Polishing Exhaust Tips - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 11-15-2019, 05:33 PM
isstatu1 isstatu1 is offline
Mein Auto: 2010 750Li
So my exhaust tips are a little dark on the bottom from all of the exhaust on my 2010 750li. Can I just wet sand the tips with 2000 grit sand paper, or is there some other method that I should be doing?
Old 11-15-2019, 05:55 PM
HerbP HerbP is online now
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Try using the wheel cleaner in a can that looks like white steel wool. You could use a Brillo pad.
Old 11-15-2019, 07:26 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
Have you considered using a fine metal polish like Blue Magic 400 or Happich Semichrome or is the staining just too significant?
It's not really yours until you void the warranty.
Old 11-16-2019, 12:14 AM
Autoputzer Autoputzer is online now
Mein Auto: 2014 535i + 2018 X3 30i
Using any kind of steel wool can leave dissimilar metal embedded in the metal of the exhaust tip, causing accelerated corrosion.
Anytime you're polishing something, you should start with the mildest product and then work up in strength until something works. I got most of my corrosion of with, oddly, Meguiar's Swill Remover. But, it came back in a few weeks.
Old 11-16-2019, 06:13 AM
I'll try the soft products first, thanks! The staining isn't significant, but I just don't want to do more damage than help.
Old 11-16-2019, 07:47 AM
1bad540's Avatar
1bad540 1bad540 is offline
use steel wool, its a ss tip but the water from your exhaust leaves carbon on it. Brillo pad w soap on it will work best. Ive used it on every exhaust ive had including corsa borla,and factory tips.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 11-16-2019, 12:32 PM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
As mentioned already, start with the mildest abrasive/cleaner first. P21S polishing soap worked well for me, starting with a toothbrush, then a scouring pad, then a Mr. Clean melamine sponge (it's like a very fine sandpaper). Avoid steel wool unless you really cannot get the carbon off.
I would also recommend taking the tips off the car so you have more working room and don't need to worry about scratching the paint. Pull the diffuser off and there are three screws holding the tips onto the bumper.
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 11-16-2019, 07:01 PM
It's not carbon on the tips, it's corrosion. The BMW rep's seem to be telling the dealerships it's carbon and that the solution is to "clean" them with steel wool. They did that with my car. Two weeks later it was back, and they replaced the tips.
The early direct injection engines (e.g. N55) do put out a lot of soot. But, if it was "baked on carbon" it'd be inside the exhaust pipe, not just on the bottom of the lip of the exhaust tips. The soot inside my exhaust cleans right off (with Remington gun oil). Frau Putzer's second-generation direct injection "B46" engine produces almost no soot. You can look up the exhaust pipe and see bare metal in there. The tips are fine, too.
I worked with equipment made out of stainless steel that got dunked in the ocean. The devices had stainless steel caps with O-rings. The tech's would pry the old O-rings off with metal screwdrivers. That'd leave dissimilar metal pieces embedded in the stainless steel caps and they'd start corroding. I made the techs start using hard plastic screwdrivers (electronics "tweaking tools") and that solved our corrosion problem.
Old 11-16-2019, 07:07 PM
Tried various cleaners and it's not coming off. It feels like it's corrosion rather than soot. In my audi the tips were smooth and the build up would clean off with some degreaser and a soft sponge. I guess I'll try the steel wool next, I'm sure I have some Brillo under kitchen sink. What are the tips made out of? Chrome? Could they be recoated with chrome?
