What to expect with F01 / G11 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - G11 / G12 (2016 - current)
The next generation G11/G12 BMW 7 Series flagship forum. Unveiled June 10th, with production starting in August the 6th generation 7 Series comes in a light weight package with extensive use of BMW i carbon fiber technology. The interior quality raises the bar with a touch screen and gesture controlled infotainment system. Exterior styling has been a sticking point with mixed reviews so far.
Old 07-09-2019, 03:46 PM
fmahjobi fmahjobi is offline
Mein Auto: BMW 2004 745i
Hi,
I am thinking of buying a 2015 or 2016 750i and would like to know in general how reliable or unreliable these cars are. Basically looking for what I will get myself into with these two models.
My current e65 (2004 745i) got me pretty exhausted with the amount of work that I have done on it is still ongoing. There are stuff which I even gave up on that needed fixing e.g. iDrive.
If someone can tell me of their experience that would be great.
Thanks in advance.
2004 E65, 225k miles
DIYs done:
- Plugs, Coils
- Water pump
- Thermostat
- Flex Disk
- Trans Oil and Filter
- Control Arm
- Tie Rod
- CCVs
- Secondary Air Pump, fuse and hose
- Brakes & Rotors
- Windshield washer fluid leak
- Broken coolant vent pipe
- Alternator Bracket Gasket oil leak.
- Alternator
- Weep hole coolant leak
- Belt drive
- Vanos o-rings
- VCGs
- VP gasket
TBD:
- Trans issues
- iDrive not working
- Seat Restraint air bag lights on
- Valve stem seals
Old 07-09-2019, 11:29 PM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
Having had a 2002 745i myself as well, I would say that the F01 platform has fewer minor issues but also a few major issues especially with the N63 engine on earlier model years. Getting a 2015 750i will be the best bet if you must have a V8, but I would say consider the 2015 740i if you want a more reliable drivetrain. It won't feel slow compared to the 745i unless you've driven the 750i.
There was a "service action" for earlier build G12 750i's due to potential increased wear. Hard to say whether this will potentially be an issue later on, but there have been a couple cases of engine replacements that were needed. There have also some minor electrical glitches/annoyances reported, and as with any new model, I would recommend avoiding the first model year if possible. The B58 engine used in the G12 740i has had a good track record so far though.
https://www.bimmerfest.com/forums/sh...d.php?t=971937
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 07-10-2019, 01:42 PM
Thank you very much for your valuable information and advice.
DIYs done:
- Plugs, Coils
- Water pump
- Thermostat
- Flex Disk
- Control Arm
- Tie Rod
- CCVs
- Brakes & Rotors
- Alternator
- Belt drive
- Vanos o-rings
- VCGs
- VP gasket
TBD:
- Trans issues
- Valve stem seals
