Instrument Cluster Issues - Bimmerfest - BMW Forums
Old 07-13-2019, 04:43 AM
riley1550 riley1550 is offline
Mein Auto:
My Instrument cluster going a bit nuts. A lot of warning lights blinking on and off. Also - the needles for tach and mph spike up and down.
Anyone have suggestions ? Does 2014 X1 have a voltage regulator or is it built into alternator. Any ideas on where to start looking ?
New to BMW
thanks for any Help
Old 07-13-2019, 10:04 AM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
Does it do this with the engine running?
Could be low battery?
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 07-13-2019, 10:33 AM
Mein Auto:
yes does it with engine running charged battery
Old 07-13-2019, 11:30 AM
Mein Auto:
Battery checks out ok Alternator also according to multi tester
Old 07-13-2019, 11:32 AM
Mein Auto:
Also tried a donor cluster and same exact thing - so not the cluster
Old 07-15-2019, 11:27 AM
Chicone Chicone is offline
Mein Auto: 2015 X1 35i X Drive
have you pulled the codes?
Steve
2015 BMW X1 35i MSport
Old 07-15-2019, 10:45 PM
stonex1's Avatar
Good question.
2013 X1
Old 07-16-2019, 08:44 AM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
FWIW, I've experienced this in non-BMW vehicles and it's always been battery / alternator / electrical-related. Highly recommend pulling any stored codes.
Not even sure if -40 degrees is cold anymore ?
Old 07-16-2019, 08:49 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
When this happened on my past e60 530xi it was an indicator the battery was failing. Testing with a multi-meter isn't always an accurate indication of "battery health" on newer BMWs.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 07-16-2019, 02:34 PM
Mein Auto:
Thanks everyone - I have a foxwell nt510 scanner coming Ill check for codes and report what I get
Old 07-16-2019, 03:22 PM
stonex1's Avatar
Could also be a bad ground connection somewhere near the battery.
2013 X1
Old 07-18-2019, 06:54 AM
Mein Auto:
Ok I hooked up a foxwell nt510 scanner. Got a number of codes that erased. 2 codes didn't erase
JBE - Junction box electronics shows Faultl2 not sure if that's a one or L after the t
ABS-DSC Dynamic Stability Control shows Faultl6
Any help of suggestions ? thx to all
Old 07-18-2019, 10:47 AM
Mein Auto:
After I started car again all the faults came back Almost all the modules have a fault except fuel pump, moonroof
I think Im in over my head !!
Old 07-19-2019, 08:16 AM
Mein Auto:
Can anyone Help ??
Codes C907 Present - JBE K-Can Communication fault
C91E not Present - No message(terminal Status, ox1 30)receiver JBE, transmitter
CAS
A733 not Present - JBE DC/DC converter
Old 07-19-2019, 09:01 AM
You said ALL modules have faults again ? Again, this is super characteristic of a bad battery.
Old 07-19-2019, 09:09 AM
Mein Auto:
I took the car to advanced auto and they tested battery - said it was good. Im also getting the needles - speedometer and tach spike up and down maybe some type of voltage surge ??
Old 07-19-2019, 09:51 AM
Yeah, ummmmmm, Advanced Auto isn't really who I would trust to diagnose my BMW. Just saying.
Old 08-03-2019, 07:54 AM
Portly Portly is offline
Mein Auto: X1 Xdrive28i
I had something similar happen when the TPMS receiver shorted out. Took out the CANBUS system (which shouldn't be possible, but that's BMW...) and every other module freaked out. Tach and speedo swung widely, warning lights flashed on and off, Idrive kept rebooting.
Fortunately the car was still under warranty, so the dealer took care of it. They replaced the bad receiver - and then had to program the car to accept the new module.
_Jeff
