Hi-Fi (option 676) Sound Upgrade - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 F48 (2016 - current)
Second generation F48 BMW X1 builds on the success of it's predecessor. Increases in power, interior and cargo space keep it a leader in the small SUV field.
Old 11-06-2019, 04:48 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
This is truly the "M package" for your SAVs audio! This amp delivers high quality, detailed audio versus just "loud" and is a major improvement over the stock hi-fi configuration. Now the underseat woofers generate solid mid-range bass that can only be improved on by a subwoofer in the trunk. I bought this gently used amp from a member on "the other board." Installation began with a review of directions at newTIS.info for the removal of the side panel, disconnecting the negative lead from the battery then, using trim removal tools and a generous measure of patience, finally gaining access to the Hi-Fi amp mounting plate. Wiring the Match Up 7BMW amp was the easiest part; it's truly "plug 'n play." Programming/configuration was done with a Windows PC using the DSP PC-tool V4 and various sample sound setup files (as a basis) downloaded from the Audiotec Fisher website.
ID:	871151   Click image for larger version
ID:	871153   Click image for larger version
ID:	871155   Click image for larger version
ID:	871157   Click image for larger version
It's not really yours until you void the warranty.
Old 11-06-2019, 11:10 PM
Takabo Takabo is offline
Mein Auto: 2019 F39 X2
Hello.
That's amazing. by the way…
Have you changed the following settings?
HU_NBT_EVO?>
3002 AUDIO_TUNER_TRAFFIC, 96> AUDIO_SYSTEM = hifi or tophifi (default: stereo)
OPTIONS (stereo = 00, hifi = 01, tophifi = 02, individual_sound = 03, hk_surroundsound = 04, highpremium = 05, hifi_system_harmankardon = 06)
Thank you.
Originally Posted by Ridin'Dirty View Post
This is truly the "M package" for your SAVs audio! This amp delivers high quality, detailed audio versus just "loud" and is a major improvement over the stock hi-fi configuration. ...
BMW X2 sDrive 18i M Sport X (F39)
Production Plant: Regensburg, Production Date: 2018-10-25
Old 11-07-2019, 07:26 AM
Originally Posted by Takabo View Post
Hello.
By the way…....
Thank you.
It is unnecessary to do any coding for this amp on F48's that come to North America because they are equipped with the Hi-Fi head units and OEM amplifier as the minimum standard; there is no base stereo head unit offered. The only other option available here is the Harman Kardon stereo upgrade but that does not work with this amp. Now if I replaced the OEM amplifier with another (different) OEM amplifier or with the Harmon Kardon amplifier, then coding of these replacement units would be necessary (as per newTIS.info).
Old 03-03-2020, 04:17 PM
"Say hello to my little friend"- Tony 'Scarface' Montana
Picked up a Focal Bomba BP20, 150-watt (max power - 300 watts) powered, ported subwoofer (frequency response: 25Hz to 125Hz). This is the perfect compliment for the Match7 BMW amp to give me that low bass that the stock, under-seat woofers can't provide. It is compact in size (aprox. 17 x 12 x 9 inches) and the angled back matches the rear seats when reclined. I plan to power it from the power outlet in back since it only draws 15 amps max.
ID:	884093   Click image for larger version
HTML code is Off
