Coolant pipe under intake - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-01-2019, 02:57 PM
bmwguy07 bmwguy07 is offline
Mein Auto: e36 m3, 323i,amg 95,
Anyone know the part numbers for the two rubber gaskets that go into the timing cover are? Iíve removed the timing cover to replace the timing guides and I would rather replace the two o rings.
Old 04-01-2019, 05:37 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
did you check real oem?? they should at least have the part number in a diagram.
are we talking 4 or 6 cylinder?? the only coolant pipe i can think of is on the 4cyl, which is plastic and should be replaced, but doesn't come with any o-rings from the dealer. (ask me how i know....) but is the best choice as vendors like uro are horrible with this part. (again,....ask me how i know....)
otherwise, if you have the old o-rings, most napa stores can match them up, and even easier with part numbers.
df
Old 04-01-2019, 06:02 PM
Old 04-01-2019, 06:03 PM
df
Hey df. Got another question. As Iím putting the cover on I noticed that the bottom of the timing cover sits on the oil pan gasket. I ran my fingers across and I donít feel much of the oil pan unfortunately. Do you think Iíll be safe using some gasket maker so it doesnít leak?
Old 04-15-2019, 08:12 AM
EyeDoc1 EyeDoc1 is offline
Transplanted JrzyBoy
Send a message via AIM to EyeDoc1
Mein Auto: 91 525i & 94 325is
I don't mind doing a little research but...
helpful is we have the complete specs of the E36 you're working on. Pelican and Real OEM are bookmarked for my rigs, and given you're posted here quite a bit, you probably know this. Just helpful
Similar Threads
Small coolant seep from heater inlet pipe crashbiggs E39 (1997 - 2003) 8 07-24-2018 03:53 PM
A.G.A Coolant Pipe 4 sale PAPER Tools and Miscellaneous 0 05-30-2018 06:13 PM
N62 Coolant return pipe(NOT THE TRANSFER PIPE). How to replace?! jjamison E60 / E61 (2004 - 2010) 2 03-30-2018 09:25 PM
E63/64 DIY: 645Ci Coolant Hose Replacement P.No.17127542540 (Above the throttle body) Hsurf 6 Series DIY 0 11-07-2017 02:11 AM
Edmunds Convertible review The BoatMan 3 Series & 4 Series 35 06-19-2002 09:13 PM
