Removing engine cover - Bimmerfest - BMW Forums
Old 09-28-2019, 03:56 PM
backslashv backslashv is offline
Mein Auto: 2014 BMW X1 sDrive28i
I'm not sure how to disconnect these hoses from the cover. I'm thinking I should just pull them out with the plastic ring but wasn't certain. Could you help? 2014 X1 sdrive btw. Click image for larger version
ID:	866049 Click image for larger version
Old 09-28-2019, 09:35 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
They look like they should just pop out.
Have you grabbed the engine cover and pulled it out?
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 09-28-2019, 10:29 PM
To quote a fellow redditor:
See the plastic clips holding them? They open up, and you can take the harness out. They have overlapping clips that lock them closed. You pry them out (one in each direction), and the clip will open up.
It's hard to explain, but once you start fiddling with it, you will see how it works.
