Splash panel substitute? - Bimmerfest - BMW Forums
Old 01-20-2020, 06:48 PM
OakTone OakTone is offline
Mein Auto: 2006 E60 550i Sport
The big odd-shaped splash panel / belly pan on my E60 is disintegrating. It’s stupidly expensive as a new part and seems impossible to find used on eBay (at least on this continent), unlike the more common front center panel.
I’m not excited at the prospect of paying $250 for an OEM plastic cover in a spot on a 14-year-old car that literally *nobody* will ever see unless they have the car on a lift. Any suggestions for a cheap substitute? We’re lucky to have a dry climate here in California, but it does rain in winter, so I’d rather not leave it bare.
OakTone
2006 E60 550i Sport
Sent from my iPad using Tapatalk Pro
Old 01-20-2020, 06:52 PM
Doug Huffman's Avatar
Nuclear engineer
Never thought of it as an appearance issue.
Old 01-20-2020, 07:07 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Are you sure that picture is correct? I think what you pictured is metal. Do you need the metal cover or the plastic one?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 01-20-2020, 08:10 PM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Is there no way to repair it? Some aluminum sheet metal and some pop rivets for a tear should work.
Old 01-20-2020, 08:51 PM
tstiglich tstiglich is offline
Mein Auto: 2009 528i xdrive
Have you tried car-part.com?
Old 01-21-2020, 07:21 AM
kd7iwp kd7iwp is offline
Mein Auto: 2001 325i
I am soooo with you on this one. I looked long and hard for one since only about 1/3 of mine was left. It's even supposed to have a little air scoop in mine (for the transfer case I guess?). My dealer wanted $410 Canadian for one. I eventually found one from a RWD that more or less lined up but lacked the air scoop and a few screw holes. It would not line up at the front since subframe is different so I got a thin sheet of aluminum and with rivets i sandwiched the two plastic pieces with the aluminum. Seems to hold up fine and this way the replacement panel covers the rear 2/3 and my original covers the front part where it correctly attaches to my subframe. I was so annoyed by how expensive the piece is. Also seemed like I found three different part numbers and an error on realoem where it listed two parts for the automatic though I believe it meant one was for the manual. It also is really difficult to find the correct photos online as many have them listed with the wrong part number. All this to say, I appreciate what you're doing and good luck.
Old 01-21-2020, 07:26 AM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
I replaced mine at dealership prices. It was around C$300. Meh.
Old 01-21-2020, 08:48 AM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
I replaced mine with some sheet metal. Traced what was left of the old one, marked the holes, and cut it to shape. It fit easily.
I used stainless but if i did it again, I'd go aluminum.
Old 01-21-2020, 08:49 AM
mr magoo's Avatar
mr magoo mr magoo is offline
Mein Auto: 2000 528i
Freight kills
Hi I went through the same process. 2010 E61 535iX. Mine was torn down the middle. Don't remember dragging across anything. Tranny area wiring exposed to NE salt and slop. I fount a cheap one for $125, but shipping such a large object was steep so I bought from a local dealer $185.
Watch out for the fasteners. I forgot what I needed and ended up paying the dealer $60. It did save me time, though.
Just do it.
Old 01-21-2020, 09:20 AM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
I've seen after markets for the engine belly cover on ebay. dont recall tranny. I will be replacing my 2004 tranny belly cover in the near future. it is in good shape, but I am in the process of restoring my car to factory condition. it has one or 2 screw holes that are torn from abuse at the shop. I hate when mechanics tear stuff up on your car and dont tell you. I have the new one in hand, but have a few other items to get out of the way before replacing. not sure what it would cost to ship, but would sell it to you cheap to cover my time plus what ever it costs to ship . my new cover is a bit different than the old, make sure it would fit. the new ones have a different oil access panel. that is about it from what I have noticed. just received it a few days ago. if you buy from pelican, and load on some other parts, they don't kill you on shipping. check them out too.
EDIT: BTW, the new ones are not entirely plastic. They are sort of fiberglass/fuzzy coating. Can't describe it all that well, but it would be shame to get oil on it. Its so pretty.
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 01-21-2020, 10:47 AM
scottalexander scottalexander is offline
Mein Auto: 2010 bmw 528i
Regarding your transmission shield, its time to get innovative.
There are plenty of construction wholesalers that sell heavy weight plastic sheets.
Buy a nice weight plastic sheet and superimpose the existing transmission cover over it as a template.
With all the money you'll be saving you can buy a brand new jig saw to cut out and customize the new plastic sheet.
The newer transmission covers are also sprayed with anti corrosive under coating spray. Buy some of that spray. Waa laa you just saved a ton of money and beat BMW at their own game.
Old 01-21-2020, 05:39 PM
This thing is plastic, “underfloor coating” in BMW-speak. It has the “trap door” for oil changes that nearly everyone’s E60 seems to be missing.
You may be thinking of the metal reinforcement plate that bolts to the subframe. It’s normally hidden by this piece in the wide front part. Both have a cutout in the middle for the oil filter housing and drain plug to stick down on the V8s. (The metal piece is imprinted with a stern warning never to drive without it in place.)
OakTone
2006 E60 550i Sport
Old 01-21-2020, 05:53 PM
Good idea. The long tongue pointing toward the rear of the car is OK. The wide front part around the OFH is in the worst shape. It crumbles easily. I think it’s cumulative damage from oil leaks over the years (shocker). In fact the reason I’ve been under there is preparing to tackle the dreaded alternator bracket gasket job.
The main hassle is trying to get fasteners to keep it in place and not just tear through the plastic, leaving the thing flapping and clattering in the breeze at speed. A little reinforcement might do the trick if I can figure out where to best fasten it.
OakTone
2006 E60 550i Sport
Old 01-21-2020, 06:08 PM
This is the purest DIYer approach: Pay a lot less for raw material and end up with a new power tool in the process. Win/win!
OakTone
2006 E60 550i Sport
Old 01-22-2020, 05:54 AM
mtnbimmer mtnbimmer is offline
Mein Auto: 325ix, 530xi
Amazon has cheap Chinese plastic substitutes. I bought one as a short term solution. After you receive it, you know why the factory one costs more but it works.
Old 01-22-2020, 06:04 AM
Nuclear engineer
I see a business opportunity for Panzer Plate. Certainly BMW motors don't hang as low as VW but they cost more.
Old 01-22-2020, 08:39 AM
I'm lucky I work in manufacturing. Sheet metal and fasteners are basically free for me. Find a sheet of aluminum, not plastic. Our standard thickness here at work is 0.051", which is nice and rigid. I reused the existing mounting holes and supplemented with some tinnerman clips when required.
https://www.metalsupermarkets.com/me...61-flat-sheet/
Old 01-22-2020, 06:43 PM
Yes, I got one of these a while ago to replace the front center splash panel. It was so flimsy it was hard to even fasten in place. Waste of time and money. Ended up getting a good price on a used OEM panel on eBay. Haven’t had the same luck with the belly pan.
Old 01-22-2020, 06:55 PM
Sounds like a good plan. I’m a novice when it comes to fabbing replacement parts, but aluminum is soft enough that even I should be able to work with it.
OakTone
2006 E60 550i Sport
