335 Hesitation on acceleration - Bimmerfest - BMW Forums
Old 08-26-2019, 08:13 AM
daggs daggs is offline
Mein Auto:
I have been experiencing some odd hesitation while I accelerate. It seems to only happen when in sport or sport + and only when I step on it. Slow acceleration doesn't seem to be an issue. It feels like the car is accelerating in steps, like it will pull, then briefly hesitate and then pull some more.
Is there anything that I could check myself to see what the issue would be before I bring it into the shop to get it checked out?
It is a 2015 335 xDrive with about 40k miles on it. No mods and regular maintenance has been done to date.
Old 08-26-2019, 08:37 AM
CoolShirtDude CoolShirtDude is offline
Mein Auto: 2011 BMW X3 2.8i F25 N52
You might want to try and read the codes, you will need a scan tool that can read BMW codes, you might check with auto parts stores in your area, they might have one that will read Bmw codes.
Several solutions for a code reader, BimmerLink and an adapter from Amazon is easy to use and affordable. This allows you to use an app on your phone to read and reset codes.
Once you get a code, use that as a starting point.
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 08-26-2019, 10:30 AM
Mein Auto:
This is what i got for error messages. A lot more than i thought i would find! Does anything in there pop out as serious or concern with what my issue is?
Info memory
AIRBAG
1 error
C95423: ICM: STEERING ANGLE FRONT AXLE EFFECTIVE - SIGNAL INVALID
ZGW
15 errors
1000FF: VCM LOGGER ERROR MEMORY ENTRY
100CFF: CAN LOGGER ERROR MEMORY ENTRY
1011FF: LOGGER ERROR MEMORY ENTRY FOR OTHER ZGW COMPONENTS
101008: UNRESOLVABLE AMBIGUOUS ROUTING - SG NOT IN THE SVT TARGET TABLE 101010: SIF ERROR
101012: TM ERROR
100600: FLEXRAY PROTOCOL STARTUP TIME IS TOO HIGH
100601: UNEXPECTED ASYNCHRONOUS STATE ON FLEXRAYBUS
100100: CONTACT TO FZM SLAVE LOST
100104: HW WECKGRUND ZGW
100300: COMMISSIONING COULD NOT BE PERFORMED AS TAS ALREADY EMPLOYS
100000: VCMSOFTWAREERROR
100001: VCMRESULTSVTCHECK - IDENTITY CHECK: DIFFERENCES HAVE BEEN DETECTED BETWEEN SVT ACTUAL AND SVT TARGET.
100203: DM SOFTWARE ERROR INFO WARNING
100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED
MOTOR
18 errors
1FB601: CHECK CONTROL MESSAGE (ID 450): AUTO START STOP FUNCTION DISABLED
190302: TANK VENTILATION AND PURGING AIR SYSTEM, MICRO-STAIN: LEAKAGE GREATER THAN 0.5 MM
21A023: INTERNAL COMBUSTION ENGINE: FAULTY START OR ENGINE FAILURE WITHOUT DRIVER INFLUENCE
140010: COMBUSTION MISFIRE, MULTIPLE CYLINDERS: DETECTED 140510: COMBUSTION MISFIRE, CYLINDER 5: DETECTED
140002: COMBUSTION MISFIRE, SEVERAL CYLINDERS: EXHAUST GAS DAMAGING AFTER STARTING PROCESS
140502: MISFIRING, CYLINDER 5: DAMAGING TO EXHAUST AFTER STARTING PROCESS
231501: ERROR MEMORY ENTRY: TRANSMIT BUFFER FULL
CDB604: FA-CAN, MESSAGE (TERMINALS, 0X12F): MISSING
CDA422: FLEXRAY, EMBASSY (STATUS DOOR SENSORS SECURED, 256.3.4): MISSING
EGS
2 errors
420801: SHIFT-BY-WIRE: INFO COUNTER FOR AUTO-P WHEN LEAVING THE VEHICLE 421732: SHIFT-BY-WIRE: INFO COUNTER FOR HOLD-N
ICMQL
10 errors
480115: DRIVING DYNAMICS SWITCH - FORCED ACTIVATION DSC
48279A: HSR FUNCTION - AUTOMATIC ACTIVATION OF DSC ON HSR MALFUNCTION 48276E: AUTOSAR - STANDARDCORE - NON-VOLATILE MEMORY - INTEGRITY FAILED 4827F9: QDM-SKR - RAD RADIUS CORRECTION FACTOR - LEARNING CONDITION 2
4827F8: QDM-SKR RADIAL RADIUS CORRECTION FACTOR - LEARNING CONDITION 1 48260D: DRIVING CONDITION OBSERVER (FZB) - VCH AT UPPER LEARNING LIMIT 482653: SWIM ANGLE ESTIMATOR - RESTRICTED MODEL VALIDITY
482651: FLOATING ANGLE ESTIMATOR - INPUTS NOT VALID SBS
4827B3: INTERNAL CONTROL UNIT - UNDERVOLTAGE AT TERMINAL 30
4827A0: SBS FUNCTION - ROLL RATE - ERROR AMPLITUDE DUE TO SUSPECTED ERROR
DSC
1 error
480AB5: TRANSFER CASE LONG-TERM PROTECTION FUNCTION REQUESTED BY THE LMV
EPS
1 error
