High Fuel consumption - Bimmerfest - BMW Forums
Old 11-30-2019, 09:01 AM
Dani1121 Dani1121 is offline
Mein Auto: 2004 BMW e60 530i
Hi experts i am facing some problem, no fault codes but fuel consumption is very high about 19L/100km M54B30 I checked through INPA but didn't understand what's this means so if anyone can help me out then it'll be great ***x1f44d;
ID:	873847   Click image for larger version
Old 11-30-2019, 05:07 PM
mjchecko mjchecko is offline
Mein Auto: 535i
How is performance and power? What is mileage of the car? Other relevant details? I don't know inpa at all but diesel truck-like mileage is often related to failing o2 sensors.
mjchecko
Old 01-01-2020, 07:16 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
I cannot reply to your PM:
"Dani1121 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-02-2020, 09:36 AM
Performance is not so good car is not running smooth like rpms are high but speed is slow just like 4 cylinders car
Old 01-02-2020, 03:03 PM
Pete_NZ Pete_NZ is offline
Mein Auto: E61 530D E91 330d E46 328
fuel consumption is very high about 19L/100km ...;
.... diesel truck-like mileage is often related to failing o2 sensors.
Diesel truck mileage??! Thems fightin words. My actual diesel truck gets 12L/100km!
(My 530d gets 5.7L/100km with 500Nm of torque which is actually more than the truck. !?)
Old 01-02-2020, 05:47 PM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
Do you have the check engine light illuminated? Do you have a simple obd2 reader? From your description, it sounds like you have misfires which might be the coil pack or might be the plugs.
Unfortunately I don't read German and I'm not familiar with inpa, so I can't direct you where you need to go within the program for simple code reading.
2006 E61 MT
2010 E91 MT
Old 01-03-2020, 09:16 AM
Mein Auto: 535i
Lol well I'm was I thinking about 18 wheelers and RVs which is usually really poor mileage
I'm a big fan of oil burning cars. Last time I had my car in for dealer warranty work they gave me a 335d (or some turbo variant I don't remember exact model) and it was FAST and great mileage
mjchecko
Old 01-03-2020, 09:36 AM
MysticRob MysticRob is offline
Mein Auto: E61 535xi Deep Sea Blue
Before going off on any mileage crusade, ensure you're getting accurate distance/consumption info by verifying you have correct wheel/tire combo for your speedometer, proper air pressure, calculations done at the pump, taking winter gas blends into account, type of drive (uphill on local streets both ways), etc.
The big thing is not to simply trust the MPG/KPL readings on the digital display. Verify using actual distance traveled and liters used to refill the tank, then let us know results.
BTW, the conversion puts you at just over 12 MPG, which is pretty bad, unless again, you're not using accurate accrual info.
All things being equal, injectors, coils, plugs, and vacuum leaks are usually the big 4 that crap out mileage. Less common, but still possible would be a clogged cat or bad O2 sensor(s).
2008 535xi E61 Touring Wagon / 110k Miles / Deep Sea Blue Exterior / Natural Brown Leather Interior / MHD Stage 2 91 Octane Tune / xHP Stage 2 Transmission Tune
Old 02-18-2020, 06:08 AM
darckreign1984 darckreign1984 is offline
Mein Auto:
helo,
please help - what can cause a consumption mixt like 12.4l/100
or city 20l and medium speed - 17-19km/h
outside 7l and medium speed 62km/h
thanks
Old 02-18-2020, 06:33 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Newbies: OK, before you do anything else, this is how you ask a question on a Forum: "My Year, Model, Mileage, Engine Type is doing (this and that bad thing), and it's showing BMW codes XXXX and YYYY, which seem to mean (code meanings)." That is, if you want a helpful answer…......
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 02-18-2020, 06:38 AM
Mein Auto:
Originally Posted by banglenot View Post
Newbies: OK, before you do anything else, this is how you ask a question on a Forum: "My Year, Model, Mileage BMW is doing (this and that bad thing), and it's showing BMW codes XXXX and YYYY, which seem to mean (code meanings)." That is, if you want a helpful answer…..
530d non facelift
from 2005
218hp
autogearbox
no errors on car
only consumption problem, and no its not the problem cluster instruments - i post my problems in other forum, with more picture regarding injectors test, return test, dino test.
i am living in Romania.
- now its ok?
Old 02-18-2020, 06:42 AM
banglenot's Avatar
Originally Posted by darckreign1984 View Post
530d non facelift
ear 2005
218hp
autogearbox
no errors on car
- now its ok?
Yeah, thanks! Best location for help is to go to the diesel forum here on BF. 95%+ of the cars in the USA are petrol, so little of the discussion on this subforum is diesel. That's https://www.bimmerfest.com/forums/fo...play.php?f=154 Welcome to the forum!
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 02-19-2020, 02:33 AM
mtnbimmer mtnbimmer is offline
Mein Auto: 325ix, 530xi
No, thank you.
Now the next subject for Newbies could be thread jacking.
