Weird Oil Life reset issue. 2008 535xi - Bimmerfest - BMW Forums
Old 02-10-2020, 06:31 AM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
I changed oil and filter 2 months/2000 miles ago. A few weeks after the Service Due light came on for oil change. I figured I forgot to reset it and so I reset it with the Foxwell tool. The next day it cam back. I've reset it a few more times and then used Carly for a reset, every time the warning returns almost as soon as I start the car.
I finally looked up the dash reset using the trip odometer button. It reported a successful reset to 15,000 miles. The next startup gave me the Service Due warning again.
It's always engine oil. Everything else seems fine.
Any ideas?
Hobby mechanic doing my own work for 50 years or so.
We have a 2006 530xi Touring and a 2008 535xi sedan.
I can't really remember the last time I took a car to a repair service.
Old 02-10-2020, 06:53 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
The car does have a CBS (condition based service) element to oil changes. Perhaps whatever triggers a oil change event that is not mileage based is malfunctioning and the system is just responding to that. I don't know what all goes into the car deciding anything other than mileage for an oil change.
Old 02-10-2020, 07:31 AM
I thought it checked oil condition as well as miles. I may have to drain the oil and check if it is contaminated. I pulled the filter out this morning and the oil looked and smelled normal. I do have a fuel mixture problem that I think is injector related. Guess I should look into that, too.
Old 02-10-2020, 07:35 AM
twh twh is offline
Condition OR Miles
Old 02-10-2020, 07:46 AM
I've read that the oil level sensor has condition sensing electrodes to measure oil conductivity or such. I shall research more. Car seems to read oil level fine, maybe a little slow to appear...
Old 02-10-2020, 08:52 AM
The sensor for oil level, condition, and temperature is all 1 unit.
https://www.meeknet.co.uk/E64/oil-sensors.pdf
page 3
Old 02-10-2020, 09:00 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
From RealOEM
"Before replacing the oil level sensor always note PuMA measure 29604954"
https://5series.net/forums/attachmen...9604954-01.pdf
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 02-10-2020, 09:33 AM
Thanks for this info.
I doubt the sensor is the issue as I have no codes. I will drain the oil and see what it looks like. If it is contaminated, I'd think there would be something visible. I may just change it and the filter anyway.
Today it shows one green square down from full which matches the normal consumption for this car.
It's a weird situation.
Old 02-10-2020, 09:38 AM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
The type of oil matters as well. The additive package in the synthetic oil affects how the sensor works, which is by measuring the dielectric constant of the oil. In other words, it's a capacitor based measuring system. The wrong oil gives a funky measurement value.
2006 E61 MT
2010 E91 MT
Old 02-10-2020, 09:49 AM
I've used Mobil 1 Euro 0w-40 since we bought the car in 2014. I used Castrol Edge Euro a couple of times because I found a great deal on it but went back to Mobil 1 as it is easy to find. LL-01 oils are kinda rare. I know, Mobil 1 isn't LL-01 any more but the standard changed, not the oil.
Thanks for the info tho... every little bit helps.
Old 02-11-2020, 05:30 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Have you used any additives?
I tried Certek (molybdenum) from Liquimoly. Worked well for what it does, but after several months I noticed my CBS data was rapidly reducing my remaining miles much faster than normal, down to few hundred remaining miles when I started the car.
Replaced the oil, and over the next month the sensor returned to a normal reading. I assume the Certek was interfering with the readings.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 02-11-2020, 08:12 AM
That's good to know.
I think I'll change oil and filter today.
No additives in it tho...
