Sunroof Shade Clip DIY - Bimmerfest - BMW Forums
Do-It-Yourself H.Q.
Old 12-28-2005, 10:35 PM
ChrisF ChrisF is offline
Mein Auto: 2002 330 xi
Like many others, I've had problems with the sunroof shade on my 330. It was not sliding properly and was binding up when I operated the sunroof. There are four "clips" that attach the shade to the slider mechanism that are notoriously poorly designed. It doesn't take much to break them.
I put together a quick Sunroof Clip DIY (with pictures) describing how to replace these clips.
When I did this repair I found that none of my clips had actually broken. In my case, one of the clips on the right side, had popped out of the slot in the sliding member and it was causing the shade to bind up when the sunroof was opened/closed.
Now that I've had it apart, I'm certain that I'd be able to replace them if/when my clips break.
Enjoy.
ChrisF
2002 330xi, 5-spd, Orient Blue w/ Sand Leather, SP, PP, Xenons
Old 12-29-2005, 09:53 AM
qu4ttro's Avatar
qu4ttro qu4ttro is offline
Mein Auto: 01 325i, 08 335i
Very nicely done, Chris!
ED - Mar 30, 2008 - e90 335i
A/W | Terra | Burl | ZSP | ZPP
Step | Paddles | Nav | CA | iPod
Old 01-07-2006, 07:00 AM
srcstc srcstc is offline
mybimmer.net
Send a message via AIM to srcstc
Mein Auto: 09 TiAg E92 335i M-Sport
Yes very nice. This turned out to be one of the easiest DIYs.
Rich
Old 01-31-2006, 06:32 PM
Hutchman Hutchman is offline
Mein Auto: 2011 328i, 01 325I
My shade wont slide back beyond two inches. My question is.....how do I loosen the 6 torx screws when I can't get to them? Anyone???????
Old 02-01-2006, 08:24 PM
blkonblk330i blkonblk330i is offline
Mein Auto: 06/2000 330i ZSP/ZPP
flip moon roof up and you should be able to slide shade back.
Never argue with an idiot. He will drag you down to his level then beat you with experience.
Old 02-04-2006, 09:53 AM
That is the problem, it wont go back more than 2 inches. It was like that when I bought it used. It goes back with the glass when it is opened, but comes back up with it when it is closed. I would like to fix it, but I don't want to brake anything in the process.
Old 08-05-2007, 07:00 PM
pbarker pbarker is offline
Mein Auto: 318
Sounds like someone did a DIY and whacked the sunroof shade back on the wrong side of the sunroof driver... I did this yesterday and it won't allow you to move it back but it goes back with the roof but not all the way into the roof.
Old 08-28-2007, 09:03 PM
kattanapilot kattanapilot is offline
Wedding Crasher
Send a message via ICQ to kattanapilot Send a message via AIM to kattanapilot Send a message via MSN to kattanapilot Send a message via Yahoo to kattanapilot
Mein Auto: 2001 325i
first thank you ChrisF, second I LOVE THIS Forum!!! I been reading for like 4 days now, my work productivity has gone down ever since I registered here. I just fixed my shade, I need 1 clip when ever I get one but I swapped one and put this back in the track. Does any one recommend any online sites to order this from?
I have an 8" tongue and can breathe through my ears...
Old 04-07-2008, 02:54 PM
byelton byelton is offline
Mein Auto:
The sun shade on my wife's 2003 325Xi just came loose. It doesn't seem to be sliding correctly in any tracks.
I was going to try to get the dealer to fix it under CPO but they are claiming that it is covered. (even though this is part of the mechanical sunroof system/movement.)
I haven't done anything with the car yet but based upon this writeup I will probably see if I can fix it before resorting to the stealer. (I was really hoping I didn't have to remove the headliner). If the clip broke off inside, what are the chances that this piece will remain in the roof of the car & can jam the sunroof mechanism?
Old 04-07-2008, 03:50 PM
johnewhite's Avatar
johnewhite johnewhite is offline
USMC ProCivEng
Mein Auto: '03.5 M3 Coupe
Very nice DIY. But the glass does not have to be removed in order to remove the shade. All you have to do is just hold the shade closed as you fully open the roof. The shade will be then be exposed and you can lift it out.
Old 04-09-2008, 10:12 AM
Mein Auto:
Found another thread about sunroof that mentioned S.I. B54 05 06. Talked to the dealer again armed with this information and now they are going to cover it under CPO. Go figure.
https://www.bimmerfest.com/forums/sho....php?p=3162413
Old 04-21-2008, 04:52 PM
BM-MAN BM-MAN is offline
Mein Auto: BMW 323ci
How exactly did u achieve that? There is a tab that automatically pulls the sunshade back when you open the glass? Seems to me that holding it shut would break something?
