X3 dash center speaker - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 G01 (2018 - current)
The third generation X3 starts production in August of 2017 and will include the new X3 M40i top of the line performance model.
Old 02-21-2020, 03:06 AM
Badtourist Badtourist is offline
Mein Auto: G01 BMW X3
Hi,
I have the base audio in my X3 and am having the audio updated. Is it possible to cut out the recess where the speaker would fit in the dash and fit speaker brack with mud and tweeter and Orem speaker grill? Also does mine have an analog or digital CAN BUS (100 or 150?)?
Old 02-21-2020, 07:52 PM
xx xx is offline
Mein Auto: F15 X5 and G01 X3
Open the cover/grill and look in there. There might be a replaceable bracket already.
X3 E83 (sold) | X5 E70 (sold) | X3 F25 (sold) | X5 F15 | X3 G01
Old 02-22-2020, 01:05 AM
As per attached picture there is no hole or grill just a recess in the dash where it should be if fitted. Can I cut that out and fit grill?
Old 02-22-2020, 09:35 AM
xx xx is offline
Oh. That is very different from the ones here (i think we have grills as standard). If trying to fit the OE BMW grill, it will require a whole lot of precision cutting and parts as the grill has a bunch of tabs/prongs going into small holders in the dash. Might be easier if you make your custom grill following that shape/outline. Let me find some recent/old pictures...
Old 02-22-2020, 10:14 AM
xx xx is offline
Ok just found some pictures from last year. These are the factory H/K config/parts. Maybe you can use the OE grill but might have to trim/cut the 6+3 tabs, and then safely affix the grill to the dash using another method (don't want the grill to dislodge in case of an accident). But then again, if after trimming the top "leather"/section we magically find the cavity and all the attachment points hiding in there... then hey we're all set! (?)
ID:	882787   Click image for larger version
ID:	882789   Click image for larger version
ID:	882791   Click image for larger version
ID:	882793   Click image for larger version
