Two part problem-Coolant & Oil!??? - Bimmerfest - BMW Forums
Old 09-03-2019, 10:34 AM
8eth 8eth is offline
Mein Auto:
I have a 2014 BMW X1 Sdrive. I purchased about a month ago, it had a great service record... always serviced at the dealership on time. So everything appeared great, until I was driving up to Park City, Utah. The car over heated I pulled over and had it taken back to my house. It pulled the code P0128. I changed the thermostat as well as the expansion tank, replaced the coolant and bled the coolant system twice. I cannot see any visible coolant leaks, I was thinking head gasket??? But I do not see the sign of coolant in the oil (milky or cloudy oil). The car drives fine around town since I changed the thermostat and expansion tank, but when you get on the freeway it starts to overheat. When I pulled over and let it cool down I checked the expansion tank and it was not dry like it was previously before I replaced the thermostat and expansion tank. I have this feeling that this is a two fold problem... I feel like there is an oil problem as well, but for whatever reason it is not sending a code for it. I feel like it is low on oil but the sensor is not detecting it, the oil sensor says it is "OK" and is at the Third bar, but the strange thing is that even when I added more oil it stayed at the same level... but I do want to mention that when I did add oil it was very strange I did see oil coming out in the front side but I couldn't see exact location. I DO know that too much oil is just as bad as not enough oil. I really do hate that the only way to check the oil level is by the sensor, there really should be a manual way to check it as well ! I would just go get an oil change to be sure, but I don't want to do that just to have another problem that basically makes the oil change a waste of time, like blown head gasket. I have been trying to find any other posts regarding this type of issue, but I have been unable to find a post about an oil sensor manfunctioning that the "oil level is good when it's not" only that the oil sensor says "oil level low when it's not" ANY help would be greatly appreciated! *** I forgot to mention that the water pump and fan work. *** Just checked this morning and the expansion tank is dry!!! UGH!!!!
Old 09-03-2019, 11:02 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Are you using a generic scanner or a BMW specific scanner? I would do an oil change and measure precisely how much comes out. Then add precisely the right amount. Also. I think it’s possible your coolant temperature sensor could be bad. Did you get an “engine overheated” warning?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-03-2019, 03:12 PM
Mein Auto:
It was a generic scanner. I did notice upon further inspection that the new expansion tank bottom connection was ill fitting and was leaking from that area... so I replaced the expansion tank back to the old one and it is not leaking anymore from that area. I am now going to take it for a test drive. I did get an engine overheating warning both times. I agree with your idea about the oil change that is definitely a must... it's so frustrating to have to do that just to check the amount of oil in the engine. Thank you!
Old 09-22-2019, 06:12 AM
alibou54 alibou54 is offline
Mein Auto: X3
Hello, did you check the recycling exhaust gaz cooler. It is probably the source of getting the coolant to low because this device uses the coolant to cool the recycled exhaust gaz. I hope it will help.
Old 09-22-2019, 06:25 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
You wrote, "I purchased about a month ago, it had a great service record... always serviced at the dealership on time." ?? From a BMW dealership ??
If the latter was the case most will offer a limited "warranty" on used car purchases ... 30-60-90 days ... UNLESS SOLD "AS-IS".
If I were you, and a recent pre-owned BMW vehicle purchased at a BMW dealer had problems as serious as you noted I'd go back to them for some remedy & financial /good-will consideration. That said, now that you've begun some DIY parts replacement repair attempts you may be on your own with this one ?!?!
If you were reluctant to go to the selling dealer perhaps you should find a qualified BMW independent mechanic who can sort through this situation.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
coolant, expansion tank, head gasket, oil sensor, over heating, thermostat, x1
