Oil - Bimmerfest - BMW Forums
Old 09-05-2019, 01:00 PM
Danaman Danaman is offline
Mein Auto:
Oil
What kind of oil do you use in 2015 320i
Old 09-05-2019, 01:41 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
Originally Posted by danaman View Post
what kind of oil do you use in 2015 320i
bmw
Old 09-05-2019, 05:46 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
What does your owner's manual recommend? There are tons of oil threads on this forum and over here - https://f30.bimmerpost.com/forums/fo...play.php?f=437
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 09-05-2019, 05:47 PM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
Get Castrol 0W40 in local Wal Mart.
Old 09-08-2019, 08:28 PM
Colossus Colossus is offline
Mein Auto: 2007 BMW 328i
I just went to Walmart today to buy some Castrol, and apparently it is no longer LL-01 certified. Still said European Formula, but no mention of BMW on the front, and no LL-01 rating on the back. So what oil can we easily buy now?
Old 09-08-2019, 11:00 PM
Oil
If you are not under warranty, use that Castrol 0W40. BMW is not certifying LL01 anymore and Castrol slightly changed formula in that oil so it has to be approved again. But, BMW is not doing it anymore. Castrol 0W40 is approved for MB 229.5 which is far more stringent specification than LL01. Now, if you are still under warranty, get Castrol 5W40. But, it is mediocre oil in every aspect.
Old 09-09-2019, 10:38 AM
namelessman namelessman is offline
Mein Auto: bimmer
229.5 is better than LL01 except in oxidative thickening, while 229.51 is better than LL01 in all aspects, but 229.51 is low-SAP and for diesel only.
Old 09-09-2019, 02:01 PM
Difference on oxidative thickening is absolutely minimal between MB229.5 and LL01. MB229.51 is NOT only for diesels. It is ACEA C3 oil and has lower SAPS. BMW and MB still donít recommend using oils like that (which would be LL04 on BMW side) in gas engines although the US moved to ULSG on 01/01/2017. VW thinks it is OK.
Either way, using MB229.5 (Castrol 0W40) in 320i is perfectly fine.
Old 09-09-2019, 02:21 PM
Mein Auto: bimmer
The US gasoline sulfur content is still pretty high even with latest regulation, e.g. US mandates 10ppm average but still allows 80ppm max at gate, and 95ppm max downstream. Euro gasoline standard is 10ppm max.
MB also disagrees with using 229.51 for non-diesel by stating this on their USA approved engine oil lists:
"Starting with MY2007 diesel engines must use only 229.51 approved engine oil. 229.51 is only approved for diesel engines."
Old 09-12-2019, 01:37 PM
insanecoder insanecoder is offline
Mein Auto: 340i sDrive
Ll-01
