2017 X1 Fuse for Cup Holder Socket? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 F48 (2016 - current)
Second generation F48 BMW X1 builds on the success of it's predecessor. Increases in power, interior and cargo space keep it a leader in the small SUV field.
Old 11-17-2019, 09:36 AM
u240018 u240018 is offline
Mein Auto: 2008 BMW X3
All other sockets for chargers work fine. The cupholder socket stopped working while moving around a charger, so I suspect the fuse blew. But which fuse??
I opened the glove compartment for fuse access, and the diagram says it could be fuse 63, 65, 100, 115, or 132. 63 & 65 are easily accessible 20A fuses, and both are fine. 115 doesn't exist, the spot is empty. 100 is just a 5A fuse, and 132 is a 20A fuse, HOWEVER, both seem impossible to get to. Do you have to somehow disassemble part of the glove box to get at them? Are those the right fuses? I can't find online anywhere.
Old 11-17-2019, 07:26 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
This should help:
https://www.newtis.info/tisv2/a/en/f...ket/1VnY1dADnY
*Click on the image to enlarge or use the website link*
It's not really yours until you void the warranty.
Old 11-17-2019, 08:18 PM
Markst Markst is offline
Mein Auto: BMW 5
The socket in front of the gear lever is on fuse 65. Check that your charger is actually making contact inside the socket, sometimes they don't fit too well together.
Old 11-18-2019, 07:18 AM
I've tried multiple chargers, they all work in all the other sockets, include the one not listed in the owner's manual mounted underneath the glove box. I found that one by accident. Fuse 65 is fine, ohms out fine, I even swapped it with another to be sure, yet nothing works in that cigarette lighter / front cup holder socket. Bad socket somehow?
Old 11-18-2019, 09:46 AM
Rustynuts Rustynuts is offline
Mein Auto: 16 X1 M-Sport
Can you fully plug in the USB without fiddling? I had someone try to jam a USB plug upside down and literally broke off the little circuit board inside the socket.
Old 11-18-2019, 10:54 AM
Maybe I wasn't clear, this is the 12V cigarette lighter socket in front of the cupholder, this is not the USB plug.
Old 12-03-2019, 08:49 PM
You may have to remove the front storage compartment to be able to check for power at the back of the socket or to replace it if defective (looks like a big job just to gain access.):
https://www.newtis.info/tisv2/a/en/f...les/1VnYtHUFRr
fuse 2017 x1 lighter cupholder
HTML code is Off
