Brake rotors warped / Pad ? - Bimmerfest - BMW Forums
Old 05-25-2016, 02:36 PM
PaulPt PaulPt is offline
Mein Auto: BMW 328xi
Hi Everyone:
New to the forum. I have a 328xi 2011 sedan (non sport or M). I have 50K miles on it and the front rotors are warped (the shaking when braking is out of control). I am planning on replacing them with Zimmerman rotors (used them in the past when I had an X5 loved them!) and either Textar or Brembo pads.
My question: Pads are still within specs, should I replace them while I am at it (not sure if the wear is uneven due to the warping), or replacing the rotors should do it. Also anyone has experienced warped rotors at this mileage (my driving is very conservative, back roads almost never in highway and I do not brake hard and there is no light indicating pad wear yet)
Also if you guys have any other suggestions on pads I highly appreciate it (I don't care much for dust etc, just something that is as close as possible to OEM without the price).
Thanks in advance for your responses.
Paul
Old 05-25-2016, 02:52 PM
08 335Ci 08 335Ci is online now
Mein Auto: 2010 335 M sport
Why don't you try re-bedding the pads 1st? Check out Tire Rack's website.
No matter how fast I go, there's always someone slower in front of me.
2010 E92 335 M Sport, Titan Silver Metallic, Steptronic, JB-4 G5 ISO, WMI, 3.5 Tmap (22 psi boost), BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC, Pedal tuner, Escort Max 360
Gone, but not forgotten ( totaled)
'08 335 E92, M-Sport suspension, 6 sp auto, w/paddle shift
CCA Member 109065 since 1993
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 05-25-2016, 07:35 PM
woodmanfondu woodmanfondu is offline
Mein Auto: 335i
I have a 2011 335i with 55K and warped rotors. I only notice it when braking hard at high speeds tho. I will be replacing pads and rotors in the next 5-10k
Old 05-25-2016, 08:00 PM
I guess we are on the same page, same here braking from lets say 60mph..
Will be doing the same soon, do you happen to know the torque values for all the bolts that are required for this job? I am looking and searching on the forum, all I've found so far are for the X3. I suspect they are very similar if not same as for the 3 series
Old 05-25-2016, 08:45 PM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
I trust you when you say rotors're warped, but shouldn't we verify? To eliminate brake compound deposits from your equation, emery cloth the rotors, or use this handy tool!
So. How's yer pulse feel now?
Name:  Big Smiley.jpg
Old 05-25-2016, 09:46 PM
Attachment 564709
Well..I have nothing to loose by cleaning the rotors until new ones arrive (better say I place the order this weekend). This shake happens when braking at over 50mph (sorry I did not mention on my first post). The rotors look like vinyl records not sure if this is an indication of sorts.
Old 05-25-2016, 10:42 PM
Banned
Well, to avoid alotta work that might not need doing, I recommend runout testing. Remember, bad bushings cause wobble too....
If ya do score new discs, I always say: corrosion inhibited.
Old 05-25-2016, 10:46 PM
Thanks for your feedback Calwater. Can bad bushings cause such a vibration only when braking?
Old 05-26-2016, 07:40 AM
Banned
Yep, possible. Trouble shoot causes to ID what's cookin'.
Old 05-26-2016, 10:11 AM
bwillia's Avatar
bwillia bwillia is offline
Just another Gear Head!
Mein Auto: 2008 335xi coupe
Do you make sure your lugs nut are always torqued with a torque wrench when installed? Improper/Uneven torque will cause warped rotors. Also a simple runout gauge test will tell you for certain if the rotors are warped.
Old 05-27-2016, 10:16 AM
I had my tires rotated which allowed me to take a look at the rotors in detail. Time for new ones
Rotors are super rusted and had a lot of white deposits (maybe from salt in the winter?) cleaned all that and braking improved a bit but definitely new rotors and pads are in order
