BMW Lightning Adapter Cable - Bimmerfest - BMW Forums
Old 05-09-2017, 08:51 AM
xxthe_remedyxx xxthe_remedyxx is offline
Mein Auto: 2014 320i
Anyone know where I can find this? There's a picture of the Lightning adapter on one of the pages on the site, but I cannot for the life of me find it anywhere. It would be great if I can get this for my iPhone 7 and not have to use a 30-pin to Lightning adapter on top of the 30-pin adapter.
http://imgur.com/a/oEZ7h
Old 05-09-2017, 08:59 AM
FCBayernFTW's Avatar
FCBayernFTW FCBayernFTW is offline
Extended Euro Delivery
Mein Auto: '18 X3
Do our cars have two USB ports? How is this better than an original apple cable?
Sent from my iPhone 7+ using Tapatalk
-2015 BMW ///M4 Austin Yellow (sold)
-2017 Mazda CX-5 Grand Touring Soul Red Premium
-2018 BMW X3 xDrive30i Phytonic Blue Metallic - ZCV, ZDA, ZPK, ZPP, ZPX
Old 05-09-2017, 09:01 AM
Nope just one. The only difference would be that they swapped the 30-pin on the original cable to a Lightning connection. This is good because I wouldn't have to use the Apple 30-pin to Lightning adapter.
Old 05-09-2017, 09:02 AM
Mein Auto: '18 X3
Ok I'm lost.
Good luck in your search!
Old 05-09-2017, 09:06 AM
Ok I'm lost.
The original adapter has one 3.5mm male and one 30-pin iPhone/iPod connector. For people like myself with newer iPhones, we have to use a 30-pin female to Lightning male adapter in order for it to plug into the phone.
https://www.apple.com/shop/product/M...30-pin-adapter
This new adapter would bypass the adapter and plug directly into the iPhone.
Old 05-09-2017, 09:12 AM
smak91 smak91 is offline
///Member
Mein Auto: 2014 335i xDrive
Whats wrong with using a USB to Lightning cable?
Isn't that what you're looking for?
'14 Porsche 911 Turbo S, Jet Black Metallic, Leather interior in Black/Bordeaux Red, Sport Chrono
'14 BMW 335i xDrive Sport Line, Jet Black, Black int, Premium / Cold Weather / Nav Pkg - MPPK/MPE
'16 BMW X1 xDrive28i, Glacier Silver Metallic, Black int, Premium / Cold Weather / Luxury Pkg
RETIRED:
'13 BMW 328i xDrive Sport Line, Jet Black, Black int, Premium / Cold Weather / Nav Pkg
SOLD:
'10 328i xDrive, Jet Black
'07 328xi, Black Sapphire Metallic
Old 05-09-2017, 09:24 AM
I'm trying to get rid of the Apple Lightning 30-pin adapter for a more streamlined fit. Less hardware and a point of failure removed.
Old 05-09-2017, 09:46 AM
2015msport 2015msport is offline
Mein Auto: 2015 328xi Msport
https://www.monoprice.com/product?p_id=12843
Old 05-09-2017, 09:54 AM
Originally Posted by 2015msport View Post
Thank you for the link but I have a ton of Lightning cables. I have a 2014 320i with no NAV and no Bluetooth audio. The only way this works is if I have the BMW adapter that plugs into the 3.5mm audio and USB in my center console.
Current config:
https://xoutpost.com/attachments/x5-...wed-apple.jpeg
New cable:
http://i.ebayimg.com/images/i/182397...-1/s-l1000.jpg
Old 05-09-2017, 09:55 AM
Looks like I found it:
https://www.getbmwparts.com/partloca...catalogid=4462
Old 05-09-2017, 10:03 AM
rounderman rounderman is offline
Mein Auto: 2019 X2 M35
I could also suggest a Bluetooth dongle. I use Tune2Air got it on Amazon for less (not much) I use it with Android, works better with IOS, plugs into USB and 3.5mm jacks
Old 05-09-2017, 10:05 AM
Thanks bud, I actually own one of those but I find the reliability is so-so. Sometimes the music cuts off and skips, other times I have to re-pair the device with my phone for it to be recognized by the iDrive. I'm thinking a plugged in connection might be more reliable.
