M5 buying guide - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 01-09-2019, 01:03 PM
johnni.english johnni.english is offline
Mein Auto:
M5 buying guide
Hello to everyone, new member here. First let me tell you about the cars I had. E46 320i, e36 328i, e39 540i, e60 525d, e39 525d and current f10 530d. I'm looking to make a comeback in the petrol powered bmw and thinking about an f10 m5. I searched for a topic with common problems but I couldn't find any. If someone can help me with a link it'd be much appreciated. So far I was able to find out from other sources that there are problems with oil consumption and injectors. Any other common issues? Thank you
Old 01-09-2019, 02:08 PM
x13atma17x x13atma17x is offline
vroom! vroom!
Mein Auto: 1999 323i 5spd
subscribed - planning to buy in the coming days a 2014 F10 M5 with low miles (found one already), but want to know the same before I pull the trigger. thanks OP!
99 323i 5spd
-H&R Stage III Springs-19x8.5 Type III ACS Wheels-Pirelli 235/35ZR19 Tires-RBTech Exhaust System-Zimmerman X-Drilled Rotors-Xenon Interior Light Kit-Silver Gauge Rings-Hamann Eyelids-Clear Corners-Solaris Invisi-Bulb-ACS Shift Knob, E-Brake, Pedals w/ Dead Pedal-ACS Roof Spoiler-//M3 Lip Spoiler
Old 01-10-2019, 03:34 PM
DONROD DONROD is offline
Send a message via AIM to DONROD Send a message via Yahoo to DONROD
Mein Auto: 2015 M5 CP
So look for proper service of the plugs and coils. and oil changes. I have 15 CP and I got it CPO from the dealer. you may also want to check out
https://f10.m5post.com
this is the best place for info on just the F10. It is a great car. Also, I had the dif service done as soon as I bought her and put better oil in her, Some of the s63s will burn a little bit based on location and what kind of oil it is. I had to up the weight for my climate and no more oil consumption. Good luck and post some pics when you get it.
Old 01-14-2019, 11:33 AM
AggieKnight's Avatar
AggieKnight AggieKnight is offline
Can has cheezburger
Mein Auto: 2014 M5
2014 M5 here. I've had to have both driver and passenger door latch mechanisms replaced as they stopped popping the lock. Also had an AC issue that was replaced under my extended warranty. Other than that, only had to do oil and filter changes, and tires with reasonable frequency, as well as breaks replaced around 65,000. Highly recommend you get a local independent shop and build a relationship with them as things are expensive to fix on this car. Would highly recommend an extended warranty if you can find one as a result (USAA sells them through a 3rd party).
Overall, she's an amazing car that I enjoy almost every time I drive it (Bay Area traffic...). Be warned though - once you go M you don't go back.
WARNING: Author not responsible for the readers failure to recognize sarcasm.
Yield, I can has picture?
Current Car:
2014 BMW M5
Retired Bimmers:
2014 BMW i3
2013 BMW 550
2009 BMW 335
