Plastic oil drain plug - Bimmerfest - BMW Forums
Old 05-14-2019, 08:42 AM
mickael mickael is offline
Mein Auto: 2005 BMW 325i
Question Plastic oil drain plug
Hello everyone, I recently did my 1st oil change on my 2014 BMW 320i F30 N20.
I bought the Filter and Plug and the oil from the Dealer.
After I greased up the new seals and installed them checked the oil no leaks. I checked the oil drain plug and it looked wet so I wiped it off, waited, didn't see any drips so I left a paper towel and took the dog for a walk and didn't see any drips when I got back, the plug still looked wet with little residue when I wiped it. Waited again, wiped it and more residue but no drips. Did this about 6 more times. I don't see any actual drip stains, just seems like the plug is seeping at a microscopic rate.
Should I replace the plug or am I just being paranoid?
Old 05-20-2019, 08:55 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i (F30)
Maybe keep checking then replace it. It is suppose to be one time use. The tightening torque is low. I think it is 8 nm or 5.9 ft. lbs. That is the plastic one, not the metal, high torque one in a F30 x-drive.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
Similar Threads
Plastic Oil Drain Plug lawfive1 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 3 04-28-2019 05:39 PM
DIY Oil Separtor, DISA, ICV Lbert E46 (1999 - 2006) 221 01-24-2018 12:49 PM
BMW Service Codes 00000000 through 09999999 mksu19 General BMW Questions 7 02-22-2013 06:07 PM
