Bmw Engine Tilt? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 11-03-2006, 12:01 PM
AW328i AW328i is offline
Mein Auto: 2 cars and a truck
Question Bmw Engine Tilt?
I did a search but didn't find anything that explains why our inline engines tilt to the passenger side. Anyone know why?? I'm sure it has something to do with oiling but I've always been curious.
Old 11-03-2006, 01:15 PM
Tangent's Avatar
Tangent Tangent is offline
Format c:\*.* /y
Mein Auto: '11 Z435i, '01 330i
Because if they weren't tilted they'de be sticking up out of the hood by a good 6-7 inches... They're pretty tall engines. Tilting them is actually bad for oiling. In hard left turns the oil can easily slosh way up the slope on the passenger side of the oil pan if you don't have baffles installed.
Old 11-03-2006, 02:33 PM
Ah ha!
Old 11-07-2006, 07:32 AM
Vikram Vikram is offline
Mein Auto:
I think BMW engineers know what they are doing.
Old 11-07-2006, 08:22 AM
gbelton's Avatar
gbelton gbelton is offline
///M for Motor Sports!
Mein Auto: No More 6 Series
They R Tilted...
Also known as a engine set at a 90 degree angle.
The Tail of The DRAGON, YES!!
2008 Alpine White, Portland Brown ///M5 (SMG)
2008 Alpine White, Fox Red ///M3 (6MT)
2008 Sapphire Black, Black 750Li
Old 11-07-2006, 09:01 AM
90 degree angle would have no tilt.
Old 11-07-2006, 01:46 PM
msbrown's Avatar
msbrown msbrown is offline
Z3 Crash-test Veteran
Mein Auto: 2002 325i
Yup. In the States, Dodge called this the "Slant Six" when they did it some 40 years ago...
Old 11-08-2006, 01:50 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Actually it has 0 degree tilt.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 11-08-2006, 01:52 PM
philippek philippek is offline
Past Sponsor
Mein Auto: Z4 M Cpe, Miata, X6 50i
It also lowers the center of gravity.
Old 11-08-2006, 07:30 PM
lex89's Avatar
lex89 lex89 is offline
Send a message via AIM to lex89
Mein Auto: '99 528i
Or 180 degree tilt
Old 11-09-2006, 06:16 AM
180 + 90- 60 carry the two, subtract the balance;I'm very confused now!
Old 11-09-2006, 10:35 AM
Tangent's Avatar
Format c:\*.* /y
I have no idea what the guys saying 0, 90, or 180 degrees are talking about... Maybe they're confusing tilt with the degrees between banks of cylinders in V# engines or something... In any case, the engine has probably close to a 30 degree tilt to the right.
Old 11-09-2006, 11:29 AM
kevinp's Avatar
kevinp kevinp is offline
Mein Auto: 2007 530i
The following link indiates that the engines tilt 30 degrees to the right.
Tangent, you are correct!!
http://www.bmwworld.com/engines/m52.htm
Enjoy!
2007 530i
Silver Grey, Beige Leather, Sirius, L7, Cold, Premium, Shades
Old 11-09-2006, 08:39 PM
Tangent's Avatar
Format c:\*.* /y
Wow, pretty good for a guess!
Old 11-11-2006, 05:40 PM
67bmer 67bmer is offline
Mein Auto: e36 325is
BMW started tilting the inline engines 30 degrees with the new class 1500, 1600, 1800 to get the hoodline lower. They were still pretty tall cars compared to todays. That is the reason most cars have gone to V engines, to get the hoodline lower. The Japanese also tilt some of their transverse front wheel drive engines for the same reason.
The tilt is measured from viertical. 90 degres would be horizontal. That would be pointless for a straigt engine, although BMW did do that in their motorcycles. Typically, a V engine with a 180 degree V is referred to as a horizontally oposed engine or a flat engine. Flat engines do not lower the CG as much as one might expect since the oil reservoir must be completely below so that the pistons are not sloshing back and forth in it. Since the vast majority of the mass is then on the centerline of the crank the CG ends up being fairly high.
BMW may have used this concept before the new class, but I am not familiar with them. I thought most of them were V engines or virtically mounted.
Old 11-11-2006, 07:48 PM
Good info! I'm guessing lower hoodline means less drag right?
Old 11-12-2006, 06:33 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
^^^Is that a P-Chop in your avy? That's hot.
Old 11-12-2006, 01:24 PM
Tangent's Avatar
Format c:\*.* /y
That's a Nazca C2, an absolute beauty. http://images.google.com/images?svnu...mw&btnG=Search
Yes, but mostly it makes the people in charge of styling the car happy. Too high of a hood looks too truck-like.
Old 11-14-2006, 04:55 PM
Pinecone's Avatar
M Mad
Unless the engine is dry sump lubricated.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 04-03-2020, 03:39 AM
GruppoHainz GruppoHainz is offline
Mein Auto:
I'm preparing my thesis in mechanincal engineeer and I would like to speak also about Bmw engine's tilinting position. Do you have any Paper about it? I dind't find any comment about the 30° degree positioning in many Bmw Press release.
Old 04-14-2020, 03:39 AM
Mein Auto:
My mother has a Bmw 320 diesel Touring E91 and I measured the tilinting of this 2.0 diesel (M47 generation): 20° degree.
bmw engine, bmw engine angle, bmw engine installation, bmw engine tilting, engine tilting
Similar Threads
Wall Street Journal Article on BMW's Past, Present and Future Salvator General BMW Questions 67 06-17-2018 04:47 AM
BMW needs to use it engineering ability to design cars that use less gas. x54.4blue General BMW Questions 247 09-16-2006 12:07 PM
The History of the BMW 5 Series WAM 5 Series 5 08-17-2006 08:46 PM
Bmw Team Ptg Names M3 Drivers For 2006 American Le Mans Series tim330i Motorsports, Racing & Track 4 01-30-2006 01:41 PM
The Bmw Group Moves Into A New Dimension tim330i General BMW Questions 6 03-21-2004 11:11 AM
