F30 window incremental roll up/down - Bimmerfest - BMW Forums
Old 05-13-2019, 02:12 PM
jwhite5497 jwhite5497 is offline
Mein Auto:
Its a 2012 328i F30 BMW. The problem is every time i roll the window up or down it only moves in 1/2" increments. I have tried resetting the window (rolling it down, holding button, rolling up, holding button). I have also pulled the door panel off and replaced the motor driver/window regulator combo and I am still having the exact same issue (note that both were tested side by side, while not installed. This means they were not seated in the door or holding up the window so it can't be an issue with the window track). Any ideas what other issues could be causing this?
Old 05-13-2019, 02:31 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
The window switches on my car have two positions. Pull up slightly to the detent and hold to move the window as far as needed. Pull up fully past a detent and the window moves all the way. I believe your window switches should work like that. If not you may have a defective switch.
Old 05-13-2019, 02:41 PM
Mein Auto:
John, both positions result in the window moving only 1/2" up. Unless both the drive switch and seat controlled switch are faulty it cant be the switch because the both result in the window moving the same amount.
Old 05-13-2019, 02:52 PM
I wonder if an overload relay is being triggered. Window dragging in the track...
Old 05-13-2019, 03:13 PM
namelessman namelessman is offline
Mein Auto: bimmer
To OP, does this happen on all 4 windows, so just specific one(s)?
Old 05-13-2019, 04:17 PM
Mein Auto:
Namelessman, it only happens to the one window.
John, two separate motor drivers completely detached from the window (just the motor by itself) still only move incrementally which means the track isn't affecting the motor performance.
Old 05-13-2019, 05:33 PM
Do you have a wiring diagram for the window?
Old 05-13-2019, 06:34 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
So you already replaced the effected window motor?. try bringing the window all the way down, hold it in down position for 20 seconds then reinitializing it. I had an e90 that did same thing your experiencing and the internal hall effect sensor in the window motor was faulty
Similar Threads
2011 335D Window Switch Failed but Windows roll up/down with keyfob dreemail E90/E91/E92/E93 (2006 - 2013) 1 04-19-2019 07:46 AM
Driver Side window Won't Roll up E92 samratz New Member Introductions 0 06-02-2015 02:09 PM
Window Electrical Problem Kouks E34 (1989 - 1995) 1 03-14-2011 10:01 PM
window wont roll up bummedbmw E34 (1989 - 1995) 2 07-25-2008 07:56 AM