My problem right now is the Driver; the metal that holds the plastic driver in place is bent. I just don't see how to bend it back in place...
My next whip!!!!
Old 05-02-2008, 01:54 AM
dimantslv dimantslv is offline
Mein Auto:
nice yob!
Old 05-02-2008, 11:17 AM
johnewhite's Avatar
USMC ProCivEng
Just like I said in the post.
Old 05-30-2008, 07:54 PM
bavenda bavenda is offline
Mein Auto:
what is the part number of the "driver"
I can't find the part number in the diagram.
Enjoy.
Old 11-08-2009, 05:58 PM
jvd626 jvd626 is offline
Mein Auto:
Were you able find this part number of the "driver"? i can't seem to find this driver in the realoem.com catalog.
Old 11-09-2009, 06:58 AM
pish180 pish180 is offline
Mein Auto: 2003 330xi
I've been looking for the slide stop (part behind what you circled).. I guess our best luck is to go to a junk yard. Its not listed on realoem.
Old 10-20-2010, 12:20 PM
darianva darianva is offline
Mein Auto: 330 sport
Hi All,
I hvae recently run into the issue where my sun roof will not open in slide mode fully.
It appears as per the forum that something on the lid/cover has broken and prevents the roof from fully opening.
I woud like to use johnewhites plan to open the roof while holding the cover lid closed, however I am not able to close the lid/cover as it gets stuck halfway.
Does that leave me no other option that to remove the roof by lifting it out after removing the 6 torx screws?
thanks
darian
Old 10-20-2010, 12:49 PM
Originally Posted by darianva View Post
Hi All,
thanks
darian
I ran into the same issue. You have to keep giggle the lid back and forth until it comes loose.
My next whip!!!!
Old 10-20-2010, 12:53 PM
aha, so the glass roof removal may not be required bsaed on what you say....
just wiggle the lid/cover loads and hope it comes loose?
how much wiggling/force did you execise? (I tried a fair amount before posting, but did not want to get too tough...)
Old 10-20-2010, 01:00 PM
Eventually you will have to remove the glass to replace the pieces that fall out as you giggle it cause some will. To loosen it up you could open and close the glass while moving the lid in the same direction. I never got around to replacing the broken clips since other members who did replace them only ended up having the same problem again. the roof is a major weakness in our e46s....
My next whip!!!!
Old 10-20-2010, 01:03 PM
thanks bm-man.
as i have access to the 3 screws to remove the roof, I will save and prevent screwing anything up by taking the glass out to see whats blocking things...
Old 11-07-2010, 05:28 AM
I finally got round to taking my roof out yesterday afternoon.
Once the roof was out it was easy to spot the issue.
It appears somehow that the driver got ahead of the front clip. I removed the front clip by taking out the 2 screws to allow me to move the shade and front clip behind the driver.
Put everything back together and voila!
The plastic on the driver was a little pushed up, but I managed to clip it back into position.
Thanks all for your good support and posts.
Took me no more than 45 mins to remove the roof, fix the issue and re-assemble the bits on my own.
Old 09-01-2011, 01:10 PM
strombou strombou is offline
Mein Auto: 2002 325i BMW
Thanks guys for the posts, I have the same issue and will attempt to DIM since I'm now armed with valuable knowledge and have a starting point and a direction to follow. If anyone has the part numbers to this kit, that would help. I have a 2002 325i BMW.
Old 10-09-2011, 09:18 AM
jordanfanx23x jordanfanx23x is offline
Mein Auto: 2000 BMW 328i Sports Pack
Even easier DIY
Another way of doing this that is much easier iswithout removing the glass. The shade slider has 2 very flexible rubber pieces at the front of it which is used to push it back when the actual glass moves if you just slowy open it and pass these two rubber pieces under it you can open the glass fully and work only with the shade slider. There are 2 perks i noticed when i did this:
1. you dont have to worry about placing the glass back on correctly and no need to recalibrate it in some cases
2. you can remove the entire slider and still close close your sunroof normally, so like for me, i could still drive around with no worries while i waited for the parts to come in!
Pt #'s
54-13-8-246-027 (left 2 needed)
54-13-8-246-025 (right 2 needed)
Similar Threads
Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions EPBB E46 (1999 - 2006) 119 05-09-2010 04:09 PM
Is there a DIY for fixing a broken sunroof shade? wag-zhp E46 (1999 - 2006) 11 07-21-2005 05:23 PM
2001 e46 sunroof shade guide broke sun3301 E46 (1999 - 2006) 10 06-03-2005 07:25 PM
Has the horrible sunroof cover 'clip design' been fixed on the E90? missing23 E90/E91/E92/E93 (2006 - 2013) 5 05-26-2005 01:57 PM
Sunroof problems MStewBoy 3 Series & 4 Series 5 01-23-2004 11:12 AM