Old 05-09-2017, 10:09 AM
I have had no connection issues (yet) on my second android phone (both Samsung, cue the fire jokes). Wired is typically way more reliable than radio for signal transmission. Hope it works for you as expected
Old 05-09-2017, 12:04 PM
BijanO BijanO is offline
I got a y cable and promptly took it back. No volume control, so it sent such a hot signal to the audio system, causing terrible distortion. Got my car codes for enhanced BT, problem (thankfully) solved.
Old 05-09-2017, 02:16 PM
Michael Schott Michael Schott is offline
Super Moderator
Mein Auto: 2017 VW GTI Sport MT
I had this issue and used an adapter but ultimately I put all my music on a USB drive and eliminated use of the cable. You may be using other features so this may not be a good solution.
Old 07-11-2017, 10:53 AM
plc001 plc001 is offline
Mein Auto: 2003 Z4 2.5I
Did you get it, did it work? I just picked up a new to me 2014 328I and i'm looking for the same. Thanks.
Old 07-11-2017, 11:34 AM
chillg8r chillg8r is offline
Mein Auto: 2014 420i
this is what I am using and while it is not as sleek as a dedicated adapter it's also not $88 and it works perfectly. It allows me to stream music from my iphone.
http://www.ebay.com/itm/OEM-Apple-MD...MhEH5UnD1ydVYQ
Old 07-15-2017, 08:40 AM
Thanks, I tried Lightning to 30-Pin Adapter, but is not OEM Apple. It charges the iPhone 7 but the USB is not active.
Could it be the adapter?
Thanks.
Old 07-15-2017, 12:35 PM
Thanks.
Did you also plug in the aux plug? If so then I guess it could be the adapted as mine is OEM and it works.....
Old 07-15-2017, 12:48 PM
Ok, thanks. I'll pick one up. Yes, I also plugged the aux.
Old 07-15-2017, 05:22 PM
tex2670's Avatar
tex2670 tex2670 is offline
You Don't Need to Know
Mein Auto: '14 328xi Sport Line
[Deleted]
2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Sport Automatic Transmission
Old 07-16-2017, 05:07 AM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
OP don't waste your money. I have been using the OEM Apple USB cable in my E90 since I purchased the car. Both the 30pin and now lightening. Since they pile up with every phone upgrade I keep on full time in my car. If it works in my E90 it has to work with all F30's. All my music is on my phone and I run it through USB to keep my phone charged while listening.
2020 X5 xdrive 40i Tanzanite Blue / Coffee Vernaska
2011 328xi. Space Grey
Old 07-16-2017, 10:01 AM
elistan elistan is offline
Mein Auto: F30 328i, AP1 S2000
Unfortunately it doesn't work that way. Some F30s, depending on how they were optioned, cannot play music off an Apple device using just a USB cable. A special y-cable from BMW is required, which connects to the phone at one end, and has both USB and headphone connectors on the other end.
OP already found listings for the Lightning based y-cable, and it's nearly $100 unfortunately. There doesn't appear to be any Apple or other 3rd party made equivalent.
Old 07-16-2017, 10:05 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
To use the white Apple USB cable directly in any BMW it must be equipped with both a Combox and BMW Apps. Otherwise the white USB cable will not work directly -the OEM USB/AUX cable must be used.
BMW OEM Audio PnP integration
www.TechnicPnP.com
[email protected]
Old 07-16-2017, 10:55 AM
3284me's Avatar
Seems odd that my 6 year old car has no issues with the Apple OEM white cable. I don't have BMW Apps either.
