.com/pr...oducts_id=1225
Streamline SE Cone Filter - K&N 63 Replacement
The Helene Performance replacement cone provides a reasonably priced upgrade in protection and performance for any cold-air-intake application that utilizes this size cone filter element. Check the manufacturer's specifications for proper size and application. New high quality attachment hardware included.
- Specific for replacement on K&N 63 BMW e46 M3 Cold Air Intake kit (filter P/N RF-1032)
Cross Reference:
Replacement cone filter for K&N part no: RF-1032 (found on K&N 63 intake kits). 4" Inlet Flange x 7" Pleat length with Flow Vortex unit and Lip for MAF Screen
http://www.europeanautosource.com/pr...oducts_id=1224
If you have any questions regarding this product, or any other product, please feel free to PM me or send me an email.
Old 09-05-2008, 11:59 AM
Mein Auto: M3
Bump!
Old 09-30-2008, 11:55 AM
Mein Auto: M3
Bump!
Old 10-08-2008, 06:58 PM
Mein Auto: M3
This Streamline filter is in stock and ready to go!
