Newbies: Searching for Parts? - Bimmerfest - BMW Forums
Old 02-10-2020, 06:37 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
(Posted this on the two forums I frequent. Hope it helps.)
So, new here and searching for parts? It goes like this:
1. http://www.realoem.com/bmw/select.do and enter the last 7 digits in your vin. Find your Part Number and copy it.
2. Since PNPC is failing after no updates in 3 years, an alternative is http://www.furiousmethod.com. Bit clunky, but it works to call up the PN on about 20 parts sites. Some work better than others.
3. Look for OEM parts -- parts from the manufacturer who sold it to BMW. For example, the primary OEM for BMW suspension parts is Lemfoerder (and for some, TRW). Coolant pumps are Pierburg and VDO (never the Chinese "equivalent"). And so on. This parts will cost 50-75% of the BMW branded equivalent. Good parts houses identify the OEM equivalent.
4. All parts are not the same quality! For example: suspension parts range from the great (Lemfoerder) to the probably OK (Febi) to the unknown (Dorman, Uro). If you don't buy BMW or OEM, do your research.
5. All sellers are not the same credibility. Buy from a name house (FCP, Autohaus, Pelican and so on). High risk from parts on Ebay or Amazon -- both are sketchy about filtering out fakes or cheap crap. You only real protection is to buy from a place that has a name to protect in the community. I'm skeptical of autoparts shops, since their buyers don't understand BMW's and often sell odd-branded parts at relatively high prices. Ask for the OEM manufacturer's brand. Rockauto sells many levels of some parts and good prices -- but pick the OEM ones by name.
6. Then, all that said, look for the best price plus shipping and a warranty return.
Hope this helps if you're new to buying BMW parts.
Good luck.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