482451: SENSOR - ROTOR POSITION - STEERING ANGLE - LOSS OF MULTITURN VALUE
AMP
1 error
930002: TRANSMITTER RECEIVER MODULE (FOT): TEMPERATURE EXCEEDS THRESHOLD 1
CAS
6 errors
03001B: FH FA: REVERSING IN EMERGENCY MODE
03009A: FH BF: TRAPPING CASE DETECTED IN PANIC MODE 03009B: FH BF: REVERSING IN EMERGENCY MODE
804000: RESET FOR UNKNOWN REASON
804002: RESET BY EXTERNAL
804029: NVM_QUEUE_EEPROM
FZD
3 errors
801A0E: NVM_E_INTEGRITY_FAILED 801A20: CAN_E_TIMEOUT
801A57: ANTI-THEFT ALARM: DEACTIVATION OF IRS AND TILT SENSOR BY CUSTOMER FUNCTION
GWS
1 error
5E0005: RESET RECOGNIZED
KOMBI
6 errors
B7F601: COMBI: ERROR READING THE EEPROM DATA
B7F60C: COMBI: PERSONAL PROFILE CONFIGURATION ERROR
930041: FUNCTION BLOCK: DOES NOT SEND ANY VALUES DESPITE NOTIFICATION
E114C2: SIGNAL ERROR IN THE MOST MESSAGE TERMINAL STATUS
E12C2F: INTERFACE HU (ACKNOWLEDGMENT REQUEST COMBINATION, 0X172): SIGNAL FAULTY
B7F757: CBS RESET DETECTED
ECALL
10 errors
610019: NVM INTEGRITY CHECK FAILED
E14405: TIMEOUT CAN MESSAGE GPS_CTI_MOST
E14406: TIMEOUT CAN MESSAGE GPS_PO_EXTS_MOST
E14409: TIMEOUT CAN MESSAGE TERMINATION
E14426: INVALID SIGNAL IN CAN MESSAGE GPS_PO_EXTS_MOST E1442C: INVALID SIGNAL IN CAN MESSAGE STAT_ZV_KLAPPEN E14413: TIMEOUT CAN MESSAGE STAT_GANG_RUECKWAERTS E14414: TIMEOUT CAN MESSAGE STAT_ZV_KLAPPEN
E14437: INVALID SIGNAL IN CAN MESSAGE GPS_PO_MOST
610026: NAD SOFTWARE RESET
FRM
10 errors
8032B5: REAR ULTRASONIC SENSOR LEFT LEFT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032BD: REAR ULTRASONIC SENSOR CENTER LEFT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032C5: REAR ULTRASONIC SENSOR CENTER RIGHT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032CD: REAR ULTRASONIC SENSOR OUTSIDE RIGHT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032D5: FRONT ULTRASONIC SENSOR OUTSIDE LEFT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032DD: FRONT LEFT CENTER ULTRASONIC SENSOR: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
8032ED: FRONT ULTRASONIC SENSOR OUTSIDE RIGHT: ACOUSTIC OR ELECTROMAGNETIC INTERFERENCE
804824: BUFFER FOR OUTGOING ERROR MESSAGES IS FULL
8049E5: CNM_E_NETWORK_TIMEOUT
E59418: CAN MESSAGE, VEHICLE STATUS (FZZSTD): INVALID SIGNALS
KLIMA
3 errors
078022: MESSAGE (VEHICLE CONDITION, 0X3A0) IS MISSING 07802B: COMM_E_NET_START_IND_CHANNEL_0
078042: IPDUM_E_TRANSMIT_FAILED
Old 08-26-2019, 10:46 AM
A little overwhelming....
I think I would start looking at the misfire on cyl 5. Depending on age, plugs and maybe coils would
Be a starting point. You can move a coil to another cylinder and see if the error follows the coil.
Most often, as plugs wear, the gap increases, this forces the coil to use more power to bridge the gap.
The rest I would clear and see if they come back. Low battery power as in worn battery can toss a lot of errors.
Old 08-26-2019, 10:56 AM
Mein Auto:
Thanks for the info, I am going to replace the plugs and coils regardless if that is the issue and clear everything out to see what happens. I'll keep you updated.
Thanks.
Old 08-26-2019, 11:13 AM
You might want to check fcpeuro.com for parts and pricing. Check out their lifetime warranty.
Old 08-26-2019, 01:52 PM
Mein Auto:
Thats who i ordered them through! Thanks!
Old 09-10-2019, 07:31 AM
Mein Auto:
So i finally got around to replacing all the spark plugs and coils. They sent the wrongs ones the first time and I also didn't have the proper spark plug socket. Anyway, i got them installed and the car definitely feels much better. I cleared all the errors, but I still seem to be throwing a few codes and still with Cylinder 5. Which one is number 5? Towards the back or towards the front? Most of these errors seem like no-issues but im still concerned about the Cylinder 5 issue. Any thoughts, or just ignore it if the car drives and feels fine?
MOTOR
18 errors
GREATER THAN 0.5 MM
STARTING PROCESS
