6WB Retrofit - Coding Required - Bimmerfest - BMW Forums
Old 06-02-2013, 01:42 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
I finally got around to installing my 6WB MFID Instrument Cluster.
Since mine was a brand new virgin Kombi, no EEPROM work was necessary to blank the donor car's mileage and VIN. Install was a breeze, and Coding was just a matter of adding 6WB to the VO, changing VO Production date to 1211, and VO Coding DKombi and HU_CIC.
Since my car does not have ECO Pro, I get just the Comfort and Sport mode displays.
Upgrading from the basic Kombi to either 6WA or 6WB is a dramatic improvement, and worth every penny. If I already had 6WA though, I personally would stick with it rather than invest in 6WB.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 06-02-2013, 03:45 PM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 750i
Looks AmAzing!!!!! Cost?
Old 06-02-2013, 03:52 PM
Thanks. It's about $2k for a new one. I got mine from an overseas BMW Dealer, but you can get it from Bimmer-Tech:
http://www.bimmer-tech.net/shop/bmw-...panel-retrofit
Old 06-02-2013, 05:54 PM
TL2E90 TL2E90 is offline
Mein Auto: 2018 BMW 750Li
Old 02-11-2019, 02:34 PM
shaohuiclub333 shaohuiclub333 is offline
Mein Auto: 328
the F2O 's basic kombi is different process,must be write the 6wb vo to svm
Old 10-16-2013, 12:43 PM
kaxasia kaxasia is offline
Mein Auto: BMW F10 550 M
Hi Shawn, I order new 6wb claser and can I codin my self? With e-sys? Or have any instructions, best regards
Old 10-16-2013, 12:47 PM
Yes, you can code it with E-Sys. If it is new and not used, you can do just as I wrote in my original post, which is add 6WB to the VO, change VO Production date to 1211, and VO Code DKombi and HU_CIC.
Old 01-26-2017, 01:59 PM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
thats it? just plug/play and FA code and code Dkombi and HU_CIC? So i can buy car 2012 and cables will be the same? what if the 6wb will be used from another car?
Old 01-26-2017, 02:12 PM
If it is used, you must desolder EEPROM from Motherboard in Kombi, use EEPROM Programmer to Blank Mileage and VIN, solder EEPROM Back, and then install to car, flash DKombi, and the VO Code DKombi and HU_CIC.
Old 01-26-2017, 02:34 PM
uragan1987 uragan1987 is offline
Mein Auto: X3 F25 2012 35iX
Not on every DKOMBI you have to desolder EEPROM
first you can try do it without do that
at me it works fine with a soic8 clip
just for info
PS: First of all you have to check your connector to KOMBI
if you dont have optical fiber, then you cant use DKOMBI
Old 01-27-2017, 01:29 PM
Curamrda's Avatar
Mein Auto: Fxx
I am quite confused....
I do understand, that the used 6wb clusters could have different milage stored.. so I have to sync the milage with othercurrent ECUs, but I do belive, that there is some master milage unit, which provide the actual value. Since If I buz some used parts/ecus, I have to syncronized them with some main /server unit?
Old 02-11-2018, 08:46 PM
mdrajput mdrajput is offline
Mein Auto: BMW 550i
steps needed
Hi Shawn, can you give me steps by stpes instruction to code 6WB on F10.
You are gru of all this, I would really appreciate if you can send me each step to how to do coding,
I bought used cluster, but I do have eSYS for coding...
Mein Auto: BMW 550i
steps needed
Hi Shawn, can you give me steps by steps instruction to code 6WB on F10.
Old 02-12-2018, 05:09 AM
Those are Step-by-Step Instructions.
If you do not understand them, you need to read the Coding Guides included in E-Sys package.
And since you buy a used Kombi, I assume then that you have plan to blank VIN, and Mileage if needed, from EEPROM before installing.
Old 02-12-2018, 06:59 AM
Mein Auto: BMW 550i
Eeprom
Hi Shawn,
Regarding. blank VIN, and Mileage if needed, from EEPROM before installing.
Do you have details or steps to clean the EERPROM..
Old 10-16-2013, 12:54 PM
Yes its new, my car updated until 48.3 psdzdata, I have to update all ecu or . Must use e-Sys last version with 50.4 v
Old 10-16-2013, 01:06 PM
48.3 was used though March 2013, so it should be fine.
Old 10-16-2013, 01:17 PM
thanks so much...)))
Old 10-21-2013, 07:51 AM
tom2325 tom2325 is offline
Mein Auto: F30,F10
Hi shawn,
I also installed the 6WB MFID Instrument Cluster.
But after FA coding, there is no cafd in DKOMBI at the SVT area.
So, I can not code DKOMBI module...
All I have done is as follows.
1) Connect E-Sys and Read FA from car at the Coding Function in Expert mode.
2) Save FA and Edit FA
3) Add 6WB to SALAPA and calculate FP with no error.
4) Save FA
5) Select Expert mode, VCM function and select FA.xml file at the Vehcle Order.
6) Select the VCM Master tab and click the Write FA FP button.
7) Select Coding function and read FA and Activate FA and Read SVT.
My cluster get error it should be updated when ignition on.
The Tachometer and speedometer does not respond when engine on.
I am very glad if you give me some advice...
Old 10-21-2013, 08:31 AM
Mein Auto: F30,F10
Sorry, I forgot to attach the screen shot...
This is the E-Sys SVT screen with no cafd in DKOMBI module.
Name:	2013-10-21 23.28.44.jpg
I coded the FA according to the instruction from this post.
But I got an message like this which was not described at this instruction and I clicked yes.
Name:	2013-10-21 23.06.01.png
I wonder this is why my DKOMBI has no cafd...
Old 10-21-2013, 09:41 AM
Originally Posted by tom2325 View Post
Hi shawn,
4) Save FA
You need to try and inject CAFD into Kombi ECU:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DKombi => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level => Select OK => Right-Click on DKombi (the ECU itself not the underlying CAFD) => Select CODE.
Old 10-21-2013, 10:17 AM
Mein Auto: F30,F10
Hi shawn!!
I completed installing my cluster with no errors!!
Thank you very very much for your help!!
6WB is exiting!!
I really appreciate your quick and kind advice
Name:	2013-10-22 01.59.51.jpg
And may I ask one more question just for my study...
After VO Code of DKOMBI, the SVT shows ECUs(28,1), the "1" font color is red.
And DKOMBI module font color is black while others are blue.
Please let me know this means something error?
Thank you very much in advance.
Name:	2013-10-22 01.54.39.jpg
Old 10-21-2013, 10:27 AM
Hi shawn!!
6WB is exiting!!
Attachment 403269
Attachment 403270
Your 6WB looks good.
This is normal. The different colors depict the different states of your actual ECU firmware compared to the reference firmware (PSdZData version)
The SVTs recorded in red letters indicate the reference system state of an ECU. The blue ones indicate the actual state of the ECU. Black entries indicate SVTs with identical reference and actual state.
Old 10-21-2013, 10:58 AM
Mein Auto: F30,F10
Attachment 403274
Thanks for letting me know. I appreciate very much!
I felt faint with no cafd of my DKOMBI...
you saved my F10 from a scrape!
Old 01-29-2018, 03:25 AM
Kruder Kruder is offline
Mein Auto: BMW 335I
I have brand new 6WB installed from 6WA on F30. I added VO but was not able to add e production build date. Not sure it matters?
I was also not able to inject the CAFD as the button for “Detect CAF for SWE” was not clickable. Pls help. I have attached a screenshot for reference. What steps did I missed ? I was not able to proceed further for DKOMBI coding...
Sent from my iPhone using Tapatalk
