Rear led lights - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 10-07-2019, 01:23 AM
carlpare carlpare is offline
Mein Auto: E46 m3 smg
Rear led lights
Hi,
I have a 2008 m3, I am wanting to upgrade the rear lights to the 2010 upgraded led lights, is this possible? As in a straight swap? Thanks in advance.
Sent from my iPhone using Bimmerfest mobile app
Old 10-15-2019, 10:00 PM
Jon Pappas Jon Pappas is offline
Mein Auto: 08 BMW M3 Convertible E93
Do you have a Sedan (E90), Coupe (E92), or Convertible (E93)? The complexity depends on which model you have...
Current ride: 2008 BMW M3 Convertible (E93)
Old 10-15-2019, 10:58 PM
Hi Jon,
I have the 2 door e92
Old 10-23-2019, 05:02 AM
Originally Posted by carlpare View Post
Hi Jon,
You're in luck, there are a lot of retrofit kits out there. e92 LCI conversions are extremely common, I've seen them all over youtube with plenty of links of affordable aftermarket options. In my case (e93), aftermarket options were limited so I went Genuine BMW. Back to your car.
If you go OEM or Genuine BMW, it'll require the taillights, a retrofit harness, and coding (to remove bulb errors).
If you go aftermarket, there are some that are completely plug and play.
I'm assuming you have the FRM3 module in your car. ECS is a great resource for figuring these things out. - https://www.ecstuning.com/b-genuine-...-kit/92lrfkt4/
