Oil Life Monitor - Bimmerfest - BMW Forums
Old 05-14-2019, 03:57 PM
chris.luurtsema chris.luurtsema is offline
Mein Auto: 2014 328xi
Oil Life Monitor
Hello! I have a 2014 328xi N26 w/ 68k miles. I changed my oil about a month ago and reset the oil life monitor afterwards. I used BMW Twin Power oil and Mann filter from FCP euro as I have done for the last two oil changes since my 50k service program dried up.
My question is in regards to the oil life monitor and how quickly it updates. I keep noticing during startup that the next service is in 9000 miles.
(oil is the next service due in the menu list this followed by a service check in 27k)
I have put about 1300 miles on the car since the oil change and the monitor has not reflected a change from the 9000 initial count down. Is this normal? I do a lot of highway miles but my OCI has averaged about 8500 miles according the CBS monitor. I am wondering if the computer is messed up or has a glitch? I thought it showed a countdown quicker.
I appreciate any input.
Old 05-15-2019, 10:01 AM
Bueller.... Bueller...
Old 05-15-2019, 12:46 PM
Wolfus Aurelius Wolfus Aurelius is offline
Mein Auto:
If you're doing mostly highway miles, that's the easiest kind of mileage for any car. That kind of service has barely tapped the ability of the oil to lubricate, cool, and hold contaminants in suspension. I suppose you might see a change soon, but 1300 highway miles out of a projected 9000 OCI is not very stressful at all.
Which reminds me to ask: How does BMW's computer figure the OCI? Is it by algorithm based on cold starts, city vs. highway driving, temps during short trips, etc. -- or does it actually test the oil?
Old 05-15-2019, 01:50 PM
namelessman namelessman is offline
Mein Auto: bimmer
To OP, the CBS oil change interval is based on gallons consumed as well as oil condition read by the oil level sensor.
For F30 with OCI of 1 year/10000 miles, the number of gallons per OCI is around 333 gallons, assuming 30mpg.
If your mpg is above, or below 30mpg, the OCI miles will adjust accordingly.
Old 05-16-2019, 12:09 PM
Thanks for the input. I will keep watching. I have been averaging just over 30 mpg. So that may be part of it.
I could just drive flogging the crap out of it to see if that changes anything as well..
Old 05-16-2019, 09:18 PM
DCWhybrew DCWhybrew is offline
Mein Auto: 2014 320i
Its normal. Donít worry about it. The computer will let you know when to change the oil.
Old 05-17-2019, 04:16 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
I do a lot of highway driving too. The interval on mine actually ranges between 10k and 11k. It's been consistent since new. The highway mpg on my car is pretty impressive too.
Old 05-20-2019, 09:51 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i/F30
It is normal. What seems to happen is that it stays at a high number, say 9000 miles, for a long time. Then it drops to 8000 miles or so. When it is around 2000 miles, it drops like a rock.
In other words, slow countdown at first, then speeds up too fast.
There is no chemistry lab in the engine compartment. It's not even resistance to electrical current or how well a float floats up.
I believe, but am not certain, that after 2000 liters of gas (about 500 gallons) is used, the oil life monitor indicates it's time to change oil. So a lot of cold weather, short trips will use up gas and result in a lower oil change interval. A moderate temperature and 100% long highway trips will have good fuel economy and a long oil change interval to 500 gallons.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
Old 05-20-2019, 10:43 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Correct - it's a capacitive measurement of the dielectric property of the oil. The oil condition/level sensor is based on a capacitor that uses the engine oil as the dielectric. As the oil ages the measured capacitance changes. In other words, direct measurement of oil quality is a variable in the CBS oil-service estimate. Fuel consumption is another and elapsed time since the last oil change (i.e., CBS service reset) is a third.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 05-21-2019, 01:58 AM
Mein Auto: bimmer
Yes that is what my bookkeeping shows, for 15000 miles/2 years OCI, the number of gallons consumed is set to 500 gallons for F30, assuming around 30mpg. The 10000 miles/1 year should be around 333 gallons.
Old 05-21-2019, 12:24 PM
Elk Elk is offline
Mein Auto: ~
Akin to the fuel gauge.
Similar Threads
DIY: E39 Changing engine oil made simple (how to do it in 30 minutes and not crying!) cn90 E39 (1997 - 2003) 129 04-15-2018 08:53 PM
BMW Service Codes 00000000 through 09999999 mksu19 General BMW Questions 7 02-22-2013 07:07 PM
