Catalytic Converter Failure - Bimmerfest - BMW Forums
Old 01-21-2020, 12:06 AM
mmakabeh mmakabeh is offline
Mein Auto: 2010 650i
I am getting fail codes on Catalytic converter.. also on BanK 2 up and down on the O2.
Do you think it is the Cat or the O2 sensors?
or something else. ?
Old 01-21-2020, 02:30 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Itís typically the O2 sensors that go bad long before the cats but do you have a vacuum leak somewhere and the O2 sensors are working as they should? The O2 sensors are going to let you know your air/fuel ratio is off.
Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 01-21-2020, 05:53 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Have you done any work on the engine lately?
Old 02-10-2020, 07:02 AM
cjwcamaro19 cjwcamaro19 is offline
Mein Auto:
Same thing happened to my 04. It was the left Cat. It was done for had to replace it. Cost about $800 dollars for the part. Luckily, but unluckily I was having the valve stem seals and cover work done so the engine was already out so I didn't get charged the labor for the Cat.
cat, catalytic converter, o2, oxygen, sensor
