M Performance Exhaust Operation - need education - Bimmerfest - BMW Forums
Old 04-24-2018, 05:50 PM
NY330iGary NY330iGary is offline
Mein Auto: 2015 435iX Gran Coupe
There must be someone who can tell me how the MPE on my 335ix is supposed to work.
I had an MPE installed by the dealer, BMW part, before I took delivery. It is a CPO unit.
I have been trying to find someone who can definitively tell me how to get the left exhaust pipe to open up. The salesman didn't have a clue.
I don't believe that the left pipe flap has ever opened. I checked connections and things appear to be tight. I gleaned from older posts that the flap opens up when RPMs are greater than 3000 and the transmission is in Sport mode or Sport +. Otherwise it stays closed.
Can someone shed some light on how it's SUPPOSED to work?
Gary
2016 F-150 SC
1974 TR6
2015 RAV-4 XLE (zzzzzz!)
2006 330I (retired)
Old 04-24-2018, 08:26 PM
bimmerbingo bimmerbingo is offline
Mein Auto: 2016 X6 50i
This.
2016 X6 50i M-Sport (mine), x-drive, CPO, alpine white
2015 435i M-Sport (mine), x-drive, CPO, sapphire black metallic, MPPK, MPBK, MPE
2015 X5 50i M-Sport (hers), x-drive, CPO, carbon black metallic
2015 328i M-Sport (hers), x-drive, new, alpine white
2007 328i (mine), rwd, used, silver
Old 04-24-2018, 09:25 PM
Hookster57 Hookster57 is offline
Mein Auto: 435i Grand Coupe
I donít think the left side ever opens.
Old 04-24-2018, 10:45 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
Or you can code it to stay open all the time.
Kevin
CURRENT:
2019 Chevy Suburban 4X4 RST
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2013 BMW 135is JB4 convt 6MT
2009 Yamaha V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
480 WHP of BURBBLES
I LOVE THE SMELL OF BURNT 100 IN THE MORNING
Old 04-25-2018, 05:32 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
Or disconnect it, add a jumper plug to make appear it's there software wise. Then open it manually and "pin it" to stay open.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 04-25-2018, 06:13 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
You're getting it....that's how it's supposed to work.
Would there be a reason for that? Yep! Back pressure and sa-mooth engine operation; torque development @ lower rpm.
Does it ever open? Um.....yes.....but as you're prob driving at the time you don't notice.
Should you force open? No, but some do as it's noisier. Low end torque will suffer.
Old 04-25-2018, 11:08 AM
Seen this before, can you explain it?
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 04-25-2018, 06:51 PM
sweeney921 sweeney921 is offline
Mein Auto: F31 LCI
Closing one of the exhaust tips does not increase torque. The back pressure argument is a flawed generalization. See below:
Keep in mind that turbocharged exhaust systems produce minimal scavenging effect, if any. This is because the turbo impeller interrupts the wave patterns within the exhaust system. The next best option is to increase the maximum flow rate, hence catless downpipes and larger diameter piping.
Old 04-25-2018, 09:37 PM
Agree with this logic, but was wondering what makes people so often state the torque loss thing.
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 04-26-2018, 07:02 AM
Well, the usual thing is that with better breathing [lower back pressure], more power is available. But BMW engines are tightly controlled and have an envelope of operation that allows only slight deviation from design spec. Reduce back pressure when the engine map is not designed to accommodate that, sub-optimal operation.
That was my experience when I did the 'golf tee' mod. What seemed at first to be smoother low end torque was simply reduced torque and when the exhaust flap was returned to normal op a pronounced increase in low rpm power appeared. I am persuaded by experience.
Old 04-26-2018, 08:19 AM
Mein Auto: 328xi GT
Now if your experience was truly using a golf tee, then it was with an older model engine and possibly ECU mapping. As electronics and equipment have evolved so has the software. There might be different results now.
Old 04-26-2018, 01:28 PM
Yeah have to think about that or play with the coding & try to get performance measurements. Mine is coded open & the car is very strong out of the hole. Same with the 435.
Kevin
CURRENT:
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 04-26-2018, 05:05 PM
'09....but I'm surprised if ECU mapping accommodates outta spec exhaust flap op. If anything, specs are tighter.
But I gotta be honest....thinking on it, JB3 may have been installed.....coulda magnified the issue, maybe caused it. But, not motivated to check. Happy with JB4 now. Flap is in operation.
Old 07-29-2019, 07:18 PM
DrGadget DrGadget is offline
Mein Auto: BMW 340i F30 LCI 2016
MPPSK and Keeping Exhaust Flap open
I have the M Performance pack installed, but use Carly for BMW Pro (New Version) to keep the flap OPEN in all driving modes. I do a lot of freeway driving, so it helps with power and efficiency to do this -- particularly in Comfort Mode.
Melbourne Red 340i F30 LCI Luxury Line with M Performance Pack - 265Kw/355HP, 2016.
ďA turbo: exhaust gases go into the turbocharger and spin it, witchcraft happens and you go faster.Ē J Clarkson.
Old 07-31-2019, 09:04 AM
Desertnate's Avatar
Desertnate Desertnate is offline
Spelling Impaired
Mein Auto: '16 435i
I have exhast soot build up in the tailpipes on both sides, so I am quite confident the left side does open under the conditions already mentioned.
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat. - Theodore Roosevelt
Old 07-31-2019, 09:19 AM
Of course youíll have soot on both sides. Iím saying when the M exhaust is popping itís only doing that on the right side.
Old 07-31-2019, 12:01 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
Can one of you exhaust conspiracy theorists explain to me why you think BMW bean counters - so tight that they would not even authorize felt flocking inside the dash cubbies on 2017 and 2018 5 Series - would sign on on paying for the valve, actuator, wiring, and programming if there wasn't a valid engineering reason for specc-ing them? Does anyone with a MPPK ever say, "Gosh, I feel like my car has 2 fewer horsepower today. That @#$%^&* exhaust flap must be closed again!" I know I've never had a complaint with the MPPK in our 340, and I'm amazed anyone here would.
Current BMW's:
2018 340i RWD 6MT MSport
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 07-31-2019, 02:54 PM
When I paid extra for the MPPK I wasnít told that it (seems) to affect only one side of the exhaust.
Old 08-01-2019, 02:54 PM
quackbury's Avatar
///Monkeyazz Duck
That's because it affects both sides. Always has. Always will.
Current BMW's:
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 08-01-2019, 04:03 PM
Hey Quack, the left pipe sounds the same as the right? No, of course not.
Old 09-07-2019, 05:43 PM
iCar Pro and OBD.Maven
In addition to using Carly for BMW, I also use an iCar Pro adapter (about AUD30/USD20) and the OBD.Maven app (free from Play Store).
The iCar Pro will connect using an Android or iOS smartphone/tablet and will use WiFi or Bluetooth. I use BT and it connects instantly. Moreover, I can add it as a trusted device to Smartlock .... meaning the connection stays live even if the phone's display is off.
Opening the rear exhaust flapper actuator valve is a one click operation.
No need to buy a dummy plug (BMW Part No. 18302411427) with the need to tie a piece of wire to hold the actuator in the open position once you have opened it electronically with the spring removed.
exhaust, flap, performance
