98 bmw m3 heating - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-23-2019, 08:53 AM
vnadonza vnadonza is offline
Vnadonza98m3
Mein Auto: m3
98 bmw m3 heating
help with my BMW 98 m3 heating. N0 heating inside but sometimes heating comes on and works. Anybody have this problem and was able to fix problem. Appreciate the help especially with weather.
Thanks,
Bimmerologist vnadonza 98M3
Old 02-23-2019, 09:25 AM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
Heater valve is stuck.
Old 02-25-2019, 04:52 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
BMWCCA HPDE Instructor
Mein Auto: 1998 BMW 328is
If the temp gauge is even a millimeter lower than 12 o'clock after about ten minutes of driving, your lack of heat is due to a thermostat that's stuck open. Very common in these cars.
If your temp gauge struggles to get to 12 o'clock or sometimes gets there but goes back down a bit, you need to replace your t-stat, not the heater valve.
1998 BMW 328is
1966 Pontiac GTO
Old 02-25-2019, 05:35 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
heater valves usually fail to "heat all the time".
first things first, check the coolant level. if it is fine, then proceed with karl's suggestions. an infra-red thermometer gun is a great way to get quick, accurate readings, and wil also work for ac diagnostics....
if you check the coolant level and it is low, then find and repair the leak.
please note, the plastic components are notorious for breaking, so if something like a connector is damaged, deteriorated, cracked, or otherwise in poor condition, replace *everything*.
these engines can be difficult to bleed, but it is possible. i use a funnel set up for bleeding the cooling system, others like to raise the front end. regardless, always double check after cooldown to ensure the coolant level is correct.
yes, it will be costly, but you will no need to worry about it for quite some time. otherwise, it's a ticking time bomb,....lots of links and hints in the diy sticky, even of you are not a diy'er.
good luck.
df
Old 02-28-2019, 01:59 AM
Screamin demon
Says not my last 3 beaters. Lol
Similar Threads
BMW E90 M3, E92 M3 Carbon fiber Interior Door Handles [email protected] Interior 0 01-08-2019 09:24 AM
BMW E46 M3 Carbon fiber Center Air Con vent [email protected] Interior 0 01-08-2019 09:13 AM
New Build - Constructive criticism very much welcomed dzhou102684 F80/F82/F83 M3 and M4 (2015 - Current) 68 12-30-2018 08:51 PM
Complete 2018 Model Year BMW Pricing and Ordering Guides - All Models tim330i Ask-A-BMW-Dealer 7 10-09-2018 12:15 PM
BMW drivers selected for Nürburgring 24 Hours tim330i Motorsports, Racing & Track 5 03-17-2004 07:37 AM
