Wastegate adjustment - Bimmerfest - BMW Forums
Old 08-20-2019, 01:05 PM
Arjon Arjon is offline
Mein Auto:
Hello,
I canít understand how this website work,
Please i need your help. I need to adjust wastegate in my bmw x1 25D twin power turbo.
Waiting for your reply
Best Regards
Old 08-24-2019, 03:07 PM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
Well, welcome to the forum. You did just fine, as you posted in the correction section
Why do you need to "adjust wastegate" ? Is there an issue you are experiencing that leads you to believe that you need your turbo's wastegate adjusted ?
Not even sure if -40 degrees is cold anymore ?
Old 08-26-2019, 11:06 AM
wvadam wvadam is offline
Mein Auto: X1 2.0L xdrive
I am also wondering why you are looking to do this. Typically when the waste gate is rattling, which has been know to happen on high mileage turbos, it means the bearing that is holding it is worn out and loose and needs to be repaired/rebuilt. Typically people just remove and replace the whole turbo assembly with a rebuilt unit from what I have seen. I have never had this issue myself.
Old 08-26-2019, 11:12 AM
You got me curious and it seems you can also get a brand new Mitsubishi N20 turbo aftermarket for about half of what the oem costs if that helps.
https://www.ecstuning.com/b-mitsubis...657635803~mbt/
