Need new brakes. "M Performance" - Bimmerfest - BMW Forums
Old 07-15-2019, 05:19 AM
tlester tlester is offline
Mein Auto: 2001 330i
Hi all -
I need new breaks and probably rotors (I have that "pulsing" break response which is probably a warped rotor).
My breaks are "M performance". On ECS Tuning, I see options for "M Sport", "OE", and "Performance". But not "M Performance".
Hawk Front HPS 5.0 Performance Brake Pad Set <-- Is that going to fit?
Old 07-15-2019, 05:51 AM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
Originally Posted by tlester View Post
Hi all -
Get OE or ATE or Textar pads.
Sent from my iPhone using Tapatalk
Old 07-15-2019, 03:56 PM
mbanks21 mbanks21 is offline
Mein Auto: 335i
Hi all -
What vehicle is this for?
Old 07-15-2019, 04:36 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Some observations:
  1. HPS 5.0 is a pad compound (friction material). Pad sets using that compound are available for many different cars. If you identified your car correctly when you searched for pads to fit your car, then it will fit.
  2. Are you replacing only the front pads, or front and rear? If the former, use only BMW or OEM pads. Do not mix significantly different pad compounds.
  3. My thoughts on various Hawk compounds can be found here.
  4. Rotors rarely warp. The pulsation often misdiagnosed as a warped rotor is more often than not caused by deposits of pad material on the rotor surface. Bedding a new set of pads (or re-bedding the existing ones) will often cure it.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 07-16-2019, 07:06 PM
Originally Posted by Zeichen311 View Post
Some observations:
Putting more aggressive pad on front is fine.
Putting it back is when trouble starts.
Old 07-16-2019, 08:34 PM
Zeichen311's Avatar
In theory. But the relative responses of the compounds in question here change with pad temperature.
When the brakes are cold, the HPS 5.0 will not bite as hard as the OE pad formulation. So with Hawks up front and OE out back, the effect is that the rear momentarily does have the more aggressive compound. Bad juju. When the brakes gather some heat, the balance shifts the other way, but not as much because HPS 5.0 is a fairly mild pad upgrade. Putting OE on the front and a "performance" pad on the rear reverses all of the preceding.
In reality, the DSC system will probably smooth over most of that because the differences between the pads in question are moderate. However, it also means the fore-and-aft brake bias no longer matches any assumptions built into the DSC control models, which means it may not respond/handle optimally in an emergency.
Bottom line is that someone who asks "will HPS 5.0 pads fit my car" is not (yet) in a position to be experimenting with brake bias. So, absent that experience or need, the smart advice is "do not change brake pad brand/type unless changing pads at all four wheels."
BMW CCA
Old 07-17-2019, 12:32 AM
I understand that, though mildly upgraded pads are pretty good in response. Still, my argument is that in slick and wet conditions, more aggressive response in the back might create issues. DSC could attempt and maybe mitigate to certain extent, but laws of physics are still there.
I am not big fan of new compound on F30. Not sure whether ATE or Textar offer more bite?
Old 07-17-2019, 09:49 PM
pdxway's Avatar
pdxway pdxway is offline
Mein Auto: 2013 328i
I got my pads from Amazon for ~$80 total last November and installed the pads myself:
https://www.amazon.com/gp/aw/d/B01LY...b_b_asin_title
https://www.amazon.com/gp/aw/d/B01CF...b_b_asin_title
Still work just fine for day to day driving and highway driving.
Old 09-09-2019, 11:05 AM
NormWild NormWild is offline
Mein Auto: 2016 435i Xdrive
My wife's 345i has got some serious pulsing right now. The place I purchased it is going to "cut" the rotors for free, but this is a solution I have never been fond of. BMW wants $225 per rotor which insane. I found these on Amazon and the price is right, I guess they will work? Dealer says unless they are drilled/slotted from the factory they all had 340mm rotors.
https://www.amazon.com/dp/B0741R67T6...ustomerReviews _sl_
Old 09-09-2019, 12:23 PM
namelessman namelessman is online now
Mein Auto: bimmer
Is it 435i instead of 345i? M or non-M?
The front rotor is 340x30 for non M-sport($140 online), but M sport is 370x30.
Old 09-09-2019, 03:08 PM
Yes, I am stupid, 435i. Thanks, it does have some M badging, like on the door sill, but the rotors are not drilled/slotted, so assuming 340mm.
